Old 14th November 2017, 17:14   #3741  |  Link
pinterf
Originally Posted by Myrsloik View Post
About how much faster is avx2 vs sse2 on a modern cpu in your expr version?
I had to do that in blind mode, I have no AVX2, only through SDE emulator. I could test it only two days ago on a 2 yr old i5 notebook and the results show that it was worth to implement.
Other speed tests are welcome, that's why there are optXXX parameters.
results in fps
avx2: set it only in Expr through optAvx2 parameter
bits      i5 sse2 32/64 bit  i5Avx2 32/64 bit
8         17.00 19.30         24.63 28.98
16       15.69 17.59         20.38 23.26
32       12.70 13.59         16.03 17.14
The script was something like this (deleted my debug experimental commented out lines)
lsmashvideosource("13HoursCUT.mp4", format="YUV444P8")
Spline64Resize(486,240) #resize, result is a multistacked image
src=last
# expr
c8 = CalcTest(src,8, False)
c16 = CalcTest(src,16, False)
c32 = CalcTest(src,32, False)
# lutxy
c8e  = CalcTest(src,8, True)
c16e  = CalcTest(src,16, True)
c32e = CalcTest(src,32, True)
res8=Diff(c8,src)
res16=Diff(c16,src)
res32=Diff(c32,src)
res8e=Diff(c8e,src)
res16e=Diff(c16e,src)
res32e=Diff(c32e,src)
col1=StackVertical(c8,c16.convertbits(8),c32.convertbits(8))
col2=StackVertical(res8, res16, res32)
col3=StackVertical(c8e,c16e.convertbits(8),c32e.convertbits(8))
col4=StackVertical(res8e, res16e, res32e)
StackHorizontal(col1, col2, col3, col4)
#used only c8, c16 or c32 output for speed test from the clips above.
# change parameters. e.g. optSSE2=true, optSingleMode=false, optAvx2=false
c8
Function Diff(clip src1, clip src2)
  return Subtract(src1.ConvertBits(8),src2.ConvertBits(8)).Levels(120, 1, 255-120, 0, 255, coring=false)
Function CalcTest(clip src, int bits, bool lut)
src
convertbits(bits)
tmp=last
method=Blur(1)
szrp=16
spwr=4
str=100/100.0
sdmplo=4
sdmphi=48
expr_pow = "x y == x x x y - abs "+string(Szrp) +" scaleb / 1 "+string(Spwr)+" / ^ "+string(Szrp) +" scaleb * "+string(str)+" * x y - 2 ^ x y - 2 ^ "
\+string(SdmpLo)+" scaleb scaleb + / * x y - x y - abs / * 1 "+string(SdmpHi)+" scaleb 0 == 0 x y - abs "+string(SdmpHi)+" scaleb / 4 ^ ? + / + ?"
ret=lut ? mt_lutxy(tmp,method, yexpr=expr_pow, U=1,V=1 ) : Expr(tmp,method,expr_pow,"","", optSSE2=true, optSingleMode=false, optAvx2=false)
return ret
Last edited by pinterf; 14th November 2017 at 17:20. Reason: test env clarification
pinterf is offline
Old 14th November 2017, 17:15   #3742  |  Link
pinterf
thanks pinterf
some friend that use vs said that float <- -> int is broken in vs expr, did you note that and fix it?
Yes, fixed and noted.
pinterf is offline
Old 14th November 2017, 22:04   #3743  |  Link
Any idea when your commits going to merge officially? You're the only one spearheading code in right now.
ryrynz is offline
Old 15th November 2017, 10:03   #3744  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
sxr, syr (relative x and y coordinates, from 0 to 1.0)
Aren't those normalised, rather than relative?
wonkey_monkey is offline
Old 15th November 2017, 10:25   #3745  |  Link
pinterf
Yes, normalized but I took the terminology from here:
http://avisynth.nl/index.php/MaskTools2/mt_lutspa
pinterf is offline
Old 15th November 2017, 12:29   #3746  |  Link
edcrfv94
I change mt_lutxy to Expr then limit function no work any more.
