30th January 2019, 03:54 | #16641 | Link |
ByteShare
In the bottom right of the "RipBot264 Encoding Client" what does the button that looks like a yellow triangle with an exclamation mark in the middle do?
when I click it, I'm not really seeing much happen. Update: Oh, got it...opens the EncodingClientLog.txt Last edited by byteshare; 30th January 2019 at 03:59. |
31st January 2019, 05:36 | #16644 | Link |
May have found a bug, I've only been able to repro it 2x although I'm nervous I may have accidentally triggered it far more often. Scenario is that I'm converting many TV shows one after another. Occasionally I will have batch added a series of shows and decide I need to add others and prioritize them higher than existing jobs. So I batch add those and slide them to the top to be processed ahead of the previously added batches. On at LEAST two occasions upon doing this I've reviewed the results and found a show with a different show's soundtrack muxxed in. Unfortunately finding these screwed up episodes is going to be nearly impossible considering the volume I'm working with I'm not sure this error is consistent, I sure hope not, but if I can reproduce it I will save the job files. I'm on v1.24.0 right now...
31st January 2019, 13:14 | #16646 | Link |
I asked Atak the same question,
see Ataks answer here: https://forum.doom9.org/showthread.p...10#post1862510 |
1st February 2019, 21:17 | #16647 | Link | |
In my view, this could be fixed in one of two ways: 1 (and best): before every new file, clear all existing items in the temp folder. This way it would fail and detect the fail because no previous file would exist that could be reused 2: Try to detect when video track extraction fails better. No idea what was causing it to fail in the first place, the file read perfectly fine, no errors, no sync problems, nothing reported wrong at all by other programs (mkvtoolnix, for example). This is a really big problem because i also run several dozen file batches per day, and now i can't be sure if my previous conversions are right or not. This is silent data corruption at its worst, and in my case, i caught it completely by chance. I'm running the latest version (could not find any updates just now). Thank your for your time, fK |
1st February 2019, 23:15 | #16648 | Link |
Tune --Animation isnt working. I have a Ma10 profile where tune is on default, chaning ot to animation and the encoding wont start. In DE mode it will just throggle between encoding and idle forever, chaning it to default and its all working again. Maybe its a bad command.
From the Profiles folder: "--profile main10 --output-depth 10 --tune animation" - not working "--profile main10 --output-depth 10" - Working fine. |
2nd February 2019, 02:36 | #16649 | Link |
How to use Ripbot to receive pushbullet notifications
Posting this here to help anyone out who might find this useful.
RunCommandSuccess and RunCommandError were added to RipBot264.ini with version 1.24 and here is how I am using it to receive a notification on my phone whenever an encoding job completes I have these 2 lines added to RipBot264.ini RunCommandSuccess="C:\Scripts\RipbotSuccess.cmd" %JOB% RunCommandError="C:\Scripts\RipbotError.cmd" %JOB% In C:\Scripts\ I have curl.exe and the 2 batch files below RipbotSuccess.cmd c:\scripts\curl.exe -u {pushbullet token}: https://api.pushbullet.com/v2/pushes -d type=note -d title="Ripbot264" -d body=%1+"Job Completed Succesfully" RipbotError.cmd c:\scripts\curl.exe -u {pushbullet token}: https://api.pushbullet.com/v2/pushes -d type=note -d title="Ripbot264" -d body=%1+"Job Failed" So with PushBullet installed on my phone I now get notifications whenever an encoding job completes |
2nd February 2019, 05:58 | #16650 | Link | |
2nd February 2019, 09:27 | #16651 | Link | |
ByteShare
2nd February 2019, 11:31 | #16652 | Link | |
I see its version x265 2.9+14 and Animation is first supported in 3.0. Then it makes sense. |
2nd February 2019, 17:50 | #16653 | Link | |
3rd February 2019, 16:33 | #16654 | Link |
ByteShare
In one of the most recent updates the "Abort" / "Start" stopped working properly for me under these conditions:
1. I start a job and at some "Abort" the job. 2. I try to "Start" the jobs again. 3. A job will never start, rather it gets stuck on the "Please Wait....Gathering information..." and also gets stuck "Aborting..." I have to kill the Encoding Client, close RipBot and restart RipBot to get a job to start again. Awesome and thank you, that was a long standing issue...I don't know why I didn't mention it myself Last edited by byteshare; 3rd February 2019 at 17:00. |
3rd February 2019, 21:20 | #16655 | Link |
Another suggestion.
Possibility to set HDR10+ metadata file for include in encode. Or better to check source for HDR10+ metadata, if present, extract and include in encode automatically.
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD |
4th February 2019, 12:24 | #16656 | Link |
Thanks!
Also, i just noticed the program has problems when converting files with "+" in the filename ("This fileSOMETHING+OTHER.mkv" -OR- "+" in the track name ("DD+" in audio track for example). Those are valid filenames and track names, so should be supported, or renamed as a preprocessing step. Thank you for your time, fK |
7th February 2019, 16:34 | #16658 | Link |
ByteShare
Really a small thing but on Windows 7 and Windows 10, I've noticed if you tab through the crop settings (to manually adjust), the Tab key goes from Top > Bottom > Right. Left is being skipped. I noticed if I click into left and hit Tab it goes to the ">" key, so it is out of order in some why.
I noticed this after going through dozens of files having to make small corrections, otherwise I'd probably have missed it because normally I'd just use the mouse. |
9th February 2019, 12:34 | #16659 | Link |
ByteShare
I lost power on a machine and all of the jobs are still in the temp folder but for some reason the jobs.list and jobs.state are gone.
I would guess this might have happened because the jobs.list is held open directly/constantly rather than being accessed when needed? I don't think there is an easy way to restore the jobs.list without just re-adding all of the jobs. |
9th February 2019, 12:53 | #16660 | Link | |
