18th December 2018, 11:57 | #16481 | Link | |
18th December 2018, 13:31 | #16482 | Link | |
Power bill is heavy. Wife complains. So as Atak just posted, I understand what you're thinking and trying to do. There is a big difference between remuxing and re-encoding. If you just want to get the 4K movie off the disc and onto your computer, then use MakeMKV and it will take the film and place it into a MKV file at it's original quality and size from the 4K disc. Average size of your file will be between 45-100GB in size. Should take about an hour or so per disc to do and then you are done. All the original subtitles will be there as well. Now if you want to make changes to said video, making it smaller, degraining, etc. then you will need to re-encode. This is what RB is for. It takes time to extract each component to set it up for how RB processes it (Handbrake skips this step, but it also can not do DE). After that, its encoding time. So for me it is 1-3 movies per day, depending on if I'm using MDegrain or not. If the file size is not right (for me) then I tweak its settings (MDegrain) and back it goes for encoding. I like to shoot for the movie to be 1/3 to 1/4 of it's original size. So about 15-25GB depending on length. Depending on grain, I might have to redo the encode 2-3 times. So a single movie, might take 1-4 days to get done. Since time seems really important to you, just use MakeMKV and keep the original movie. Get a couple of 10GB drives and store your movies natively. |
18th December 2018, 13:56 | #16483 | Link | |
I have helped you with a lot of problem solving with your program, over the past couple of years, to help get it better, and I'm happy that I was able to help. I have told you many times that this IS way over my head, and sometimes you expect "us" to be able to read your mind, when it comes to feedback of problems, and where & what to look for. I have had NO IT training at all. Having said that, in my experience, RB does an awesome job with anything up and including 1080, x264. And it's probably clearly the fastest x265 encoder around, mainly due to the DE function. My suggestions of building a simple remuxing tool, that also offers some filtering, denoising, & DE, would be very welcome, as most 4K movies probably don't require encoding, and I'm not too interested in reducing file size. So there's an opportunity for you to create another great program. You're right, I probably shouldn't be here, so I will disappear. I won't stop using RB. |
18th December 2018, 14:01 | #16484 | Link |
Exactly ... Storage with traditional HDs is so cheap these days..... If remiuxing is faster on a SSD, one could take this intermediate step and pull everything in one peace over to the HD.. Much cheaper on the bill and a lot quicker than re-encoding...
If Size/Quality Ratio is not that big of a concern - one could easily buy a recent GPU oder CPU with hardware encoding and be very quick with very good results. My 50 Euro Pentium (Kaby Lake) was able to do 1080p in H265 10 Bit in "faster than realtime" with no sweat... and Q20 gave results for a normal Movie (with not too much grain in it) at max 6mbit or so.... All my quicksync encodes look very good with about 50% to 100% more Bitrate thrown at them than x265 - and are done much faster.. Of course, If one wants to squeeze out the best quality per bitrate possible - you have to filter, use X265 instead of hardware, take slow settings, wait, twak, CU-losless your brains out, etc.. I really enjoy optmizing things, but thats more of a question of "whats important to me - time? Quality? Having a Hobby? Learning the secrets of encdoing? go to avisynth college...?? But it all comes down to the basics - understanding the difference between re-muxing and re-encoding - I agree on that |
18th December 2018, 14:48 | #16485 | Link | ||
RB has this one wonderfull feature of Distributed encoding - which is probably unique... (Iīve seen Mediaencoder having some network settings.. never got it to work). This way your file can be split up into many small parts - and every PC in your network can contribute encoding.. Thatīs the speed advantage.... Of course, RB does some muxing, indexing, etc... This is helpful and necessary to keep everything together and in sync... Handbrake (for exmaple) can deal with a videofile without that many "pre-steps", because it simply starts at the beginnig (but take a look at staxrip, wich demuxes also). Handbrake does subtitle scanning which can take a while, too.. But all this time (preparing before encoding) is "next to nothing" compared to the encoding time itself when using x265 in 4k and high quality settings (if you filter, it gets even worse)... Quote:
Filtering, Denoising (which is filtering).... requires re-encoding.. There is NO WAY to simply remux and have a filter applied.... So your suggestion is impossible (not because no one wants to try, it really is impossible!). |
18th December 2018, 15:21 | #16486 | Link | ||
remuxing & re-encoding are two different things
