Old 20th July 2008, 11:45   #2041  |  Link
Did you ever check this out and fix it?
Fixed: 5.1 Audio profile was missing if audio had 8 channels
Audio track is stored in pcm format therefore it must be re-encoded to 5.1 AC3.
possibly the issue's with Vista 64? dunno.
Have you installed the latest Catalysts?
Old 21st July 2008, 01:51   #2042  |  Link
jtheripper
Originally Posted by Discoboy View Post
Seems 1.8 is the latest and has some AVCHD fixes:
http://www.avforums.com/forums/showp...postcount=1166
Actually I am using firmware 1.8 Must be some other problem
jtheripper is offline   Reply With Quote
Old 21st July 2008, 06:18   #2043  |  Link
Sarreq Teryx
Location: Between a clown and a mime, holding an uzi to each head.
yes, as soon as they came out
And as I walk through the Valley of the Shadow of Death, Lord, thy balls and shaft, they comfort me, you annoint my head with oil, some salt, a dash of pepper, a sprigg of parsley......Lord?............Lord??? What dost thou intend to do with that fork???
Sarreq Teryx is offline   Reply With Quote
Old 22nd July 2008, 12:15   #2044  |  Link
pitch.fr
Didée 4 President
Hello
I want to convert my file m2ts into MKV, but I have a problem
I have a file “info.txt” but it is empty
help me ,thank you
pitch.fr is offline   Reply With Quote
Old 25th July 2008, 08:04   #2045  |  Link
tteich
RipBot264 HD-DVD compliant options
Hello Atak,
thanks for your great work for the community!
I have a quick question: is there an option in the .ini files to set the x264 --keyint <int> and --min-keyint <int> parameters? Alternatively: do you have a HDDVD ini-file (similar to the Bluray one) which presets those parameters correctly? I'd like to create HDDVD compliant .264 raw files, and a couple of x264 parameters from the Bluray profile that I use at the moment have to be changed (e.g GOP <=36, and probably others).
tteich is offline   Reply With Quote
Old 25th July 2008, 12:23   #2046  |  Link
My tests show that --keyint <int> and --min-keyint <int> are not neccessary. Blu-Ray ( and probably HD-DVD as well) players play movies without problems. Besides HD-DVD format is dead for me.
Old 25th July 2008, 12:51   #2047  |  Link
pitch.fr
Didée 4 President
Hello Atak
do you have a solution to my problem?
Please
Old 25th July 2008, 12:51   #2048  |  Link
tteich
Well, I don't know how picky HDDVD players are with out-of-spec streams. What I've encountered is that some authoring tools don't accept out of spec GOP values, hence my question. I try to author a HDDVD from a backup of my purchased BD, as I see it as a waste of ressources to dump a perfectly functioning HD player.
EDIT:
Atak: is RipBot264 open source, I would volunteer to make necessary additions and test them, in case you've no interest and time to do this...
Old 25th July 2008, 13:08   #2049  |  Link
Try to sell it. Add some money and buy PS3.
I don't need screenshots! I need samples. No samples = No help
Old 25th July 2008, 17:18   #2050  |  Link
pitch.fr
Didée 4 President
ok ,I make a sample and I send it to you
Old 26th July 2008, 06:05   #2051  |  Link
over-killer
So ripbot isn't able to do dts 7.1?
over-killer is offline   Reply With Quote
Old 26th July 2008, 07:13   #2052  |  Link
Yuma does not have DTS (it has PCM) track therefore COPY STREAM option is not available. I don't have DTS encoder so the only option is to encode to ac3 5.1
Old 27th July 2008, 13:51   #2053  |  Link
loogmoo
Vista64 hangs or reboots
Except for a 20 minute video, my Vista64 (Intel Duo 3GB, 4GB Ram, 1TB HD) system everytime froze or rebooted while RipBot264 was running. I tried 5 or 6 different Blu-Ray rips.
Of 2 jobs, I kept the content of the temp directories. Which of this information shall I post here or put somewhere (where?) to get help?
Thanks - Loog Moo
loogmoo is offline   Reply With Quote
Old 27th July 2008, 15:31   #2054  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
You have hardware problems. Your system is highly unstable in stress conditions.
Remove any overclock (im pretty sure you did it) and check your hardware (RAM, HDDs, etc) with one or more burn in software and check also the temps.
Sharktooth is offline   Reply With Quote
Old 27th July 2008, 17:19   #2055  |  Link
use this http://files.extremeoverclocking.com/file.php?f=103
Old 27th July 2008, 22:42   #2056  |  Link
Merkie
I have a very annoying problem. Anytime I try to convert any divx or xvid file (and I mean any), I always get MPC popping up saying it 'cannot render the video file'. This occurs just after I added the file, so before the actual converting.
I've tried reinstalling all my codecs, but it still does not work.
I use the latest ffdshow, CoreAVC and Haali Media Splitter.
I'm getting rather desperate, so thanks in advance!
Merkie is offline   Reply With Quote
Old 27th July 2008, 22:53   #2057  |  Link
Reinstall AviSynth
Old 27th July 2008, 23:02   #2058  |  Link
Merkie
It works! Yeah!
Thanks a lot.
Edit: ah, my PC is ready for a long night of encoding.
Old 28th July 2008, 05:31   #2059  |  Link
Sarreq Teryx
Reinstall AviSynth
It works! Yeah!
Thanks a lot.
I sometimes have the same problem, but only with Xvid/Divx AVIs, remuxing them to MKV with MKVmerge before trying to use ripbot seems to fix it also.
Old 28th July 2008, 05:33   #2060  |  Link
Sarreq Teryx
possibly the issue's with Vista 64? dunno. all I know is the anime and film filters stopped working for me when you switched from the MSU filter to FFT3DGPU.
any idea about this at all?? I miss the anime filter
