Old 31st December 2016, 08:27   #41781  |  Link
Originally Posted by Patrik G View Post
NGU goes overboard and crash and burns
Correction, produces coil whine
but maybe its hard to see on a LCD/OLED tv with only 300 lines of motion resolution lol
Or a 1024x768 or whatever plasma.. :P
for plasma users NGU looks crap
i get the same effect if i bump up sharpness +20.
Hello to flickering chainsaw edges and morie patterns all over the image.
YMMV I guess.. I had a good laugh from this though.
NNEDI3 produces an accurate and natural image NGU does not.
Not entirely true, madshi developed this using various ground truths, in many cases this would produce a natural and accurate image. In saying that I doubt I'll use it any time soon.
and one tip: use a proper tv to evaluate your scaling algorithms
100% agree. A blind dog can't lead a blind man.
Old 31st December 2016, 11:09   #41782  |  Link
Mistery 73
greetings to all ..
is there a way to mask the image in the top of the screen side with madVR?
leaving the top fixed without scale the image?
Mistery 73 is offline   Reply With Quote
Old 31st December 2016, 11:26   #41783  |  Link
Cinemancave
How should I configure madvr/lav in order to perform HDR-->SDR conversion and leaving BT.2020 untouched?
I have a JVC projector and a popular method of watching UHD is to let Panasonic UB700/900 do HDR-->SDR conversion with BT.2020 passthrough with the help of the HD fury/integral. I am basically interested in doing the same thing with Madvr since I now have HDR content on my HTPC. I am thinking this should be possible?
Cinemancave is offline   Reply With Quote
Old 31st December 2016, 11:32   #41784  |  Link
Just set your display device in madVR to be native BT.2020 ("is already calibrated to bt.2020" on the device page), then it should leave it alone.
Old 31st December 2016, 13:35   #41785  |  Link
Cinemancave
Ok sounds good
When MadVR is set to "is already calibrated to bt.2020" and it receives rec709, I assume that it leaves it untouched and doesn't try to expand the gamut? I am looking for a "set it and forget it"-setting and only adjust the color gamut in the projector depending on content.
Old 31st December 2016, 19:46   #41786  |  Link
bcec
NGU goes overboard and crash and burns why do you want to compare it?
Back to the drawing table madshi
I haven't been following up NGU very closely recently, but last I remember everyone was raving about it. Samples looked great with it. Did people's opinions on it change?
bcec is offline   Reply With Quote
Old 31st December 2016, 19:52   #41787  |  Link
Asmodian
No, it is just that Patrik didn't like it. You can never please everyone.
madVR options explained
Old 31st December 2016, 20:03   #41788  |  Link
Oguignant
Oguignant's Avatar
At 60Hz it does, but the majority of people don't have a 4K TV yet (like the person who asked above, the model he listed is FullHD)
4k 60mhz 4.4.4 exceeds 18Gbps bandwidths? Are you sure?
I use it but change automatically to 23/24 mhz when the movie is 23.976 fps...
Always with uhd deep color enabled. Using in 60 mhz or 23/24 mhz noticed that it looks bad or choppy.
"To infinity, and beyond!"
Oguignant is offline   Reply With Quote
Old 31st December 2016, 20:05   #41789  |  Link
Oguignant
Oguignant's Avatar
For my NGU does a good job. Much faster than neddi.
Old 31st December 2016, 20:13   #41790  |  Link
sneaker_ger
For >=10 bit and if you add the overhead: yes.
Old 31st December 2016, 20:14   #41791  |  Link
Oguignant
Oguignant's Avatar
If you add the overhead: yes.
Old 31st December 2016, 20:19   #41792  |  Link
Oguignant
Oguignant's Avatar
Should I see wrong when it exceeds the bandwidth?
Old 31st December 2016, 20:26   #41793  |  Link
sneaker_ger
It cannot switch to that mode at all. Either there will be a fall-back to a different mode or there will be an error message.
Old 31st December 2016, 20:27   #41794  |  Link
Q-the-STORM
You wouldn't see anything, your GPU wouldn't allow to send anything above 18gbps, so even if you try to force it, you wouldn't get a signal...
btw it's hz not mhz....
Q-the-STORM is offline   Reply With Quote
Old 31st December 2016, 20:29   #41795  |  Link
Oguignant
Oguignant's Avatar
I use it 4k 60 mhz 10 bit 4.4.4 without any problem.
Old 31st December 2016, 20:40   #41796  |  Link
sneaker_ger
You don't, at least not via HDMI.
Old 31st December 2016, 22:39   #41797  |  Link
Oguignant
Oguignant's Avatar
use rgb or ycbcr444 for hdmi 2.0b (Gtx 1080 and lg ef9500 uhd deep color) and madvr exclusive mode 10bit 4k 60mhz.
Do not tell me just "no", pls explain why you say "no"
Old 1st January 2017, 00:10   #41798  |  Link
Because its physically impossible. Its beyond the bandwidth offered of HDMI 2.0. Nothing can change the physical properties of the HDMI protocol.
Just because madVR is in 10-bit mode doesn't necessarily mean your GPU outputs 10-bit to the TV.
The best you can do is 60Hz 4K 4:4:4 8-bit, or if you really want 10-bit for some reason its down to 4:2:2.
Its a shame they didn't increase the HDMI bandwidth slightly more to allow this, but alas they didn't.
HDMI 2.1 is supposed to be officialy announced at CES in January. All so far known about it is that it'll add dynamic HDR support - if it'll also increase the bandwidth is unknown (to me, anyway).
Old 1st January 2017, 00:16   #41799  |  Link
Q-the-STORM
every information I've read so far has been suggesting there is not a bandwidth change and 2.1 will simply be a firmware update...
Old 1st January 2017, 06:42   #41800  |  Link
Oguignant
Oguignant's Avatar
Clarisimo!
So, when madvr says 10 bit in exclusive mode, what does it mean? I guess, madvr converts 8 bit into 10bit?
this means that Madvr can never match or exceed the quality of the native TV player?
pd. Happy New Year to everyone!