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
19th December 2018, 08:59 | #16488 | Link |
Silent Reader
Only a remark how good or bad is --opencl in x264:
I am encoding in DE mode. Two Ryzen 2700X with RX550 and DDR4-3200 using placebo preset... With opencl enabled for RX550 I get around 13 fps alltogether, but cpu-utilization is around 45%, when opencl is disabled cpu-utilization increases to 100%, but encoding fps only increases to 19 fps. (this means higher wattage for CPU but lower demands for GPU) With opencl enabled and using two encodingservers per Client cpu-utilization stays at around 45%, no increase of encoding fps. (so opencl at RX550 seems to be the bottleneck, I am curious that opencl at RX550 seems to be slower than without on Ryzen 2700X) Is there a possible option to enable x264 opencl for the first encodingserver per client and disable for the second one? Last edited by Wishbringer; 19th December 2018 at 09:34. |
19th December 2018, 11:04 | #16489 | Link | ||
UPDATE: Have tried adding incorrect device id to disable opencl acceleration? /x264-opencl-device-id 9
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th December 2018 at 11:34. |
19th December 2018, 14:04 | #16491 | Link | |
You also have to understand, Atak may be a bit short sometimes. He may feel sometimes that some are ungrateful with all of his hard work. (I'm very grateful for RB!) And he just gets exasperated. He has a life too outside of RB and who knows how much stress is involved in that. And on top of all of this, he develops RB for FREE and on his own time. We have to be more grateful for everything he has done. So in the end, we can post bugs that we find, and hope that Atak can fix them. But if he can't, and a work around exists, then we should just live with it. Just look at how much more RB does year after year. 4K support just got added around this time last year. Amazing stuff. Thank you Atak for such an amazing problem and your awesome support. |
19th December 2018, 21:47 | #16494 | Link | |
Silent Reader
So your suggestion works. That x264 task from 2nd encodingserver has 0% GPU usage. Thanks! now the weird ones: with one encodingserver using opencl and one encodingserver not using opencl I got per client 100% CPU usage an 2% GPU usage (GPU usage is unexpected low!) with both encodingservers using opencl per client I got again around 45% CPU usage and 40-60% GPU usage (again unexpected low, expected 100%) But the difference in GPU usage between one and two servers is remarkable, and curious. HDD usage can't be the reason: using 1TB 970 Evo M.2 NVMe with around 3.5 GB/Sek reading and 2 GB/Sek writing. RAM is 64GB DDR4-3200-16-16-18-38 Network is 1GBit per client over HPE 1920S-48 switch (at moment only 3 pcs on it) the only result I got like expected : Both encodingservers without opencl gave 100% CPU and 0% GPU usage. Last edited by Wishbringer; 20th December 2018 at 14:33. |
20th December 2018, 15:12 | #16495 | Link |
Updates Not Working
Atak, not sure if you were aware that updates are not working right now:
2018-12-20 06:46:42 : =========================[UPDATER ACTIVATED]========================= 2018-12-20 06:46:42 : Looking for correct UUID link in http://atak-snajpera.5v.pl/ 2018-12-20 06:46:43 : [SUCCESS] http://atak-snajpera.5v.pl/ has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0 2018-12-20 06:46:43 : Downloading update file http://atak-snajpera.5v.pl/ripbot264update/update.zip 2018-12-20 06:46:43 : [ERROR] Unable to download update file http://atak-snajpera.5v.pl/ripbot264update/update.zip 2018-12-20 06:46:43 : Searching for UUID link with DuckDuckGo... 2018-12-20 06:46:44 : Search results... 2018-12-20 06:46:44 : http://atak-snajpera.5v.pl 2018-12-20 06:46:44 : Looking for correct UUID link in http://atak-snajpera.5v.pl 2018-12-20 06:46:44 : [SUCCESS] http://atak-snajpera.5v.pl has correct UUID link 6c966b28-e0dd-48f6-b1c7-a56e8a275ec0 2018-12-20 06:46:44 : [ERROR] Unable to download update file http://atak-snajpera.5v.pl/ripbot264update/update.zip 2018-12-20 06:46:44 : No results. I was hoping for an update to fix the OpenCLInfo hang problem. |
20th December 2018, 15:28 | #16496 | Link | |
21st December 2018, 12:00 | #16497 | Link | |
Or to what have changed from those two versions? Saw a post about v1.20.0 was the last 32-bit version and v1.21.0 beeing 64-bit or something, but can't find that post nomore. Dunno if this would change anything(?) |
21st December 2018, 19:21 | #16499 | Link |
Update on my own issue:
Decided to downgrade to 1.20.0 and disable the updater. This turned out to be a great idea! The bug with the subs is gone and even better is, I now get 40 FPS encodes up form 13.5 - 15 FPS. Whatever the diffrences is on the versions above 1.20.0 there seems to be some huge changes. As I don't care for H265/4K stuff I don't know if there's a boost to this encode form - which some have been complaining about taking too long. Try downgrading and see if that changes things for you guys aswell. Anyways... Good luck! Gryph |
