Old 6th August 2019, 13:27   #28681  |  Link
Originally Posted by cartman0208 View Post
Is it possible to strip the Dolby Vision data?
Like backup a 3D source as 2D?
Apparently, from what I gather, a Blu-Ray stream with Dolby Vision stream also includes HDR10. So I should be able to support it as an HDR10 stream until I find out how to provide support for Dolby Vision.
Has anyone seen contradicting information?
Old 6th August 2019, 14:44   #28682  |  Link
laserfan
Aging Video Hobbyist
Not sure but jdobbs this thread might be useful to you in some way?
https://www.makemkv.com/forum/viewto...94ad9c2def00a1
Old 6th August 2019, 14:49   #28683  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Apparently, from what I gather, a Blu-Ray stream with Dolby Vision stream also includes HDR10....
Indeed it does.
I've carried out quite a few Dolby Vision detection tests using my LG television and OPPO UDP-203 playback devices and with most current muxing tools when you mux a HEVC stream with Dolby Vision into the .m2ts or .mkv container, the aforementioned hardware playback devices only detect/trigger the HDR10 layer.
Old 6th August 2019, 16:08   #28684  |  Link
BD Rebuilder v0.60.19
I've updated the first post of this thread with a link to the most recent release of BD Rebuilder. Changes for this release:
- Corrected "UHD_Correct_M2TS() 00009  8102"
  error that could be experienced on some
  high framecount BDs.
- Fixed "Can't open file:" error that can
  occur when attempting backup of sources
  with Dolby Vision.
- Added code to help support Dolby Vision, it
  is very experimental and needs much more
  testing.
Old 6th August 2019, 19:00   #28685  |  Link
FilipeAmadeuO
  with Dolby Vision.
  testing.
Tested 0.60.19 and the error "Corrected "UHD_Correct_M2TS() 00009 8102" still appears on SOLO STAR WARS UHD. Any sugestion ?
FilipeAmadeuO is offline   Reply With Quote
Old 6th August 2019, 20:54   #28686  |  Link
When you reported it a couple of days ago you said the error was "UHD_Correct_M2TS() 00006 8102". Are you sure it isn't error 00006?
Old 6th August 2019, 21:28   #28687  |  Link
gonca
Yes. But, as I said, it depends on how hard it will be to support Dolby Vision directly.
Dolby Vision and HDR10 co-exist in the same stream.
If you omit the DV layer you still have HDR10.
Typical movie disc layout of m2ts
4K video layer, movie and HDR metadata
2K video layer, DV metadata
Sound
Subs
Etc
Old 6th August 2019, 21:32   #28688  |  Link
ripem2011
Ahhh, I see. It confused me because of the actual format called DV (Digital Video) that is common on some video recorders.
@ripem2011
Dolby Vision isn't supported yet. I have a few details on it, but not all that is needed. I probably won't work on it until I have standard UHD processing bug free.
yes thats what i am saying it kept the Dolby Vision file it shows both
ripem2011 is offline   Reply With Quote
Old 6th August 2019, 21:54   #28689  |  Link
ripem2011
you are right it show Dolby Vision i just tried it and it plays the HDR and not Dolby Vision my bad
Old 7th August 2019, 08:12   #28690  |  Link
FilipeAmadeuO
You are correct. The error reported was:
08/06/19 [18:56:02] UHD_Correct_M2TS() 00006 8102
Old 8th August 2019, 19:37   #28691  |  Link
spotter
I'm wondeirng if it ever be possible to add hdr10+ metadata based on dolby vision to a stream, this would be somewhat of a game changer for those with hdr10+ TVs. My guess is that it be significantly harder to go in the opposite direction (hdr10+ to dolby vision), but who knows.
spotter is offline   Reply With Quote
Old 9th August 2019, 00:20   #28692  |  Link
If I'm seeing it correctly, the HDR10 metadata is already there, stored in the same way as if it weren't Dolby Vision. I'm not sure how it changes with HDR10+. I don't have an HDR10+ source to dump/study.
Things are changing too fast... it's getting really hard to keep up.
