Old 23rd May 2010, 19:14   #8281  |  Link
unrox
Repost
I have made copies of Avatar, made 2 copies each in BD5 and BD9. Neither of th BD9's would play on my stand alone, yet played on the computer. I have a Panasonic B60, the BD 5's played on both, Used Verbatim 2.4X disks on all. Any ideas? Also one copy of each was full movie and one movie only.Again neither worked On BD9, both did work on BD5. T.I.A.
unrox is offline   Reply With Quote
Old 23rd May 2010, 21:11   #8282  |  Link
humphammer
Did you use AVCHD patcher 1.06 before IMGburn? IF not that may be your problem.
humphammer is offline   Reply With Quote
Old 23rd May 2010, 22:22   #8283  |  Link
No it's not. AVCHD Patcher is never needed. The problem is the Panasonic -- it just doesn't like BD-9s for some reason.
Old 23rd May 2010, 23:32   #8284  |  Link
saphire199
Hi, sorry to ask this as I know I have read something on this before on threads, I cldn't find it again. I'm trying to burn movie, full backup to DVD9. When done, it shows up as a data disc on PS3, and won't play on PC with Power DVD 10. Is this because:
1. DVD 9's don't do well with full movie backup?
or
2. There is a setting I have to adjust to enable this to happen?
saphire199 is offline   Reply With Quote
Old 24th May 2010, 01:37   #8285  |  Link
SLOVEHEART
SLOVEHEART
SLOVEHEART's Avatar
I still recommend AVISYNTH 2.5.7, but there haven't been any reports of issues with v2.5.8 that I could conclusively point at AVISYNTH so I decided to list it at "Ok". I think it may have gotten some of the blame for HAALI versions that didn't work and got corrected with a "complete reinstall of support components".
As for CoreAVC -- I can only say that I bought it, and ended up reverting to FFDSHOW because it had issues with playback of some sources. So if you decide to use it, always remove it and try FFDSHOW before posting a bug.
Yes, "Blank this stream" is planned for future implementation. Probably not for FFMPEG, although at one point I added that as a placeholder. Frankly X264 works so well that other choices (like I had in BD Rebuilder) seem senseless now.
Thanks for the reply - I only get to the forum sporadically.
I'll remember the AviSynth issue if I have troublke with encodes - which after my switch from Vista x86 to Win7 x64 hasn't been a problem at all. I mentioned this is Afterdawn's thread on BD-RB. As for blank this stream - it would be a nice way to edit - I'm sure it would take some doing - as the structure would change then (if used). And as for the encoder(s) - x264 is fine w/ me!!! Just wondering what the grey FFmpeg was for...
Many Thanks for such a great app. Go public someday??
ROSE...
SLOVEHEART is offline   Reply With Quote
Old 24th May 2010, 01:43   #8286  |  Link
KeVe1983
Banned
Hi jdobbs,
new problem.
Using BD Rebuilder 33.07.
Settings:
BD 25
2pass
HQ (Default)
Quicker Encode for Extras
Sound:
Main Movie: DTS HD
Extras: Ac3 Stereo
Disc: Terminator 2
BD RB Log:
[03:44:58] BD Rebuilder v0.33.07 (beta)
  - Source:  T2_FEATURES
  - Input BD size: 45,46 GB
  - Approximate total content: [05:52:35.216]
  - Target BD size: 22,66 GB
  - Windows Version: 6.1 [7600]
[03:44:58] PHASE ONE, Encoding
 - [03:44:58] Extracting A/V streams [VID_00226]
 - [03:45:03] Reencoding: VID_00226 (1 of 52)