Function kf_limit_dif8_expr(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
	sCSP = filtered.kf_GetCSP()
	IsY8 = sCSP == "Y8"
	smooth   = Default(smooth, True    )
	thr      = Default(thr,    1.0     )
	elast    = Default(elast,  smooth ? 3.0 : 255./thr)
	darkthr  = Default(darkthr,thr     )
	Y        = Default(Y,      3       )
	U        = Default(U,      3       )
	V        = Default(V,      3       )
	Y        = min(Y,     4)
	U        = min(U,     4)
	V        = min(V,     4)
	thr      = max(min(    thr, 255.0), 0.0)
	darkthr  = max(min(darkthr, 255.0), 0.0)
	elast    = max(elast, 1.0)
	mode     = thr == 0 && darkthr == 0 ? 4 : thr == 255 && darkthr == 255 ? 2 : 3
	smooth   = elast==1 ? False : smooth
	diffstr  = " x y - "
	elaststr = " "+string(elast)+" "
	thrstr   = diffstr+" 0 > "+string(darkthr)+" scalef "+string(thr)+" scalef ? "
	alphastr = elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstr+" * / ? "
	betastr  = thrstr+elaststr+" * "
	sexpr    = smooth   ? alphastr+diffstr+" * "+betastr+diffstr+" abs - * y + "
	\                   : thrstr+diffstr+diffstr+" abs / * y + "
	expr     = diffstr+" abs "+thrstr+" <= x "+diffstr+" abs "+betastr+" >= y "+sexpr+" ? ? "
	thrstrc  = " "+string(thr)+" scalef "
	alphastrc= elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstrc+" * / ? "
	betastrc = thrstrc+elaststr+" * "
	sexprc   = smooth   ? alphastrc+diffstr+" * "+betastrc+diffstr+" abs - * y + "
	\                   : thrstrc+diffstr+diffstr+" abs / * y + "
	exprc    = diffstr+" abs "+thrstrc+" <= x "+diffstr+" abs "+betastrc+" >= y "+sexprc+" ? ? "
	# diff   = filtered - original
	# alpha  = 1 / (thr * (elast - 1))
	# beta   = elast * thr
	# When smooth=True  :
	# output = diff <= thr  ? filtered : \
	#          diff >= beta ? original : \
	#                         original + alpha * diff * (beta - abs(diff))
	# When smooth=False :
	#                         original + thr * (diff / abs(diff))
	expry = (Y == 3) ? expr : ""
	expru = (U == 3) ? exprc : ""
	exprv = (V == 3) ? exprc : ""
	return   (mode == 4)    ? original
	\      : (mode == 2)    ? filtered
	\      : IsY8           ? Expr(filtered, original, expry, optSSE2=true, optSingleMode=false, optAvx2=true)
	\      :                  Expr(filtered, original, expry, expru, exprv, optSSE2=true, optSingleMode=false, optAvx2=true)
Function kf_limit_dif8_mt(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
	Y        = Default(Y,      3       )
	U        = Default(U,      3       )
	V        = Default(V,      3       )
	Y        = min(Y,     4)
	U        = min(U,     4)
	V        = min(V,     4)
	diffstr  = " x y - "
	return   mode == 4    ? original
	\      : mode == 2    ? filtered
	\      :                mt_lutxy(filtered, original, yExpr=expr, uExpr=exprc, vExpr=exprc, Y=Y, U=U, V=V)
edcrfv94 is offline
Old 15th November 2017, 12:48   #3747  |  Link
pinterf
Could you specify your calling parameters and what should I look for in the results?
pinterf is offline
Old 15th November 2017, 13:05   #3748  |  Link
edcrfv94
The result is very different.
	SetMemoryMax(3000)
	#colorbars(width=1920, height=1080, pixel_type="yv12").killaudio().assumefps(25, 1)
	ImageSource("1.png", end=0).Dither_convert_rgb_to_yuv(lsb=true,output="YV12").DitherPost(mode=6)
	ConvertToY8()
	trim(0, 5000)
	#Limiter()
	#InvertNeg()
	#VToY()
	src = last.ConvertBits(bits=16)
	sharp = src.Sharpen(1.0).Sharpen(1.0)
	kf_limit_dif8_mt_test(sharp, src, thr=1, elast=42, y=3, u=1, v=1)
	#kf_limit_dif8_expr_test(sharp, src, thr=1, elast=42, y=3, u=1, v=1)
	ConvertToStacked().DitherPost(mode=6, ampo=1)
	Function kf_limit_dif8_expr_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
		IsY8 = sCSP == "Y8"
		Y        = Default(Y,      3       )
		U        = Default(U,      3       )
		V        = Default(V,      3       )
		Y        = min(Y,     4)
		U        = min(U,     4)
		V        = min(V,     4)
		diffstr  = " x y - "
	Function kf_limit_dif8_mt_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
		Y        = Default(Y,      3       )
		U        = Default(U,      3       )
		V        = Default(V,      3       )
		Y        = min(Y,     4)
		U        = min(U,     4)
		V        = min(V,     4)
		diffstr  = " x y - "
	Function kf_GetCSP(clip c)
		try {
			csp = c.kf_GetCSP_avsPlus()
		} catch (error_msg) {
			csp = c.kf_GetCSP_avs()
		return csp
	Function kf_GetCSP_avs(clip c)
		return c.IsPlanar ? c.IsYV12 ? "YV12" :
		\                   c.IsYV16 ? "YV16" :
		\                   c.IsYV24 ? "YV24" : c.kf_GetCSP_Y8_YV411() :
		\      c.IsYUY2   ? "YUY2"   :
		\      c.IsRGB32  ? "RGB32"  :
		\      c.IsRGB24  ? "RGB24"  : "Unknown"
		Function kf_GetCSP_Y8_YV411(clip c) {
		    try {
			c.UtoY
			csp = "YV411"
			csp = "Y8"
		    return csp
	Function kf_GetCSP_avsPlus(clip c)
		return c.Is420   ? "YV12"  :
		\      c.IsY     ? "Y8"    :
		\      c.Is422   ? "YV16"  :
		\      c.Is444   ? "YV24"  :
		\      c.IsYUVA  ? "YUVA"  :
		\      c.IsYV411 ? "YV411" :
		\      c.IsPackedRGB  ? "RGB32/RGB24" :
		\      c.IsPlanarRGB  ? "RGB48"       :
		\      c.IsPlanarRGBA ? "RGB64"       : "Unknown"
edcrfv94 is offline
Old 15th November 2017, 13:39   #3749  |  Link
pinterf
...code...
