Old 11th January 2021, 20:34   #4141  |  Link
ChaosKing
R52 needs Python 3.8 on windows.
Old 11th January 2021, 22:22   #4142  |  Link
Soliloquy
that did it, thanks man!
Soliloquy is offline   Reply With Quote
Old 15th January 2021, 17:54   #4143  |  Link
unix
Is there a direct VapourSynth support for x264?
unix is offline   Reply With Quote
Old 15th January 2021, 21:19   #4144  |  Link
DJATOM
DJATOM's Avatar
If you can apply patch and compile, my patch is here.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 16th January 2021, 07:17   #4145  |  Link
unix
I think I will stuck with ffmpeg because I'm not familiar with compile x264 ^^"
anyways I found a topic and I think it could help me https://forum.doom9.org/showthread.php?t=148615
Thank you
Old 16th January 2021, 15:21   #4146  |  Link
feisty2
I'm Siri
feisty2's Avatar
@Myrsloik
what are some of the other things I need to do to make my project the preferred C++ wrapper for VS over vsxx?
feisty2 is offline   Reply With Quote
Old 17th January 2021, 13:30   #4147  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by feisty2 View Post
@Myrsloik
Find 3 people who prefer it I guess? I don't use either so I have no opinion about which one is better...
Old 17th January 2021, 16:21   #4148  |  Link
videoh
Useful n00b
We don't need no steenkin' wrappers. Imagine having a bug in your filter and having to go to feisty2 for support.
Old 17th January 2021, 17:03   #4149  |  Link
stax76
stax76's Avatar
But it's pythonic and C++20, don't you like it?
Old 17th January 2021, 17:42   #4150  |  Link
videoh
Useful n00b
I'm sure it's wonderful and great for noobs.
Old 17th January 2021, 18:59   #4151  |  Link
StainlessS
StainlessS's Avatar
I'm sure that its lovely Feisty, Myrsloik and VideoH are just being, well themselves really
I sometimes post sober.
Old 17th January 2021, 19:34   #4152  |  Link
feisty2
I'm Siri
feisty2's Avatar
that is simply not true. the source code is publicly available and extremely easy to understand. anyone reasonably familiar with the C++ language should be able to manipulate the wrapper (adding more functionality, fixing bugs, etc.) however he or she wants with zero difficulty.
Old 17th January 2021, 19:53   #4153  |  Link
videoh
Useful n00b
Where is the documentation for the wrapper?
Visual Studio solution files for building the examples?
Old 17th January 2021, 20:15   #4154  |  Link
feisty2
I'm Siri
feisty2's Avatar
also not true. the wrapper covers all functions provided by the C API, so anything you can do with the low level API, you can do the same with the C++ wrapper, plus the much cleaner and more concise syntax while also being less error prone. there is no performance cost (as long as you choose not to enable some dynamic features like automatic padding which are meant for fast prototyping), everything is built upon zero cost abstraction. even experienced developers should enjoy some benefits like RAII and expect less memory errors.
someone must be a masochist to prefer
auto std = vsapi->getPluginByNs("std", core);
auto args = vsapi->createMap();
vsapi->propSetNode(args, "clip", node, paAppend);
vsapi->freeNode(node);
auto ret = vsapi->invoke(std, "Transpose", args);
vsapi->freeMap(args);
node = vsapi->propGetNode(ret, "clip", 0, nullptr);
vsapi->freeMap(ret);
over
auto TransposedClip = Core["std"]["Transpose"]("clip", InputClip);
Old 17th January 2021, 20:54   #4155  |  Link
feisty2
I'm Siri
feisty2's Avatar
I haven't started working on documentation and I'll get started once all interface design is finalized. I have covered all functions in the C API but the filter backbone is still subject to change.
for now, you can find various examples here: https://github.com/IFeelBloated/vsFi...aster/Examples
GaussBlur - simple 3x3 convolutional filter
TemporalMedian - a temporal filter
Rec601ToRGB - an example showing how to write filters that manipulate frame properties, and output a video clip of a different format than its input
Crop - an example showing how to write filters that deal with various bitdepths, and output a video clip with a different image size
ModifyFrame - an example showing how to write filters that interact with Python scripts.
Palette - an example showing how to write filters with multiple outputs
SeparableConvolution - an example showing how to write filters that invoke external filters and itself
GaussBlurFast - an example showing how to write filters without automatic padding.
msvc is not currently supported, because it lacks many core language features of C++20 (mainly concepts). you need at least GCC 10.2 to compile the examples
Old 17th January 2021, 21:47   #4156  |  Link
videoh
Useful n00b
It's undocumented and I can't build with it or debug it in my development environment. I'm such a masochist for not using it.
Old 20th January 2021, 00:21   #4157  |  Link
sl1pkn07
Pajas Mentales...
@videoh. is a joke?
maybe is your problem(?)
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 20th January 2021, 03:05   #4158  |  Link
videoh
Useful n00b
Because Visual Studio on Windows has such a tiny usage. I'm the only one that would be stupid enough to have such an environment.
Hey, he called me a masochist for not using his stuff. How about you mind your own business? Or how about you ask him to create some documentation, for God's sake?
The only joke here is the never-DG guys continually twisting themselves into pretzels. Pitiful.
Old 20th January 2021, 07:48   #4159  |  Link
feisty2
I'm Siri
feisty2's Avatar
it's nobody's problem, msvc is well known to be slow on supporting new C++ features (it's also not the worst tho, apple clang is far worse than msvc in terms of C++20 support). things will get there eventually. the main problem with msvc currently is that it does not provide complete support for concepts, a major C++20 feature that the wrapper relies on heavily.
and the masochist thing is not personal, using the low level API not only requires more work to do the same thing, it is also very error prone in certain cases, especially when dealing with reference counted objects. you won't believe how easy and how likely it is to forget calling that "free" function marked in red in the following code block
vsapi->freeNode(node); // manually releasing resource acquired in a foreign scope, highly error prone.
and bang! there you have a memory leak. and that's what I meant by "masochist", to rely on the not always so consciously stable human willpower to deal with all that when you have the option to let a language facility do it automatically for you.
Old 20th January 2021, 12:45   #4160  |  Link
videoh
Useful n00b
I don't have that option, and I can't wait for eventually.
And do yourself a favor and write some documentation. Examples are not enough.
speed, vaporware, vapoursynth