 - [03:45:03] Reencoding secondary video [TRK_02]
 - [03:45:06] Collecting video information
   - Rate/Length: 23,976fps, 13 frames
 - [03:45:06] Reencoding: VID_00226, Pass 1 of 1
 - [03:45:08] Video Encode complete
 - [03:45:08] Reencoding audio tracks (if req'd)
 - [03:45:08] Multiplexing M2TS
 - [03:45:10] Extracting A/V streams [VID_00209]
 - [03:45:50] Reencoding: VID_00209 (2 of 52)
 - [03:45:50] Reencoding secondary video [TRK_02]
 - [03:45:53] Collecting video information
   - Rate/Length: 23,976fps, 431 frames
 - [03:45:53] Reencoding: VID_00209, Pass 1 of 1
 - [03:46:07] Video Encode complete
 - [03:46:07] Reencoding audio tracks (if req'd)
 - [03:46:07] Multiplexing M2TS
 - [03:46:11] Extracting A/V streams [VID_00216]
 - [03:46:50] Reencoding: VID_00216 (3 of 52)
 - [03:46:50] Reencoding secondary video [TRK_02]
 - [03:46:53] Collecting video information
   - Rate/Length: 23,976fps, 482 frames
 - [03:46:53] Reencoding: VID_00216, Pass 1 of 1
 - [03:47:09] Video Encode complete
 - [03:47:09] Reencoding audio tracks (if req'd)
 - [03:47:09] Multiplexing M2TS
 - [03:47:14] Extracting A/V streams [VID_00206]
 - [03:47:50] Reencoding: VID_00206 (4 of 52)
 - [03:47:50] Reencoding secondary video [TRK_02]
 - [03:47:53] Collecting video information
   - Rate/Length: 23,976fps, 613 frames
 - [03:47:53] Reencoding: VID_00206, Pass 1 of 1
 - [03:48:11] Video Encode complete
 - [03:48:11] Reencoding audio tracks (if req'd)
 - [03:48:11] Multiplexing M2TS
 - [03:48:14] Extracting A/V streams [VID_00214]
 - [03:49:05] Reencoding: VID_00214 (5 of 52)
 - [03:49:05] Reencoding secondary video [TRK_02]
 - [03:49:07] Collecting video information
   - Rate/Length: 23,976fps, 648 frames
 - [03:49:07] Reencoding: VID_00214, Pass 1 of 1
 - [03:49:28] Video Encode complete
 - [03:49:28] Reencoding audio tracks (if req'd)
 - [03:49:28] Multiplexing M2TS
 - [03:49:33] Extracting A/V streams [VID_00005]
 - [03:50:27] Reencoding: VID_00005 (6 of 52)
 - [03:50:27] Reencoding secondary video [TRK_02]
 - [03:50:33] Collecting video information
   - Rate/Length: 23,976fps, 610 frames
   - Bitrate: 12.172 Kbs
 - [03:50:33] Reencoding: VID_00005, Pass 1 of 2
 - [03:50:56] Reencoding: VID_00005, Pass 2 of 2
 - [03:52:05] Video Encode complete
 - [03:52:05] Reencoding audio tracks (if req'd)
 - [03:52:05] Multiplexing M2TS
 - [03:52:11] Extracting A/V streams [VID_00207]
 - [03:53:04] Reencoding: VID_00207 (7 of 52)
 - [03:53:04] Reencoding secondary video [TRK_02]
 - [03:53:13] Collecting video information
   - Rate/Length: 23,976fps, 764 frames
 - [03:53:13] Reencoding: VID_00207, Pass 1 of 1
 - [03:53:37] Video Encode complete
 - [03:53:37] Reencoding audio tracks (if req'd)
 - [03:53:37] Multiplexing M2TS
 - [03:53:47] Extracting A/V streams [VID_00211]
 - [03:54:41] Reencoding: VID_00211 (8 of 52)
 - [03:54:41] Reencoding secondary video [TRK_02]
 - [03:54:44] Collecting video information
   - Rate/Length: 23,976fps, 811 frames
 - [03:54:44] Reencoding: VID_00211, Pass 1 of 1
 - [03:55:05] Video Encode complete
 - [03:55:05] Reencoding audio tracks (if req'd)
 - [03:55:05] Multiplexing M2TS
 - [03:55:11] Extracting A/V streams [VID_00215]
 - [03:56:17] Reencoding: VID_00215 (9 of 52)