Thanks, scalef bug in 10-16 bits. scaleb was o.k.
I'll wait a bit before make the new version with the fix.
pinterf is offline
Old 15th November 2017, 17:32   #3750  |  Link
pinterf
New build with a hotfix
Download Avisynth+ r2544
20171115 r2544
  - Expr: fix "scalef" for 10-16 bits
  - Expr optimization: eliminate ^1 +0 -0 *1 /1
pinterf is offline
Old 15th November 2017, 23:43   #3751  |  Link
Gave the sizetmod a try but have it crash every time. Tried a simple script through ffdshow raw.
SetFilterMTMode("DEFAULT_MT_MODE", 2)
ffdshow_source()
aWarp4(Spline36Resize(width*4, height*4, 0.375, 0.375), aSobel.aBlur(), depth=2)
Prefetch(4)
MadVR ends up crashing, no issues with the normal build.
ryrynz is offline
Old 16th November 2017, 09:24   #3752  |  Link
pinterf
ffdshow_source()
Prefetch(4)
Thanks. Do you know if anything in this chain is using CPP 2.5 or C interface?
For me they (x64 plugins with CPP 2.5 interface) are crashing with the sizetmod build. No wonder, 2.5 is the "baked" code interface.
I don't like them. For example supporting 2.5 prevented me last year to introduce the array type. Now this.
They badly need at least a recompile for 2.6.
pinterf is offline
Old 16th November 2017, 12:08   #3753  |  Link
tormento
Acid fr0g
tormento's Avatar
Experimental x64 crashing here.
PHP Code:
SetMemoryMax(8000)
SetFilterMTMode("DEFAULT_MT_MODE"2)
SetFilterMTMode("ChangeFPS"3)
SetFilterMTMode("DGSource"3)
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\1_37 Swiss Army man — Un amico multiuso\swiss.dgi")
#CompTest(1)
ChangeFPS(last,last,true)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=0)
Prefetch(6
@turment on Telegram
tormento is offline
Old 16th November 2017, 12:10   #3754  |  Link
Shouldn't be. Awarp4, asobel and a blur are all part of the x64 build of Awarpsharp you compiled and is the latest version you released, it should be compatible.
ryrynz is offline
Old 16th November 2017, 12:32   #3755  |  Link
pinterf
Perhaps the source filter?
For example LSmashSource (CPP v2.5 as Avsmeter64 reports) is crashing for me. ffms2 is OK.
pinterf is offline
Old 16th November 2017, 12:54   #3756  |  Link
pinterf
PHP Code:
SetMemoryMax(8000)
#CompTest(1)
Prefetch(6
I don't know about the source filter, I have replaced it with ffms2.
The script still crashed with lsb=true.
Unfortunately dither.dll is a 2.5 style plugin.
With lsb=false the script is working properly with the given parameters.
Edit: rebuilt dither.dll, replaced the 2.5-style avisynth.h with the 2.6-style avs+ header (not even the size_t mod version) and no more crash with lsb=true.
pinterf is offline
Old 16th November 2017, 16:37   #3757  |  Link
tormento
Acid fr0g
tormento's Avatar
Ahem... post new dither here
tormento is offline
Old 16th November 2017, 16:49   #3758  |  Link
pinterf
It does not help at the moment.
LSmashSource, dither, AddGrainC, x264_64, and a lot more cpp 2.5 plugins and 2.5 c interface user apps are out there.
Just have a look at the CPP 2.5 list of avsmeter -avsinfo.
pinterf is offline
Old 16th November 2017, 17:01   #3759  |  Link
tormento
Acid fr0g
tormento's Avatar
[CPP 2.5 / 64 Bit Plugins]
D:\Programmi\Media\AviSynth+\plugins64\Dither-1.27.2.dll
D:\Programmi\Media\AviSynth+\plugins64\f3kdb-2.020140721-SAPikachu.dll
To me is more than enough! It's the only filter I use still 2.5!
tormento is offline
Old 17th November 2017, 11:17   #3760  |  Link
Yanak
Not sure if my used plugins are all up to date and /or if some others could be replaced by something else tho but things like LSmashSource, Avsinpaint, MP_Pipeline are essential for me and i don't think there is any alternative to those :/
Yanak is offline
