Go Back   Doom9's Forum > Video Encoding > MPEG-2 Encoding
Old 13th March 2012, 08:20   #21  |  Link
manono
Originally Posted by Biggiesized View Post
I know this is old, but how did you acquire the Fox Home Theater CQMs?
They're built into HCEnc (and also found in Matrix collections that are floating around). Or:
Fox 1:
        08 08 09 11 13 13 14 17
	08 08 11 12 13 14 17 18
	09 11 13 13 14 17 17 19
	11 11 13 13 14 17 18 20
	11 13 13 14 16 17 20 24
	13 13 14 16 17 20 24 29
	13 13 14 17 19 23 28 34
	13 14 17 19 23 28 34 41
	08 08 08 09 09 09 09 10
	08 08 09 09 09 09 10 10
	08 09 09 09 09 10 10 10
	09 09 09 09 10 10 10 10
	09 09 09 10 10 10 10 11
	09 09 10 10 10 10 11 11
	09 10 10 10 10 11 11 11
	10 10 10 10 11 11 11 11
Fox 2 (Slightly different from the version HCEnc uses, but very comparable):
	08 08 09 09 10 10 11 11
	08 09 09 10 10 11 11 12
	09 09 10 10 11 11 12 12
	09 10 10 11 11 12 13 13
	10 10 11 11 12 13 13 14
	10 11 11 12 13 13 14 15
	11 11 12 13 13 14 15 15
	11 12 12 13 14 15 15 16
Fox 3:
	16 16 16 16 16 16 16 16
manono is offline   Reply With Quote
Old 13th March 2012, 11:02   #22  |  Link
Biggiesized
Biggiesized's Avatar
I know they're part of HCEnc. I've viewed them there myself.
I mean, who originally sourced them? And how?
Biggiesized is offline   Reply With Quote
Old 13th March 2012, 13:03   #23  |  Link
It's easy to dump them from the stream with the right tool.
Old 13th March 2012, 13:57   #24  |  Link
pandy
However be inform that some decoders (AFAIR broadcom) don't like situation when DC is lower than 8 (sometimes even lower than 16 on non-intra).
pandy is offline   Reply With Quote
Old 13th March 2012, 16:31   #25  |  Link
kolak
Restream can dump matrixes.
Old 13th March 2012, 19:36   #26  |  Link
mp3dom
If I'm not wrong, ReStream dump the first set of matrices in the file. If the mpeg2 switch matrices at GOP level (like some encoders do) you can't log them all. With DGIndex, enabling "Log quantizer matrices" you can dump all the matrices used by the mpeg2.
mp3dom is offline   Reply With Quote
Old 13th March 2012, 21:33   #27  |  Link
kolak
Hmmm- now I'm not sure what I've used- maybe it was DGIndex, which does it "better" way. Don't remember
I think it was DGIndex
Old 13th March 2012, 23:06   #28  |  Link
manono
Who? The one called Fox 1 (aka Fox Home Theater) first showed up in a collection of XviD matrices as far as I know. It was obviously sourced from a 20th Century Fox DVD. I don't know the person that first made it available. The how has been explained elsewhere in this thread. It was probably done using ReStream as I don't believe DGIndex had that ability then.
The ones called Fox 2 and Fox 3 were supplied by me for Rockas's add-on to DVD-Rebuilder. Fox 2 I got from a DVD. Fox 3 I created from pieces of two others. I believe it was Hank that gave all three of them the names used in his encoder. The idea was that each compressed the video more than the one before (output a smaller file size), for the same quant value.
Old 13th March 2012, 23:32   #29  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Rockas Matrix Editor uses Quantdump.exe:
[C:\]
=>quantdump
QuantDump 1.1 by Donald A. Graft
Usage: quantdump inputfile [outputfile]
       where input file is an elementary or program stream
       and outputfile will be written with the quant dump information.
Old 13th March 2012, 23:33   #30  |  Link
Oh yeah, I forgot I made that.
Old 14th March 2012, 05:32   #31  |  Link
Biggiesized
Awesome! I can't wait to dig up some good looking DVDs in my collection and analyze them.
Just curious... but what are some of everyone's favorite looking DVDs (for comparison)?
Old 14th March 2012, 10:45   #32  |  Link
Biggiesized
Hmm... can you dump QMatrices from H.264 streams as well?
Old 14th March 2012, 11:24   #33  |  Link
kolak
Yes- there is a tool, but don't remember name
Something like AVpnic?
Old 14th March 2012, 12:29   #34  |  Link
mp3dom
AVInaptic. You need to put the raw stream in an MKV container. You'll see only matrices that differs from "Flat". So, basically, Flat matrix used -> no info about matrices. Something different -> values of 8x8/4x4 intra/inter matrices.
Old 14th March 2012, 13:13   #35  |  Link
kolak
Hehehe- I was close with name
Old 26th November 2012, 23:50   #36  |  Link
Biggiesized
I did some tests with AVInaptic and only the 4x4 intra luma matrix was dumped. Does this mean all of the other matrices are flat?
Are there any other tools for MPEG-4 AVC/H.264 steams?
encoding, mpeg2, quality, quantization matrix
