15th August 2019, 20:08 | #3501 | Link |
Professional Code Monkey
R47.2 released. You should definitely update if you use a previous R47 version since it fixes the merge bug introduced when converting everything to intrinsics.
22nd August 2019, 22:13 | #3502 | Link | |
I only have one user on my PC and when I installed Python I selected install for all users. What am I doing wrong? |
23rd August 2019, 19:10 | #3503 | Link | |
Do you have any registry entries in HKEY_LOCAL_MACHINE\SOFTWARE\Python\PythonCore\3.7?
23rd August 2019, 21:04 | #3505 | Link |
Then you've most likely installed python only for the current user...
25th August 2019, 10:30 | #3508 | Link | |
Typically: C:\Program Files\VapourSynth\core AND C:\Program Files\Python37\Lib\site-packages Go test this so it can be included in the next official release. And test the MVToolz optimizations too.
26th August 2019, 21:34 | #3510 | Link |
It's not included in the installer so maybe you don't have it...
27th August 2019, 10:19 | #3512 | Link | |
Tested like this PS D:\> vspipe.exe -p -e 5000 D:\del.vpy . on a Ryzen 2600, 16GB ram, DVD 720x480 clip Vinverse seems to consist only of Expr+MakeDiff and therefore has the biggest speedup of ~22% https://github.com/HomeOfVapourSynth...sfunc.py#L2375 Code:
import havsfunc as haf clip=haf.DeHalo_alpha(clip) clip=haf.FineDehalo(clip) # new build Output 5001 frames in 16.87 seconds (296.39 fps) Output 5001 frames in 16.73 seconds (298.98 fps) Output 5001 frames in 16.84 seconds (296.98 fps) # old build Output 5001 frames in 17.04 seconds (293.43 fps) Output 5001 frames in 17.07 seconds (292.99 fps) Output 5001 frames in 17.04 seconds (293.51 fps) clip=haf.srestore(clip) # new build Output 5001 frames in 35.41 seconds (141.24 fps) Output 5001 frames in 35.12 seconds (142.42 fps) Output 5001 frames in 35.74 seconds (139.94 fps) # old build Output 5001 frames in 35.20 seconds (142.07 fps) Output 5001 frames in 35.24 seconds (141.91 fps) Output 5001 frames in 35.09 seconds (142.53 fps) clip=haf.SmoothLevels(clip) # new build Output 5001 frames in 10.41 seconds (480.28 fps) Output 5001 frames in 10.34 seconds (483.86 fps) Output 5001 frames in 10.33 seconds (484.30 fps) # old build Output 5001 frames in 10.66 seconds (469.29 fps) Output 5001 frames in 10.64 seconds (469.96 fps) Output 5001 frames in 10.66 seconds (468.97 fps) clip=haf.Vinverse2(clip) # new build Output 5001 frames in 5.12 seconds (977.57 fps) Output 5001 frames in 5.17 seconds (967.26 fps) Output 5001 frames in 5.13 seconds (974.39 fps) # old build Output 5001 frames in 5.85 seconds (855.08 fps) Output 5001 frames in 5.86 seconds (853.31 fps) Output 5001 frames in 5.86 seconds (853.19 fps)
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 27th August 2019 at 10:25. |
27th August 2019, 17:13 | #3513 | Link |
I have notice a new problem with Python 3.7.4 installer that's affecting vs installer. When I'm doing a clean install, if I choose "install now" in python installer, the default installation path would be something like "users\username\appdata\roaming\...", and the default installation path for the vs installer would be "users\username\appdata\local\programs\vapoursynth". But if I choose "custom installation" in python installer, its installation path would be changed to "c:\program files\python37", and the vs installer would also be changed to "c:\program files\vapoursynth".
31st August 2019, 17:52 | #3515 | Link |
Not that I know of. Avisynth compatiblity should work though.
6th September 2019, 20:17 | #3518 | Link | |
Changing the vsscript api to match the style of the rest of vs so importing it becomes trivial is on my todo list and will fix it. Some day.
10th September 2019, 18:53 | #3520 | Link | |
unsigned int
Buy me a "coffee" and/or hire me to write code! |