 - [03:56:17] Reencoding secondary video [TRK_02]
 - [03:56:33] Collecting video information
   - Rate/Length: 23,976fps, 871 frames
 - [03:56:33] Reencoding: VID_00215, Pass 1 of 1
 - [03:56:56] Video Encode complete
 - [03:56:56] Reencoding audio tracks (if req'd)
 - [03:56:56] Multiplexing M2TS
 - [03:57:02] Extracting A/V streams [VID_00027]
 - [03:58:16] Reencoding: VID_00027 (10 of 52)
 - [03:58:16] Reencoding secondary video [TRK_02]
 - [03:58:29] Collecting video information
   - Rate/Length: 23,976fps, 1.033 frames
   - Bitrate: 7.573 Kbs
 - [03:58:29] Reencoding: VID_00027, Pass 1 of 2
 - [03:59:56] Reencoding: VID_00027, Pass 2 of 2
 - [04:01:34] Video Encode complete
 - [04:01:34] Reencoding audio tracks (if req'd)
 - [04:01:34] Multiplexing M2TS
 - [04:01:40] Extracting A/V streams [VID_00212]
 - [04:02:50] Reencoding: VID_00212 (11 of 52)
 - [04:02:50] Reencoding secondary video [TRK_02]
 - [04:03:02] Collecting video information
   - Rate/Length: 23,976fps, 958 frames
 - [04:03:02] Reencoding: VID_00212, Pass 1 of 1
 - [04:03:28] Video Encode complete
 - [04:03:28] Reencoding audio tracks (if req'd)
 - [04:03:28] Multiplexing M2TS
 - [04:03:37] Extracting A/V streams [VID_00218]
 - [04:04:49] Reencoding: VID_00218 (12 of 52)
 - [04:04:49] Reencoding secondary video [TRK_02]
 - [04:05:06] Collecting video information
   - Rate/Length: 23,976fps, 972 frames
 - [04:05:06] Reencoding: VID_00218, Pass 1 of 1
 - [04:05:34] Video Encode complete
 - [04:05:34] Reencoding audio tracks (if req'd)
 - [04:05:34] Multiplexing M2TS
 - [04:05:39] Extracting A/V streams [VID_00025]
 - [04:06:59] Reencoding: VID_00025 (13 of 52)
 - [04:06:59] Reencoding secondary video [TRK_02]
 - [04:07:14] Collecting video information
   - Bitrate: 11.084 Kbs
 - [04:07:14] Reencoding: VID_00025, Pass 1 of 2
 - [04:07:46] Reencoding: VID_00025, Pass 2 of 2
 - [04:09:52] Video Encode complete
 - [04:09:52] Reencoding audio tracks (if req'd)
 - [04:09:52] Multiplexing M2TS
 - [04:10:01] Extracting A/V streams [VID_00136]
 - [04:11:13] Reencoding: VID_00136 (14 of 52)
 - [04:11:13] Collecting video information
   - Rate/Length: 29,970fps, 1.410 frames
 - [04:11:13] Reencoding: VID_00136, Pass 1 of 1
 - [04:12:41] Video Encode complete
 - [04:12:41] Reencoding audio tracks (if req'd)
 - [04:12:41] Multiplexing M2TS
 - [04:12:49] Extracting A/V streams [VID_00224]
 - [04:13:58] Reencoding: VID_00224 (15 of 52)
 - [04:13:58] Collecting video information
   - Rate/Length: 23,976fps, 220.728 frames
 - [04:13:58] Reencoding: VID_00224, Pass 1 of 1
 - [04:42:53] Video Encode complete
 - [04:42:54] Reencoding audio tracks (if req'd)
 - [04:42:54] Multiplexing M2TS
 - [04:43:04] Extracting A/V streams [VID_00159]
 - [04:44:15] Reencoding: VID_00159 (16 of 52)
 - [04:44:15] Collecting video information
   - Rate/Length: 23,976fps, 1.859 frames
 - [04:44:15] Reencoding: VID_00159, Pass 1 of 1
 - [04:45:50] Video Encode complete
 - [04:45:50] Reencoding audio tracks (if req'd)
 - [04:45:50] Multiplexing M2TS
 - [04:45:57] Extracting A/V streams [VID_00007]
 - [04:47:34] Reencoding: VID_00007 (17 of 52)
 - [04:47:34] Reencoding secondary video [TRK_02]
 - [04:47:59] Collecting video information
   - Rate/Length: 23,976fps, 1.147 frames
