Old 3rd May 2015, 16:39   #721  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for version 10.4.0
* Accept relative paths for the output file
* Do a second crop detection run in case the first try fails
Old 23rd June 2015, 22:08   #722  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 10.4.1
* Modified the mail func for dir batch encodes to report the input directory instead of the last encoded file from it
* Get rid of some commented out code which is no longer used
* The -a52drc option only has an effect if input audio is AC-3. Since we currently don't store the audio codec detected into a usable var, disable this option for the time being.
* Increased the detault audio bitrate for AAC from 128 to 192kbps
Old 6th September 2015, 03:37   #723  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 10.4.2
* Increased the default audio bitrate/quality value for Vorbis audio
* Added mov file extention to the supported formats for chapter dumps
* New ASCII art banner
* Updated the man page
Old 8th September 2015, 17:43   #724  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 10.4.3
* Removed the $ from the index of array variables
* Be more portable and use eval instead of seq in loops as seq is too Linux-specific
Old 10th September 2015, 14:23   #725  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 10.4.4
* Portability improvements. It should now work on other UNIXes
Old 14th September 2015, 17:52   #726  |  Link
microchip8
microchip8's Avatar
ChangeLog for 10.4.5
* Fixed a small issue in the detection of aspect ratio when forcing it
Old 21st September 2015, 13:19   #727  |  Link
microchip8
microchip8's Avatar
ChangeLog for 10.4.6
* Clean up the config file a bit
* Added support for setting the MAX_AMOUNT_SUBS and MAX_AMOUNT_AUD_TRACKS to "auto". When set to "auto" it will ask for as many audio tracks/subs as detected
* New variable in the config file, MAX_AMOUNT_EXT_SUBS, for setting the amount of times we get asked for importing external subs into mkv/mp4/ogm
Old 19th January 2016, 20:23   #728  |  Link
microchip8
microchip8's Avatar
ChangeLog for version 10.4.7
* Added support for the video rotate filter. Requested by Thomas Troeger
* Updated copyright dates
h264enc, ipod, mencoder, ps3, xbox360
