Old 8th May 2010, 20:59   #41  |  Link
Eretria-chan
Originally Posted by Zathor View Post
I am just guessing - maybe you have to install the visual c++ runtimes for x64?
Runtimes aren't backwards compatible.
To install the proper runtime, we would need to know:
- What version it is (2005/2008).
- If SP1 is installed or not (2008 only).
They have different runtimes.
Eretria-chan is offline   Reply With Quote
Old 8th May 2010, 23:59   #42  |  Link
rogersnm
I've got the Microsoft Visual C++ 2008 SP1 Redistributable x64 and x86 and I also just installed the 2010 Runtime (both x64 and x86) and the 2005 SP1 Redistributable (again, x64 and x86) which have made no difference.
Event Viewer might have yielded some useful information, it generates 3 errors every time I attempt to run the executable.
---------------- Error 1 ----------------
Source: SideBySide
EventID: 32
Dependent Assembly Microsoft.Windows.Common-Controls could not be found and Last Error was The referenced assembly is not installed on your system.
---------------- Error 2 ----------------
Source: SideBySide
EventID: 59
Resolve Partial Assembly failed for Microsoft.Windows.Common-Controls. Reference error message: The referenced assembly is not installed on your system.
---------------- Error 3 ----------------
Source: SideBySide
EventID: 59
Generate Activation Context failed for C:\PathTo\MeGUI.exe. Reference error message: The referenced assembly is not installed on your system.
Edit: Possibly microsoft's fault http://support.microsoft.com/kb/914061
Edit #2: No joy, that hotfix is apparently included in SP2
Edit #3: After looking at sxstrace logs it looks like Windows Server 2003 doesn't possess the required assembly code.
rogersnm is offline   Reply With Quote
Old 9th May 2010, 10:42   #43  |  Link
KSab
Source: SideBySide
EventID: 32
Source: SideBySide
EventID: 59
Source: SideBySide
EventID: 59
For me too most!
KSab is offline   Reply With Quote
Old 9th May 2010, 13:07   #44  |  Link
Zathor
You can try this one:
http://www.microsoft.com/downloads/d...displaylang=en
Old 9th May 2010, 13:45   #45  |  Link
rogersnm
"Setup cannot continue because this version of the .NET Framework is incompatibile with a previously installed one. For more information, see http://support.microsoft.com/support/kb/articles/q312/5/00.asp"
The x64 version of the .NET Framework 2.0 SP2 seems to already be installed.
Just FYI: Avisynth x64 is functioning well
Old 9th May 2010, 16:26   #46  |  Link
KSab
Mine:
Old 11th May 2010, 22:55   #47  |  Link
newstd
I just wanted to share with you this comparison test :
same DVD (157840 frames), with same settings for x264 (in constant quality) on win 7 x64 OS
Here are the statistic logs from :
megui x86 = encoded 157840 frames, 13.34 fps, 1654.44 kb/s
megui x64 = encoded 157840 frames, 18.38 fps, 1557.75 kb/s
Thanks Zathor for this useful initiative.
it's worth of it (even if not all encoders or plugins are not ready for 64-bit), especially when you don't have the last powerful Quad processor ...
Hoping now to see it on the stable server.
newstd is offline   Reply With Quote
Old 12th May 2010, 08:53   #48  |  Link
AMED
AMED's Avatar
Should MeGUI be using a crazy amount of memory?
at the moment there are are total of 130 jobs loaded in to MeGUI and its up to job 120.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 13th May 2010, 11:55   #49  |  Link
ncatt
I saw this too when loading many jobs. My workaround was load all jobs, close and reopen megui, then start the encodes. Otherwise, very good job Zathor!!
ncatt is offline   Reply With Quote
Old 13th May 2010, 22:32   #50  |  Link
quantum5uicid3
thx for confirming people. i tried to figure out what its doing with my limited expertise and if i had to guess, i'd say megui x64 is leaving avisynth threads open.
quantum5uicid3 is offline   Reply With Quote
Old 18th May 2010, 00:41   #51  |  Link
Cyber-Mav
any difference in speed using megui in native 64bit mode vs the 32bit megui that uses the 64bit wrapper?
Cyber-Mav is offline   Reply With Quote
Old 18th May 2010, 05:43   #52  |  Link
Zathor
Didn't compare it myself, but:
http://forum.doom9.org/showthread.ph...59#post1390959
Old 18th May 2010, 08:02   #53  |  Link
AMED
AMED's Avatar
I think you correct about AviSynth threads staying open. I just did a quick check by opening a FFMS indexed mkv file in the avisynth creator. I then closing the AviSynth creator by clicking the Red X and then tried to delete the mkv file and i get this.