   - Bitrate: 11.591 Kbs
 - [04:47:59] Reencoding: VID_00007, Pass 1 of 2
 - [04:54:23] Reencoding: VID_00007, Pass 2 of 2
 - [04:56:56] Video Encode complete
 - [04:56:56] Reencoding audio tracks (if req'd)
 - [04:56:56] Multiplexing M2TS
 - [04:57:01] Extracting A/V streams [VID_00213]
 - [04:57:16] Reencoding: VID_00213 (18 of 52)
 - [04:57:16] Reencoding secondary video [TRK_02]
 - [04:57:28] Collecting video information
   - Rate/Length: 23,976fps, 1.248 frames
 - [04:57:29] Reencoding: VID_00213, Pass 1 of 1
 - [04:57:58] Video Encode complete
 - [04:57:58] Reencoding audio tracks (if req'd)
 - [04:57:58] Multiplexing M2TS
 - [04:58:02] Extracting A/V streams [VID_00210]
 - [04:58:15] Reencoding: VID_00210 (19 of 52)
 - [04:58:15] Reencoding secondary video [TRK_02]
 - [04:58:21] Collecting video information
   - Rate/Length: 23,976fps, 1.452 frames
 - [04:58:21] Reencoding: VID_00210, Pass 1 of 1
 - [04:58:57] Video Encode complete
 - [04:58:57] Reencoding audio tracks (if req'd)
 - [04:58:57] Multiplexing M2TS
 - [04:59:01] Extracting A/V streams [VID_00160]
 - [04:59:18] Reencoding: VID_00160 (20 of 52)
 - [04:59:18] Collecting video information
   - Rate/Length: 23,976fps, 2.411 frames
 - [04:59:18] Reencoding: VID_00160, Pass 1 of 1
 - [05:00:07] Video Encode complete
 - [05:00:07] Reencoding audio tracks (if req'd)
 - [05:00:07] Multiplexing M2TS
 - [05:00:10] Extracting A/V streams [VID_00021]
 - [05:00:31] Reencoding: VID_00021 (21 of 52)
 - [05:00:31] Reencoding secondary video [TRK_02]
 - [05:00:47] Collecting video information
   - Rate/Length: 23,976fps, 1.277 frames
   - Bitrate: 12.562 Kbs
 - [05:00:47] Reencoding: VID_00021, Pass 1 of 2
 - [05:01:26] Reencoding: VID_00021, Pass 2 of 2
 - [05:03:43] Video Encode complete
 - [05:03:43] Reencoding audio tracks (if req'd)
 - [05:03:43] Multiplexing M2TS
 - [05:03:47] Extracting A/V streams [VID_00161]
 - [05:04:05] Reencoding: VID_00161 (22 of 52)
 - [05:04:05] Collecting video information
   - Rate/Length: 23,976fps, 3.001 frames
 - [05:04:05] Reencoding: VID_00161, Pass 1 of 1
 - [05:05:12] Video Encode complete
 - [05:05:12] Reencoding audio tracks (if req'd)
 - [05:05:12] Multiplexing M2TS
 - [05:05:16] Extracting A/V streams [VID_00017]
 - [05:05:39] Reencoding: VID_00017 (23 of 52)
 - [05:05:39] Reencoding secondary video [TRK_02]
 - [05:05:58] Collecting video information
   - Rate/Length: 23,976fps, 2.015 frames
   - Bitrate: 11.081 Kbs
 - [05:05:58] Reencoding: VID_00017, Pass 1 of 2
 - [05:07:02] Reencoding: VID_00017, Pass 2 of 2
 - [05:10:32] Video Encode complete
 - [05:10:32] Reencoding audio tracks (if req'd)
 - [05:10:32] Multiplexing M2TS
 - [05:10:40] Extracting A/V streams [VID_00001]
 - [05:11:07] Reencoding: VID_00001 (24 of 52)
 - [05:11:07] Reencoding secondary video [TRK_02]
 - [05:11:27] Collecting video information
   - Rate/Length: 23,976fps, 2.056 frames
   - Bitrate: 11.801 Kbs
 - [05:11:27] Reencoding: VID_00001, Pass 1 of 2
 - [05:12:34] Reencoding: VID_00001, Pass 2 of 2
 - [05:16:09] Video Encode complete
 - [05:16:09] Reencoding audio tracks (if req'd)
 - [05:16:09] Multiplexing M2TS
 - [05:16:19] Extracting A/V streams [VID_00162]
 - [05:17:16] Reencoding: VID_00162 (25 of 52)
