Old 4th January 2013, 23:56   #41  |  Link
xekon
I actually just noticed that today, I wasnt even aware there was a doom10....
anyway here the link to over at doom10: http://doom10.org/index.php?topic=2178.0
Last edited by Guest; 5th January 2013 at 00:47. Reason: remove invitation for OT discussion
xekon is offline   Reply With Quote
Old 11th April 2013, 13:00   #42  |  Link
sl1pkn07
Pajas Mentales...
the link of port to vapoursynth is broken
any notice if ver2.2d has been ported?
sl1pkn07 is offline   Reply With Quote
Old 11th April 2013, 13:07   #43  |  Link
Reel.Deel
Originally Posted by sl1pkn07 View Post
the link of port to vapoursynth is broken?
Working link can be found here.
Reel.Deel is offline   Reply With Quote
Old 11th April 2013, 13:15   #44  |  Link
sl1pkn07
Pajas Mentales...
oh, i don't look this is part of havsfunc
thanks and greetings
Old 4th June 2015, 07:34   #45  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I put up the excellent documentation on Avisynth.nl since I couldn't find it online, and edited it some as well.
Old 6th September 2018, 18:25   #46  |  Link
Katie Boundary
Katie Boundary's Avatar
Mediafire no longer hosts this file. Would anyone be kind enough to provide a functioning link?
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 6th September 2018, 19:30   #47  |  Link
Groucho2004
As I told you earlier. all the info you need is here. Then you have to scroll down a bit where you shall find a link to the current SMDegrain.
Groucho's Avisynth Stuff
Old 7th September 2018, 02:45   #48  |  Link
Katie Boundary
Yeah, sorry, I posted that before I realized that users are supposed to just copy and paste the text into an AVSI file. I was expecting a .dll
Old 18th May 2019, 17:48   #49  |  Link
EHarlen
Denoisers are not effective enough at removing noise in SMDegrain as Prefilter input clip.
For example, there is a big difference between smdegrain (tr=3,thsad=300,prefilter=removegrain(11),pel=1)
and smdegrain (tr=3,thsad=300,pel=1).removegrain(11)
But I wanna use denoisers in SMDegrain as Prefilter input clip.
How is it possible to make them more effective?
EHarlen is offline   Reply With Quote
Old 18th May 2019, 18:36   #50  |  Link
StainlessS
StainlessS's Avatar
I aint any expert but think maybe your favourite spatial denoiser would work with some kind of 'strength' arg to tune it.
(I like VagueDenoiser, but no idea if works well with SMDegrain [which I dont use])
EDIT: Actually, Removegrain(11) is similar to Blur(1.0), so I guess that you could use blur and vary with single float arg.
http://avisynth.nl/index.php/RgTools/RemoveGrain
I sometimes post sober.
Old 22nd May 2019, 17:33   #51  |  Link
real.finder
smdegrain is only Temporal Denoiser, it work good in some sources and in others it's not, anyway did you tried it like this
RGclip=removegrain(11)
smdegrain (tr=3,thsad=300,prefilter=RGclip,mfilter=RGclip,pel=1)
also you can try something else like dfttestMC and admfilter
See My Avisynth Stuff
Old 19th January 2020, 01:47   #52  |  Link
redfordxx
Hi, I am trying SMDegrain...
...when I use contrasharp, then the 32bit filters are required, am I correct?
And then I am going out of memory with 3K video...
Any chance having 64bit version of contrasharp?
redfordxx is offline   Reply With Quote
Old 19th January 2020, 10:54   #53  |  Link
StainlessS
StainlessS's Avatar
Redforxx, Probably be a good idea to give details of input clip and also your script call to SmDegrain, otherwise maybe too much guesswork for real.finder.
[just my guess].
Old 19th January 2020, 21:05   #54  |  Link
redfordxx
Well.... today it didn't crash...
I have 3264 x 1836 30FPS.
I tried
SMDegrain(tr=4,thSAD=400,thSADC=200,contrasharp=40,refinemotion=true,truemotion=true,subpixel=1,pel=1)
But I plan to add deshaker... so I am worried it will crash... we'll see
Speaking of the deshaker...it compensates global rotation, so DePan
that would help MVAnalyse finding motion vectors on strongly rotating videos, correct?
Old 19th January 2020, 21:25   #55  |  Link
redfordxx
Concerning the sharpening...
I don't know whether it is implemented...
...I understood, the sharpening is limited by max change made by the denoiser...
How about to limit it max and min of all motion-compensated neighbour frames? Because due to sudden local motion the single frame could be blured and both neighbours could be sharp...so the limitation of the current frame would be not enough.
Is there any filter, which returns max or min value of multiple (lot of) clips?
Old 20th January 2020, 18:40   #56  |  Link
real.finder
there are some mc sharp funtions by Didée
BTW I don't know what SMDegrain you use but the OP one is so outdated
denoise, interlaced, mdegrain, smdegrain, yuy2