A Man Eating Duck
Old 19th May 2010, 14:37   #54  |  Link
quantum5uicid3
looks like i was wrong about 64bit ffmpeg's abilty to do avs in and ffvhuff out. it does actually work in many cases but fails with others.
zathor, can you change the pre-rendering to use this easily? it would make it easier to test.
ffmpeg -i input.avs -vcodec ffvhuff -context 1 -vstrict -1 -an output.avi
and any thoughts on memory behavior?
i forgot to add:
the memory problems occur only when using ffms, not directshowsource. unfortunately i can't duplicate the issue on the commandline.
Old 26th May 2010, 00:28   #55  |  Link
quantum5uicid3
i'll add that, i can't find any disadvantage to using ffmpeg over mencoder.
edit
i think multithreading works better too
Old 3rd June 2010, 20:37   #56  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
I don't know if this is a problem with Megui x64, or the 64-bit NicAudio plugin from Squid80, but I'm getting an error every time I check the box for "Apply Dynamic Range Compression":
--[Information] [6/3/2010 12:28:35 PM] Started handling job
--[Information] [6/3/2010 12:28:35 PM] Preprocessing
--[NoImage] Avisynth script
---[NoImage] LoadPlugin("C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\NicAudio.dll")
---[NoImage] NicAc3Source("C:\YOU_ONLY_LIVE_TWICE\VIDEO_TS\You Only Live Twice T82 2_0ch 192Kbps DELAY 0ms.ac3", DRC=1)
---[NoImage] ConvertToMono()
---[NoImage] Normalize()
---[NoImage] return last
--[NoImage] Commandline used: -ignorelength -lc -br 96000 -if - -of "{0}"
--[Information] [6/3/2010 12:28:35 PM] Encoding started
--[Information] [6/3/2010 12:28:35 PM] Encode thread started
--[Information] [6/3/2010 12:28:35 PM] Avisynth script environment opened
--[Error] An error occurred
---[NoImage] Exception message: Script error: NicAc3Source does not have a named argument "DRC"
---[NoImage] Stacktrace
----[NoImage] at MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env)
----[NoImage] at MeGUI.AviSynthScriptEnvironment.ParseScript(String script)
----[NoImage] at MeGUI.AviSynthAudioEncoder.encode()
---[NoImage] Inner exception: null
Any thoughts? Oh, I'm using MeGui x64 0.3.4.15 and Avisynth 2.5.8 MT 64-bit from SEt.
Lyle_JP is offline   Reply With Quote
Old 3rd June 2010, 22:32   #57  |  Link
Zathor
The NicAudio plugin from Squid80 is rather old (2006) and therefore I think that DRC is not supported.
You can post a request for an updated x64 build here: http://forum.doom9.org/showthread.php?t=152800 the source code for the recent x86 build is here: http://nicaudio.codeplex.com/
Maybe someone is able to compile a x64 build.
Old 3rd June 2010, 23:07   #58  |  Link
Eretria-chan
Here's an x64 build of NicAudio compiled by myself: http://www.mediafire.com/?ozlnnjtgzam
Unfortunately, since the source wasn't designed for x64, it might or might not work. I'm not going to try fixing bugs, however. Let's just hope it works.
Compiled with VS2010, so you may need its runtime.
Old 4th June 2010, 14:06   #59  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
That worked great with DRC, and I didn't have to download any runtimes. I'll try it with PAL to NTSC slow-down and DTS, and if it works on those, it does everything I need!
Old 11th June 2010, 02:01   #60  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
Checking back in. The NicAudio plugin provided worked with everything I threw at it. But Zathor must have already tested it himself since it seems to have been added to the Megui x64 update distribution (unless that's yet another compile).
I have another problem. One actually mentioned by someone else way back in 2008 to Sharktooth, but nothing was (AFAICT) ever done. Megui x64 is very unstable when the video provided by Avinsynth has not been resized to a mod16 height, regardless of video source. This has never really been a problem in 32-bit Megui, but the crashes are frequent and unpredictable with the 64 bit version, until you resize to a mod16 height, at which time the random crashing goes away. The crashes usually happen when opening a preview window or enqueing a video encoding job, but never seem to happen when actually processing a queue, which would seem to indicate that the crashes are not happening because of x264 or Avisynth.