Old 9th August 2019, 01:04   #28693  |  Link
FilipeAmadeuO
Dolby Vision and HDR10+ are aditional 1080p layers
HDR10 metadata is integrated in the main HEVC
Old 9th August 2019, 04:04   #28694  |  Link
spotter
what Filipe said.
a UHD BluRay with HDR will have HDR in the main HEVC stream, but HDR10+ and dolby vision are additions on top of that to enable more dynamic HDR. The problem is it really depends on your TVs support. Most TVs that support dynamic HDR, only support Dolby Vision, while a few (notably all Samsung's) only support HDR10+. Basically a format war all over again.
It be nice if a mechanism was figured out to reauthor blurays to support both (especially if one can do it wiithout modifying the core HEVC stream), but have no clue if its possible.
Old 9th August 2019, 09:52   #28695  |  Link
SeeMoreDigital
I have some Dolby Vision (.ts and .mp4 contained) samples where the Dolby Vision meta-data is embedded within the HEVC video stream. And I also have some Dolby Vision samples where the Dolby Vision meta-data is placed within the .m2ts or .mp4 container as a separate stream.
So far all the Dolby Vision encoded discs I have have their Dolby Vision meta-data placed within the .m2ts container as separate stream.
By contrast, I have a couple of HDR10+ encoded discs and their HDR10+ meta-data is embedded within the HEVC video stream.
If people have some samples they would like testing I'm able to do this...
EDIT: Over on the Blu-ray.com forum there's this List of UHDs that contain Dolby Vision topic, which now contains information about whether the disc has been encoded using MEL (10-bit minimal enhancement layer) or FEL (12-bit full enhancement layer).
Cheers
Old 9th August 2019, 19:07   #28696  |  Link
SeeMoreDigital
Actually..... The newer ranges of Panasonic televisions and UHD players support both Dolby Vision and HDR10+
Old 9th August 2019, 23:11   #28697  |  Link
spotter
yes, but not available to US consumers I believe many players support both, but its the TV that really matters. The # of TVs that support both is very small (relative to the size of the market).
Sony was able to add Dolby Vision to their TVs, they have no intent to support HDR10+, but I sort of hope they add it if it gets significant market share
Old 10th August 2019, 18:25   #28698  |  Link
BD Rebuilder v0.60.20
I have updated the first post of this thread with a link to the most recent release of BD Rebuilder (v0.60.20). Changes for this version:
- Added code to work around the TSMUXER
  error: "Can't parse play list file" which
  appears to be associated with certain UHD
  MPLS files.
- Fixed an error in UHD audio extraction in
  which a "Failed to retrieve audio..."
  by TSMUXER message might appear.
- Added steps to audio/video extraction
  routines to try several demuxing methods
  before declaring failure.  Prompted by
  TSMUXER issues associated with UHD.
- Fixed an issue that could prevent BD-RB
  from keeping originals when size permits
  while IVTC_1080P is set -- even when the
  source was not 29.97fps.
- Added a check in automatic audio track
  selection that prevents a mono or stereo
  stream from taking priorty over a multi-
  channel source just because it is a higher
  priority encoding technology.
- Made numerous changes in order to support
  Dolby Vision sources. It needs considerable
  testing and feedback, but has progressed
  significantly.
I would appreciate feedback on the Dolby Vision support. I don't have a player or monitor that supports Dolby Vision -- so your comments are the only way I know if it works properly.
Old 10th August 2019, 20:08   #28699  |  Link
SeeMoreDigital
It is indeed sad that Panasonic products are not readily available for you guys over in the US of A (you don't say where you're from by-the-way).
But good news for the two hundred or-so other countries in the world
Old 11th August 2019, 19:45   #28700  |  Link
BD Rebuilder v0.60.21
I have updated the first post of this thread with a link to the most recent release of BD Rebuilder (v0.60.21). Changes for this release:
- Fixed an error that would prevent muxing of
  Dolby Vision sources that are multipart and
  in which the video is being left intact.
  This might also affect non-Dolby Vision
  sources that have secondary video streams.
- Fixed an issue that would cause oversizing
  when reencoding Dolby Vision sources.  The
  sizing algorithm was not accounting for the
  fixed size of the Dolby Vision track.
