Old 20th April 2018, 20:44   #27261  |  Link
Lathe
Lathe's Avatar
Originally Posted by varekai View Post
These are my logs.
I know the start and endings are missing but... please advise?
Careful... gonca really likes looking at other people's logs...
Old 20th April 2018, 20:47   #27262  |  Link
Lathe
Lathe's Avatar
Originally Posted by Ch3vr0n View Post
I'm not even going to dignify that with an answer as i wasn't talking to you in the first place.
Old 20th April 2018, 21:48   #27263  |  Link
gonca
Lathe, remember saying
it was my anal little 'tweaks' that slowed everything down so much
Varekai
Please don't post those kinds of pics, Lathe likes looking at other guys "wood"
Old 21st April 2018, 00:37   #27264  |  Link
Lathe
Lathe's Avatar
Varekai
Old 21st April 2018, 18:43   #27265  |  Link
varekai
Well... you actually did answer..
Relax... it was a joke...
Old 24th April 2018, 02:50   #27266  |  Link
Jake802
Not really a bug. I was just wondering if you are considering toying with the 4K Stuff?
Jake802 is offline   Reply With Quote
Old 24th April 2018, 11:42   #27267  |  Link
abbadon
So adding "IMPORT_VFR_DISABLE=1" allowed it complete, but yes it was out of sync. As it was a small clip meant as a gift, I just put it on an old phone and gave it to the recipient to watch. I am curious what the issue is and how, if possible, to solve it.
Win7x64...I had to...
RIP WinXP
abbadon is offline   Reply With Quote
Old 25th April 2018, 20:13   #27268  |  Link
e143slime8
Jigsaw problems
The issue, yes. The CloneBD stuff, not so much.
Here's the contents of BDREBUILDER.INI for Jigsaw for those interested:
[Options]
VERSION=0.50.0.24
ENCODER=0
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
TARGET_SIZE=23500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
AUTO_BURN=1
VERBOSE_STATUS=1
[Paths]
SOURCE_PATH=H:\RIPPED NEW MOVIES\JIGSAW GOOD\
WORKING_PATH=H:\TEMP TARGET FROM BDRB MOVIES\
Note: the problem is the movie/audio sync and jumping around starting near the 29 minute mark.
e143slime8 is offline   Reply With Quote
Old 26th April 2018, 14:19   #27269  |  Link
@e143slime8
Could you also click on HELP/INSPECT and post what is displayed? Sync issues are often related to the versions of the helper apps. Also, have you tried reripping? When sync issues start that late, it can sometimes be caused by a glitch just before that point due to a bad rip.
Old 1st May 2018, 05:58   #27270  |  Link
DoctorM
Can't 4k already be imported as video files or are you talking full UHD BD to BD conversion?
Old 1st May 2018, 22:29   #27271  |  Link
HomeDepot4
Trying to make a encode my version of "Elf" and I'm getting the following error, been using BDRebuilder for years and never had a problem.. have done a couple this week actually.. Making a BD25.
Rebuilding BD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
- Not enought buffer for parse video stream. Current frame num 10139
Failed to REBUILD
[05/01/18] Checking System Settings
- BD-Rebuilder v0.50.25
- Windows Version: 6.2 [9200]
- Working Path Free Space: 2,365.13GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[05/01/18] Systems Settings Check complete
[Options]
VERSION=0.50.0.23
ENCODER=0
MODE=3
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
DTSX_ENABLE=1
AUDIO_DRC=0
DECODER=2
AVCHD=0
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
TARGET_SIZE=23500
MOVIEONLY_TYPE=17
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
AUTO_BURN=1
[Paths]
WORKING_PATH=G:\MUSIC\BLURAY\
SOURCE_PATH=G:\VIDEO\BACKUP\ELF\
[Batch]
MAIN_MPLS=00023.MPLS
MAIN_MPLS_ANGLE=0
FORCED_SUB=0
FORCED_AUD=0
AUDIO=111111111
SUBS=000000000000000000
Any help would be appreciated. Thanks..
UPDATE, Actually, it doesn't seem to be picking the movie... it's choosing one of the extras and not the main movie.. interesting
HomeDepot4 is offline   Reply With Quote
Old 1st May 2018, 22:48   #27272  |  Link
@HomeDepot4
1. Please post the entire log. Thanks.
2. Any reason why you aren't using the latest version?
Old 1st May 2018, 23:01   #27273  |  Link
HomeDepot4
@HomeDepot4
I have the latest installed... that's odd why it doesn't reflect that... Anyway, here is the complete log. Thanks! Obviously, not choosing the main movie, as it would be more than 11 gigs!
