Old 8th February 2019, 15:51   #54621  |  Link
tp4tissue
tp4tissue's Avatar
If you are testing with the latest builds and still find the image is too dark, trying changing the output gamma in madVR. Even those with a display calibrated to 2.20 can sometimes get a better result by setting madVR to 2.40.
why does setting to 2.4 make it brighter ?
My 2.4 luts are always darker
Also, is there a lut switcher of sorts in madvr that can cycle the luts in a folder ?
Ghetto | 2500k 5Ghz
Old 8th February 2019, 16:04   #54622  |  Link
with HDR->SDR madVR trys to archive a gamma of 2.2 and at that gamma the brightness matches PQ brightness. so if you now set your display is calibrated to 2.4 it will lower the gamma so the image looks brighter and is effect gamma 2.2.
with a target 2.4 3D LUT it doesn't do that because it doesn't known the 3D LUT gamma so the image is darker in comparison and mathematically wrong.
this should not be confused with color and gamma setting which work different and again don't work properly with a 3D LUT.
no but you can do that with profiles.
Old 8th February 2019, 17:44   #54623  |  Link
Manni
Good news: it looks like 418.81 fixes the levels issues that I had with the JVCs in 12bits. So now you can get the correct levels with NCP set to 4K23 12bits RGB Full and MadVR set to video levels (16-235) with the projector set to standard HDMI.
That means that there is officially no reason to stay with 385.28, at least here.
Using CRU, custom refresh survive a reboot (as long as 23p is your default rate, not 60p).
Great to have custom refresh rates, correct levels and optimized 3D with the same drivers, with Asio4all support as well.
Still not an option for those who need HDMI passthrough for HDR, as the metadata is still not correct sadly. But if you use pixer shader tonemapping as I do, 418.81 seem to work great.
I just hope that it will be the same with my new RS2000 (arriving next week) and that ideally the 8bits magenta bug will be gone on the new models. I'll report back when I've been able to test.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 8th February 2019, 17:57   #54624  |  Link
SamuriHL
SamuriHL's Avatar
Originally Posted by 70MM View Post
Great thank you so much for your help, so a lower number than 175 will be brighter correct. If you make it too bright do you loose contrast or blacks?
I need to be clear on one point here. This is true if you are converting to SDR. if you are outputting to HDR then a higher target nit value would correspond to a brighter image. Yes, this can be somewhat confusing to wrap your head around in the beginning but it does make sense. Making it "too bright" definitely can cause unwanted issues, yes.
Old 8th February 2019, 19:00   #54625  |  Link
mrmojo666
just a question OT, are you using asio because you do not passthrough audio ?
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
Old 8th February 2019, 22:27   #54626  |  Link
Manni
No, no, Asio4all is just for REW
I use HDMI bitstream for movie audio playback.
Win11 Pro x64 b23H2
Old 8th February 2019, 23:39   #54627  |  Link
brazen1
It's great to see nVidia is addressing issues for JVC PJ users using madVR. In the mean time, for three driver series dating back to last year, they still fail to engage HDR mode because they can't even passthrough. I installed 418.81 a few days ago. It failed as miserable as the previous dozen or so.
Old 9th February 2019, 07:49   #54628  |  Link
sat4all
@Manni
Does other apps like HDR 3D games also send wrong metadata or it's only related to madVR?
ZOTAC MAGNUS EN1060K: Win 10 x64 + Kodi DSPlayer x64
LG OLED65C8 / Denon AVR-X3200W / KEF E305+ONKYO SKH-410 / Synology DS2415+ / Logitech Harmony 950
sat4all is offline   Reply With Quote
Old 9th February 2019, 13:55   #54629  |  Link
Warner306
It must be DVDFab alone because madVR seems fine: https://forum.doom9.org/showthread.php?t=176013
Old 9th February 2019, 13:58   #54630  |  Link
Manni
Originally Posted by sat4all View Post
@Manni
No idea, I haven't tested and don't have any HDR games.
Win11 Pro x64 b23H2
Old 9th February 2019, 14:20   #54631  |  Link
mrmojo666
thank you for the answer, but.....what do you mean as REW ?
MADVR-D3D11/10bit
Old 9th February 2019, 15:03   #54632  |  Link
KoKlusz
If you would like to test it, Shadow of the Tomb Raider and Resident Evil 2 have free demos on steam that support HDR.
KoKlusz is offline   Reply With Quote
Old 9th February 2019, 15:31   #54633  |  Link
Manni
Room EQ Wizard https://www.roomeqwizard.com/
Thanks, I might if I find the time, but not a priority here. Also how am I supposed to know if the metadata is correct or not? At least with UHD Bluray we know what the correct metadata is, plus MadVR shows it in the OSD.
nVidia is sending metadata, it's just not the correct one. the only way to know is to know what should be sent in passthrough mode.
Win11 Pro x64 b23H2
Old 9th February 2019, 16:08   #54634  |  Link
it's usually 4k with 10000 nit as pure white (will be clipped anyway so they didn'T bother.)
you will have sliders to control the meta data and you only need to look into the sun the max nit you setup.
Old 9th February 2019, 16:11   #54635  |  Link
KoKlusz
Tomb Raider internally reaches max 1500 nits, while RE2 4000 nits, so those values should be somehow reflected in metadata. If you gonna get the same values as with madVR, than metadata is fake.
That said this is purely to satisfy mine and sat4all's curiosity, so don't bother with this if you have better things to do.
Old 9th February 2019, 16:21   #54636  |  Link
tp4tissue
tp4tissue's Avatar
This is confusing.
The color graders don't have the right equipment.
We don't have the right equipment.
Neither parties have the right equipment to view the standard..
Ghetto | 2500k 5Ghz
Old 9th February 2019, 19:48   #54637  |  Link
it'S a computer game and only light source like the sun have this brightness.
Old 9th February 2019, 21:31   #54638  |  Link
OakLover
It is an expected behaviour for the GPU to reject every single optimized pixel clock up to clock number 32? A compatibility of 85 sounds a little bit more promising than that.
Am I doing something wrong or it is the display of my TV driving me nuts?
OakLover is offline   Reply With Quote
Old 9th February 2019, 22:06   #54639  |  Link
madjock
Not really, I never had any success with that side of madVR myself, so just always used older nVidia drivers that accepted custom resolutions. I always found the numbers that madVR was saying would work were of no use.
I think others have more success by inputing the numbers madVR gives into CRU, I never had much success with that, but lots of others did.
Old 9th February 2019, 22:11   #54640  |  Link
brotherscro1
Can anyone recomend me good settings for madVR can't seem to find some good settings most of what I have found is for older versions and with some video stutters
I have gtx 980ti i7 5930k and watching on 1440p screen mostly 1080p content sometimes 4k if that helps
brotherscro1 is offline   Reply With Quote