 - [05:17:16] Collecting video information
   - Rate/Length: 23,976fps, 3.529 frames
 - [05:17:16] Reencoding: VID_00162, Pass 1 of 1
 - [05:18:36] Video Encode complete
 - [05:18:36] Reencoding audio tracks (if req'd)
 - [05:18:36] Multiplexing M2TS
 - [05:18:41] Extracting A/V streams [VID_00019]
 - [05:19:05] Reencoding: VID_00019 (26 of 52)
 - [05:19:05] Reencoding secondary video [TRK_02]
 - [05:19:26] Collecting video information
   - Rate/Length: 23,976fps, 2.129 frames
   - Bitrate: 11.716 Kbs
 - [05:19:26] Reencoding: VID_00019, Pass 1 of 2
 - [05:20:37] Reencoding: VID_00019, Pass 2 of 2
 - [05:24:22] Video Encode complete
 - [05:24:22] Reencoding audio tracks (if req'd)
 - [05:24:22] Multiplexing M2TS
 - [05:24:31] Extracting A/V streams [VID_00012]
 - [05:24:57] Reencoding: VID_00012 (27 of 52)
 - [05:24:57] Reencoding secondary video [TRK_02]
 - [05:25:21] Collecting video information
   - Rate/Length: 23,976fps, 2.301 frames
   - Bitrate: 11.147 Kbs
 - [05:25:22] Reencoding: VID_00012, Pass 1 of 2
 - [05:26:41] Reencoding: VID_00012, Pass 2 of 2
 - [05:30:44] Video Encode complete
 - [05:30:44] Reencoding audio tracks (if req'd)
 - [05:30:44] Multiplexing M2TS
 - [05:31:02] Extracting A/V streams [VID_00010]
 - [05:31:35] Reencoding: VID_00010 (28 of 52)
 - [05:31:35] Reencoding secondary video [TRK_02]
 - [05:32:00] Collecting video information
   - Rate/Length: 23,976fps, 2.540 frames
   - Bitrate: 11.101 Kbs
 - [05:32:00] Reencoding: VID_00010, Pass 1 of 2
 - [05:33:59] Reencoding: VID_00010, Pass 2 of 2
 - [05:38:26] Video Encode complete
 - [05:38:26] Reencoding audio tracks (if req'd)
 - [05:38:26] Multiplexing M2TS
 - [05:38:45] Extracting A/V streams [VID_00011]
 - [05:39:27] Reencoding: VID_00011 (29 of 52)
 - [05:39:27] Reencoding secondary video [TRK_02]
 - [05:40:00] Collecting video information
   - Rate/Length: 23,976fps, 2.683 frames
   - Bitrate: 11.154 Kbs
 - [05:40:00] Reencoding: VID_00011, Pass 1 of 2
 - [05:42:02] Reencoding: VID_00011, Pass 2 of 2
 - [05:46:44] Video Encode complete
 - [05:46:45] Reencoding audio tracks (if req'd)
 - [05:46:45] Multiplexing M2TS
 - [05:47:05] Extracting A/V streams [VID_00220]
 - [05:48:05] Reencoding: VID_00220 (30 of 52)
 - [05:48:05] Reencoding secondary video [TRK_02]
 - [05:48:36] Collecting video information
   - Rate/Length: 23,976fps, 2.776 frames
 - [05:48:36] Reencoding: VID_00220, Pass 1 of 1
 - [05:51:16] Video Encode complete
 - [05:51:16] Reencoding audio tracks (if req'd)
 - [05:51:16] Multiplexing M2TS
 - [05:51:35] Extracting A/V streams [VID_00002]
 - [05:52:22] Reencoding: VID_00002 (31 of 52)
 - [05:52:22] Reencoding secondary video [TRK_02]
 - [05:53:02] Collecting video information
   - Rate/Length: 23,976fps, 2.928 frames
   - Bitrate: 12.096 Kbs
 - [05:53:02] Reencoding: VID_00002, Pass 1 of 2
 - [05:55:41] Reencoding: VID_00002, Pass 2 of 2
 - [06:00:20] Video Encode complete
 - [06:00:20] Reencoding audio tracks (if req'd)
 - [06:00:20] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00002.meta
Muxing took 3 seconds
[06:00:20] - Failed to build structure, aborted
KeVe1983 is offline   Reply With Quote
Old 24th May 2010, 01:50   #8287  |  Link
DK
DK's Avatar
or
Was it burned properly (e.g. UDF 2.50)?