[05/01/18] BD Rebuilder v0.50.25
[12:22:26] Source: ELF_00023
- Input BD size: 11.77 GB
- Approximate total content: [01:28:24.841]
- Target BD size: 22.95 GB
- MOVIE-ONLY mode enabled
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[12:22:26] PHASE ONE, Encoding
- [12:22:26] Processing: VID_00004 (1 of 9)
- [12:22:26] Extracting A/V streams [VID_00004]
- [12:24:21] Reencoding video [VID_00004]
- [12:24:21] Keeping original video (no reencode)
- [12:24:21] Processing audio tracks
- [12:24:21] Processing: VID_00006 (2 of 9)
- [12:24:21] Extracting A/V streams [VID_00006]
- [12:25:06] Reencoding video [VID_00006]
- Rate/Length: 23.976fps, 29,689 frames
- Bitrate: 28,685 Kbs
- [12:25:06] Reencoding: VID_00006, Pass 1 of 1
- [12:31:38] Video Encode complete
- [12:31:38] Processing: VID_00005 (3 of 9)
- [12:31:38] Extracting A/V streams [VID_00005]
- [12:32:12] Reencoding video [VID_00005]
- Rate/Length: 23.976fps, 16,585 frames
- Bitrate: 35,000 Kbs
- [12:32:12] Reencoding: VID_00005, Pass 1 of 1
- [12:36:14] Video Encode complete
- [12:36:14] Processing: VID_00007 (4 of 9)
- [12:36:14] Extracting A/V streams [VID_00007]
- [12:36:35] Reencoding video [VID_00007]
- Rate/Length: 23.976fps, 9,529 frames
- [12:36:35] Reencoding: VID_00007, Pass 1 of 1
- [12:38:53] Video Encode complete
- [12:38:53] Processing: VID_00008 (5 of 9)
- [12:38:53] Extracting A/V streams [VID_00008]
- [12:39:21] Reencoding video [VID_00008]
- Rate/Length: 23.976fps, 17,593 frames
- Bitrate: 28,279 Kbs
- [12:39:21] Reencoding: VID_00008, Pass 1 of 1
- [12:43:13] Video Encode complete
- [12:43:13] Processing: VID_00009 (6 of 9)
- [12:43:13] Extracting A/V streams [VID_00009]
- [12:43:32] Reencoding video [VID_00009]
- Rate/Length: 23.976fps, 9,409 frames
- Bitrate: 33,044 Kbs
- [12:43:32] Reencoding: VID_00009, Pass 1 of 1
- [12:45:28] Video Encode complete
- [12:45:28] Processing: VID_00010 (7 of 9)
- [12:45:28] Extracting A/V streams [VID_00010]
- [12:45:57] Reencoding video [VID_00010]
- Rate/Length: 23.976fps, 15,009 frames
- Bitrate: 34,855 Kbs
- [12:45:57] Reencoding: VID_00010, Pass 1 of 1
- [12:49:32] Video Encode complete
- [12:49:32] Processing: VID_00011 (8 of 9)
- [12:49:32] Extracting A/V streams [VID_00011]
- [12:49:53] Reencoding video [VID_00011]
- Rate/Length: 23.976fps, 9,369 frames
- [12:49:53] Reencoding: VID_00011, Pass 1 of 1
- [12:52:09] Video Encode complete
- [12:52:09] Processing: VID_00012 (9 of 9)
- [12:52:09] Extracting A/V streams [VID_00012]
- [12:52:33] Reencoding video [VID_00012]
- Rate/Length: 23.976fps, 9,865 frames
- [12:52:33] Reencoding: VID_00012, Pass 1 of 1
- [12:55:02] Video Encode complete
[12:55:02]PHASE ONE complete
[12:55:02]PHASE TWO - Rebuild Started
- [12:55:02] Rebuilding BD file Structure
[17:21:19] - Failed to REBUILD
Old 2nd May 2018, 15:57   #27274  |  Link
1. The error is coming from TSMUXER. Typically that means a corrupt source... but, I don't think so in this case.
2. There is nothing in a source that says "I'm the main movie." So BD-RB uses a series of checks to look for in each playlist to determine which is the most likely. It's right 99+% of the time, but in this case it looks like it didn't. If it's choosing the wrong playlist, use the "Other Movie-Only Playlist" selection from the MODE menu and choose the playlist for the main feature. But... the one it's selecting looks like it is almost 12GB, which is pretty large for an extra. If it is wrong, that may fix your issue.
3. Now... with that said -- there is another obvious problem for this playlist. The first section of the playlist (VID_00004) is being kept intact while the rest of the playlist (VID_00006, VID_00007... etc) are being encoded. That means the first section is VC-1 and the others are AVC. That is illegal, should never happen, and is likely the source of the issue. So there is something going wrong in BD-RB that I will have to investigate.
If this playlist actually is the movie... you can add
FORCE_NOENCODE=1
to the [Options] area of your BDREBUILDER.INI file. This should make BD-RB keep the entire stream intact, and since the length will easily fit on the target there would be no need to reencode.
If, however, you ran into a situation where it wouldn't fit, or where you needed it to be AVC rather than VC-1, you could add (instead):
FORCE_ENCODE=1
That would make sure the source is reencoded, even if it would fit without doing so.
If you use either option, it's a good idea to remove it after you are done to avoid issues with other discs.
Old 2nd May 2018, 17:11   #27275  |  Link
HomeDepot4
Thanks for helping clear that up. It looks like it 'picked' a 1 hour 28 minute extra that is included in the movie. I tried your suggestion of using the -other movie method and am encoding an MKV. When I get home I will try to burn the the BDR and report back.
Thank you!
Old 2nd May 2018, 17:38   #27276  |  Link
slimm
Just wanted to thank you again for this software. A gift card has been sent your way.
slimm is offline   Reply With Quote
Old 2nd May 2018, 18:08   #27277  |  Link
Thank you. Your support is appreciated.
Old 3rd May 2018, 01:14   #27278  |  Link
Blurayhd
I have to say it you make me laugh
Old 3rd May 2018, 01:37   #27279  |  Link
Lathe
Lathe's Avatar
Old 3rd May 2018, 06:22   #27280  |  Link
geheim
Hey jdobbs, do you have any news about UHD compatibility of BDRB?? Could you figure out the muxing problems??
geheim is offline   Reply With Quote
