16th December 2018, 21:12 | #6642 | Link |
2899 [Settings] fixed worker settings window when using High DPI (regression of 2884) 2898 [Main] fixed OneClick audio/video profile selections overwriting the main tab profile selections at next restart 2897 [DGIndexNV Indexer] adjusted AVS script parameters (requires DGIndexNV 2053.163+) mod2 is forced for crop values (was mod4 before) added a check to ensure that the full path information is written into the dgi file |
18th December 2018, 20:05 | #6644 | Link |
Thanks for the help. I found out how to set the job priority.
In settings.xml for different job there is a tag <Priority>. For Video mine was set to IDLE. Now I changed it to my preferences. ========================================== Is there a way to see advanced options for x265 encoder like the ones for x264? |
18th December 2018, 20:21 | #6645 | Link |
To early to happy. Today Indexing with MeGUI gave me the following dgi result:
DGAVCIndexFileNV21 DGIndexNV 2053.0.0.164 X64 D:\Sonstiges\Videotools\MeGUI\tools\dgindexnv\ D:\Temp\BluRay\PI\BDMV\PLAYLIST\00001.mpls 19026911232 ..\STREAM\00007.m2ts 12288 This is interesting, because I have never seen the mpls source in the file. Correcting ..\STREAM\00007.m2ts 12288 only to D:\Temp\BluRay\PI\BDMV\STREAM\00007.m2ts 12288 makes MeGUI crash when loading the file. So... corrected both to the m2ts sourcefile and it's working. Last edited by Morku; 18th December 2018 at 20:24. |
20th December 2018, 15:49 | #6647 | Link | |
Sent from my LG-M700 using Tapatalk |
20th December 2018, 16:25 | #6648 | Link |
DVD playable format? Valid formats for a DVD Video disc (e.g. MPEG-2 video, Dolby Digital audio) were already specified decades ago. And MeGUI does not produce a DVD Video disc anyway. You are either completely wrong or did not explain correctly what you mean.
20th December 2018, 16:27 | #6649 | Link | |
20th December 2018, 17:23 | #6650 | Link |
Unreasonable User
MPEG2 has licensing requirements that go beyond h.264/h.265. Also, I don't know of any good freeware MPEG2 encoders other than HCenc (likely for the same reason). They stopped working on x262 back in 2015.
21st December 2018, 14:45 | #6651 | Link |
If you want to make a DVD Video disc, MeGUI will not be the tool of choice, it was never supposed to be. DVD specifications are quite strict. You will need a DVD Authoring tool, along with good encoders. You may have to study for a while to learn how to do that optimally.
22nd December 2018, 06:02 | #6652 | Link | |
22nd December 2018, 08:59 | #6653 | Link |
You just ignored the link to a wide software selection in my previous post? ... If you insist in still producing inferior media, with the risk of video norm issues, try e.g. DVD Flick or ConvertXtoDVD (what a name of a tool, already suggesting that it might match your needs).
But why still all the hassle? Get a tiny HTPC or even a "Media Harddisk" instead (like WD-TV, or newer models), or a network stick like Google ChromeCast - put it into a HDMI port of your TV and stream videos from your PC via WLAN. Many "smart" TV sets even play directly from an attached USB drive, with an own internal media player. I don't know if you can afford one of these solutions, but it's more sustainable than burning DVDs nowadays. |
22nd December 2018, 09:51 | #6654 | Link |
IMO the DVD format still has its merits, and due to the sheer number of devices which support DVD playback the format will not disappear any time soon. If you intend to share your conversions with others, using the DVD format is still a good idea.
Another advantage of DVDs is good freeware support for creating nice looking menus. For the modern AVC and HEVC formats you need to spend big bucks and a lot of time for learning how to author BD menus. The big flaw of the DVD format today is that only SD frame sizes are supported (720x576 and 720x480). IF you want HD then DVD is not for you. I recommend three different free software solutions for creating DVDs. DVDFlick2 is the easiest to learn, limited features, but it does produce menus and the quality is very acceptable. AVStoDVD and DVDStyler are the other two. Both have similar features. AVStoDVD is a little bit limited for menu creation (but powerful enough for most users). Its main strength is using high quality tools like HCenc and Muxman. And if offers high quality procedures for users who need to convert things from PAL to NTSC or vice versa, it handles soft pulldown and much much more. DVDStyler has a lot less transcoding features (it can only use FFmpeg for transcoding), but it offers very powerful menu creation tools. If your main goal is to create elaborate menus then this is the software you need. I suggest you check out all three of them, it will cost you nothing except some time... Cheers manolito Last edited by manolito; 22nd December 2018 at 09:54. |
24th December 2018, 21:54 | #6659 | Link |
Hi, I'm using MeGUI 2900 x64 DEVELOPMENT UPDATE SERVER
Since the previous update, I'm having this problem: In One Click Encoder, when I want to edit an AviSynth profile (for example the one in the image, COLOR EDIT) I click on "Config" and it doesn't directly allow me to edit, I have to choose it again from the presets list, this didn't happen a couple of updates ago. |
