Old 28th February 2020, 22:25   #1381  |  Link
Spunkmeyer
Originally Posted by shodan5000 View Post
When trying to open a source file with the newest beta I only get a message stating:
System.DllNotFoundException: Unable to load DLL 'FrameServer': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Any ideas on how to fix this issue?
Me too, path in error details is pointing to drive D:/Projekte
Suppose I could just install it there as a temp fix but still ;-)
Spunkmeyer is offline
Old 28th February 2020, 22:37   #1382  |  Link
JKyle
App Digger
JKyle's Avatar
Same problem here.
DllNotFoundException (2.0.7.1)
   at StaxRip.FrameServer.CreateAviSynthServer()
   at StaxRip.FrameServer..ctor(String path) in D:\Projekte\VB\staxrip\General\FrameServer.vb:line 12
   at StaxRip.VideoScript.Synchronize(Boolean convertToRGB, Boolean comparePath, Boolean flipVertical) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 246
   at StaxRip.VideoScript.GetInfo() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 437
   at StaxRip.VideoScript.GetFramerate() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 432
   at StaxRip.MainForm.ModifyFilters() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 2263
   at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 1981
JKyle is offline
Old 29th February 2020, 02:15   #1383  |  Link
chipxtreme
Same for me
chipxtreme is offline
Old 29th February 2020, 02:25   #1384  |  Link
Patman
Patman's Avatar
Originally Posted by chipxtreme, JKyle, shodan5000, Spunkmeyer
FrameServer-Error
Copy the FrameServer.dll from zip or folder to C:/Windows/System32. I think Stax will fix that soon
EDIT: doesn't help...
Tools for StaxRip | x264 - x265
Patman is offline
Old 29th February 2020, 03:25   #1385  |  Link
JKyle
App Digger
JKyle's Avatar
This doesn't seem to fix the problem.
There already existed another version of the file, but I replaced it with the one included in the StaxRip zip file. However, the problem still exists.
JKyle is offline
Old 29th February 2020, 03:28   #1386  |  Link
Patman
Patman's Avatar
Hmmm... i have no problem with the new version of Staxrip...
Patman is offline
Old 29th February 2020, 05:21   #1387  |  Link
Mister XY
I have also the same FramServer error
Mister XY is offline
Old 29th February 2020, 06:07   #1388  |  Link
JKyle
App Digger
JKyle's Avatar
Just out of curiosity...
If FrameServer.dll plays such a crucial role in the new Beta version, why don't you put it in the Apps => Manage => Runtimes menu and let users to customize its path?
Sorry if it's against your development philosophy.
JKyle is offline
Old 29th February 2020, 11:25   #1389  |  Link
Taurus
Taurus's Avatar
Originally Posted by chipxtreme View Post
Same for me
Same here...
Taurus is offline
Old 29th February 2020, 12:27   #1390  |  Link
Magik Mark
Same here. Refuses to be copied in the system32 directory
Magik Mark is offline
Old 29th February 2020, 13:48   #1391  |  Link
stax76
stax76's Avatar
Sorry, I'm not super C++ competent, I've not used it often and not in recent years.
I use Windows 10 and in Visual Studio 2019 I used Platform Toolset 'Visual Studio 2019 (v142)', it's the newest and I hope it works when following x64 runtime is installed:
https://support.microsoft.com/en-au/...al-c-downloads
If it doesn't work then it might be the same issue I have with my other C++ library:
https://github.com/stax76/OpenWithPlusPlus/issues/5
The C++ DLL exports C functions, in .NET C functions are called using a technique named pinvoke, which means the .NET runtime loads FrameServer.dll, there is another unrelated FrameServer.dll in system32 (maybe a Windows component), this should not be a problem because the startup directory has a higher priority than the system32 directory.
stax76 is offline
Old 29th February 2020, 14:44   #1392  |  Link
Patman
Patman's Avatar
Maybe this will help with the frameserver. dll error
http://batcmd.com/windows/10/services/frameserver/
That service only exists on win10.
Patman is offline
Old 29th February 2020, 15:40   #1393  |  Link
Spunkmeyer
at StaxRip.FrameServer.CreateVapourSynthServer()
at StaxRip.FrameServer..ctor(String path) in D:\Projekte\VB\staxrip\General\FrameServer.vb:line 14
at StaxRip.VideoScript.GetFrameCount() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 461
at StaxRip.GlobalClass.IsValidSource(Boolean warn) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 684
at StaxRip.MainForm.AviSynthListView_ScriptChanged() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 5196
at StaxRip.FiltersListView.OnChanged() in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 269
at StaxRip.FiltersListView._Lambda$__14-0(VideoScript script) in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 29
at StaxRip.VideoScript.RaiseChanged() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 21
at StaxRip.VideoScript.SetFilter(Int32 index, VideoFilter filter) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 91
at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 2064
Tried all the above hints and Visual Studio, 3.5 gig download etc, happens with both AVS and Vapour.
Oh and Nvenc has been updated again :-)
Old 29th February 2020, 15:50   #1394  |  Link
Magik Mark
Yup. Problem still persisting
Old 29th February 2020, 17:06   #1395  |  Link
stax76
stax76's Avatar
I searched for DllNotFoundException which led to a StackOverflow thread were somebody said:
I ran into this problem and solved with the following:
There's a dependency on msvcr90.dll if you compile under /MD. Try compiling the code with /MT instead.
Project properties > C/C++ > Code Generation > Runtime Library: /MT
I check this setting and it's:
Multi-threaded Debug DLL (/MDd)
I think the problem is I released a debug build, I do it all the time with .NET code and wasn't aware that it can't be done with native code.
Sorry everybody, I'll upload a new build soon.
stax76 is offline
Old 29th February 2020, 17:18   #1396  |  Link
ukmark
Absolutely no need to apologize.
I know we are all very grateful for your efforts.
ukmark is offline
Old 29th February 2020, 19:27   #1397  |  Link
stax76
stax76's Avatar
I hope it's fine now.
2.0.7.2 Beta
- new: showing MediaInfo for the source file works now even if
       the source file is an d2v/dgi index file
- new: improved detection to find out if all video encoder
       command line switches have a GUI implementation,
       (there is still a lot work to do)
- fix: use FrameServer.dll release build instead of debug build
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
stax76 is offline
Old 29th February 2020, 20:06   #1398  |  Link
Patman
Patman's Avatar
2.0.7.2 Beta
The new version with release compiling settings works great!!!
Patman is offline
Old 1st March 2020, 00:06   #1399  |  Link
Magik Mark
Thanks Stax! It' s awesome!
Old 1st March 2020, 09:57   #1400  |  Link
stax76
stax76's Avatar
Thanks for the feedback everybody.
@JKyle
Next build addresses the x265 issues and has also some related improvements.
stax76 is offline