Old 24th May 2010, 03:14   #8288  |  Link
eTiMaGo
Originally Posted by PeteWalker74 View Post
Gran Torino out of sync issue at Chapter 18. The backup of the original Blu-Ray doesn't exhibit this issue. It goes to a sky-blue screen, before the chapter starts, throwing the audio out of sync.
Experiencing the same problem with Alvin & the Chipmunks 2, Asian release. It flickers a still image from a random scene when you start playing, then it's way out of sync after that.
Tried re-ripping it, on two computers, even. Exact same issue. Gonna try ripping with DVDFab next, since it might also just be an AnyDVD glitch...
eTiMaGo is offline   Reply With Quote
Old 24th May 2010, 05:35   #8289  |  Link
humphammer
Sorry for the incorrect info, you designed the program so you should know....of the 8 movies I have backed up the only one I didn't run the patcher on would not play on my ps3, it had nothing but a black screen although the log showed no errors on the encode. The other seven played perfectly, so that was the reasoning behind my post.
Old 24th May 2010, 06:04   #8290  |  Link
saphire199
I believe so. I burned with Imgburn, I have it set to UDF for blu-ray, even tho Imgburn checks this automatically.
Old 24th May 2010, 12:55   #8291  |  Link
lastangel
I try many BD (avatar, Toto Live, LOTR ecc)
when i use setting with compress hd audio or ac3 audio, tsmux not work
Demux ok
Compresson video ok
Compresson audio ok
but on remux go to 100% and not mux
why?
can you help me?sorry for me english i'm italian
lastangel is offline   Reply With Quote
Old 24th May 2010, 12:58   #8292  |  Link
datman
don't know if this has been mentioned. The 2 encodes (batch) I did with 33.07 I checked shut down at the end and both restarted the computer instead of shutting down.
I will post logs if needed but they are on another computer.
datman is offline   Reply With Quote
Old 24th May 2010, 14:17   #8293  |  Link
BD Rebuilder v0.33.09 (beta)
I have updated the link in the first post of this thread with a new version of BD-RB (v0.33.09). Changes for this release are:
- Corrected an error in v0.33.07 in which interlaced
  sources might mistakenly use FFMS.
- Corrected a "PredictandEncode() 00058 2809" error that
  could occur in features that consist of a large number
  of combined M2TS files following a stop/restart. This
  error was introduced in v0.33.07.
- Corrected an issue in which the status percentage and
  bar may incorrectly reflect completion status.
- Corrected a demuxing failure caused by long filenames
  that could occur during and ALTERNATE movie-only rebuild
  on some sources with a large number of combined M2TS
  files.
- Corrected an error in which "SHUTDOWN after Rebuild" no
  longer worked correctly in v0.33.07.
- Updated the FFMS selection routine so that it would
  include movie-only encodes when appropriate.  It seems
  the seamlessly branching titles might cause "stutter"
  in that case as well.
- Changed the way FFMS is used to prevent short flashes
  and out-of-sync audio on certain sources.
- Updated the included version of X264.EXE to the
  latest release (r1602).
Old 24th May 2010, 15:16   #8294  |  Link
raul124
raul124's Avatar
Jdobbs what happen with v0.33.08?
raul124 is offline   Reply With Quote
Old 24th May 2010, 16:57   #8295  |  Link
SUPERSONIC74
I am trying to back up the da vinci code which has a secondary video track for PIP commentary which I believe has it own audio track listed on the stream as "AUD_003(2nd)DTS-express,stereo,english" but I cant highlight to encode which I can for other tracks and subtitles if i want them added. Any ideas or am I doing something wrong?
Thanks in advance
SUPERSONIC74 is offline   Reply With Quote
Old 24th May 2010, 18:18   #8296  |  Link
Aratar
we can't remux dts express properly as the tool (tsmuxer) used for building m2ts files does not support them.
Aratar is offline   Reply With Quote
Old 24th May 2010, 18:49   #8297  |  Link
SUPERSONIC74
Is there likely to be a fix for dts express?
Old 24th May 2010, 19:30   #8298  |  Link
Thanks in advance
Use the search button. DTS Express is not currently supported.
Old 24th May 2010, 19:31   #8299  |  Link
v0.33.08 was and internal test version.
Old 24th May 2010, 19:33   #8300  |  Link
It is a limitation of TSMUXER. So probably not unless it is updated or another freeware M2TS muxer comes along. I believe the Sourceforge team is working on one.
