Old 1st May 2008, 15:08   #221  |  Link
locotus
Just for reporting my beta test:
I just finished my first try to make a single DVD with 3 movies.
Sorry to tell but the final size was way to large the DVD chosen.
For a 4.7 DVD the final resulting size was 6.8GB.
Think about not deleting the m2v and its audio, so user could choose to author manually if as in this case the final output is to big.
Thanks anyway.
locotus is offline   Reply With Quote
Old 1st May 2008, 18:07   #222  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Some questions, locotus
1. 3 movies are usually too much for a dvd. AVStoDVD should have informed you about it by turning red the dvd size bar. Doesn't it?
2. If you do not want to delete temporary process files (m2v, ac3, etc.), click "Settings"/"Misc" and uncheck "Delete temporary process files". Did you do that?
3. Could you post here the log file created by AVStoDVD, which contains a lot of details about your encoding?
4 Are you the dark side of Captain Picard?
Btw, I will add a check to authored filesizes before burning them to dvd.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 1st May 2008, 19:27   #223  |  Link
locotus
Some answers, MrC
1.-I usually get quite good quality in old B&W movies, based mostly on runnig time. This 3 movies were more or less
90 minutes each.
Indeed the program advised me that it will use 4800MB,
but finaly ended in 6.8GB. So I cancelled the job before finishing
the iso file.
2.-I did not make any change in the settings, now I will do it and let you know what happens.
3.-Sorry I deleted the file, and
4.-As Picard I prefer to be the "bald" side.
Thanks for you kindness.
Old 2nd May 2008, 13:43   #224  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Let's waiting for the results and for the next log file.
Bye
MrC
AVStoDVD Homepage
Old 11th May 2008, 16:56   #225  |  Link
wg
Have done several encodes with the latest beta & all have went perfectly. Also did a batch encode of 2 separate dvd structures, 1 full movie on each, & AVStoDVD turned the pc off after 'both' jobs had completed, brilliant! the bug is no more. Also nice to be able to use srt subs. Thanks again MrC
Cheers!
wg is offline   Reply With Quote
Old 12th May 2008, 08:03   #226  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks for the feedback, wg.
Within few days, I will release 2.0.0 "final" version.
Bye
MrC
AVStoDVD Homepage
Old 13th May 2008, 09:01   #227  |  Link
rendez2k
rendez2k's Avatar
Bye
Great news! Whats next on the road map after 2.0? Menu support would be a great addition as some of the known favourites such as FAVC appear to have very few (if any) updates these days.
rendez2k is offline   Reply With Quote
Old 13th May 2008, 16:16   #228  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Well, let's hope not to have too many bugs to fix along with the "Final" distribution, because menu support is surely on my ToDo toplist this summer. Btw, some deepening about my menu structure knowledge is necessary...
Bye
MrC
AVStoDVD Homepage
Old 15th May 2008, 20:14   #229  |  Link
Sir Didymus
Hi MrC!
When I added the menu support in BatchMux (it is the authoring engine you are using to drive MuxMan in your application, right ?), I spent some care - and some time - in order to implement this feature in a way making possible a "simple" integration into applications like your jewel, AVStoDVD...
So I would like to support the kind request from rendez2k...
However, I agree with you on the fact that the mastering of some fundamental elements on the DVD menus is necessary in order to use properly this feature of BatchMux (but nothing too complicated, I can ensure you)...
In the present time I am quite busy with my job, but this summer (hopefully) I would be glad to offer some hints and technical contributions, if you think it can be useful...
Maybe in Italian, in the doom9.it forum, if you like... or via PM...
Cheers,
SD
Sir Didymus is offline   Reply With Quote
Old 16th May 2008, 07:41   #230  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi Sir Didymus!
Thanks a lot for your offer! I am sure your contributions will be very very useful. It will be my must to contact you as soon as I will have some stuff to review or some question to ask.
Let's stay tuned
Ciao
MrC
MrC
AVStoDVD Homepage
Old 18th May 2008, 14:13   #231  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD 2.0.0 Final is available to download
Change log (quite long, includes changes from release 1.2.3, most of them have been included in 2.0.0 betas):
- GUI redesigned
- Added possibility to add more titles to one DVD
- Added log activity window in main form
- Mouse right-click menus enabled in main form
- Added built-in Preview window (uses DirectShow ActiveMovie library quartz.dll)
- Added customizable skins
- Added a new more configurable 'Title Edit' form
- Added configurable Video Encoding Profiles setup (see Help for more details)
- Added CQ prediction calculation and 1-pass VBR encoding with HCenc
- Added support to SubRip (srt) text-based subtitles (using "SubtitleCreator", included in AVStoDVD installer package)
- Added possibility to hard-encode subtitles (using "VobSub" AviSynth plugin (VSFilter.dll), included in AVStoDVD installer package)
- Added 'AudioAmplify' shortcut in 'AviSynth Script Edit' window (now in 'Title Edit' form)
- Added split between 'temporary process' and 'AVStoDVD working' files classification
- Added check on m2v output filesize. If bigger than target, added a transcoding step using ReJig
- Added audio AC3 fixing step when AC3 track is demuxed from the original input file (using "AC3Fix", included in AVStoDVD installer package)
- Added prompt to save project when exiting from AVStoDVD
- Added possibility to make PayPal donations
- Improved AVStoDVD project log file
- Revised bitrate calculation routine and DVD-5/DVD-9 default sizes
- AVStoDVD settings are now stored in the Windows Registry (removed AVStoDVD.ini configuration file)
- HCenc updated to 0.23
- MediaInfo updated to 0.7.6.4
- ImgBurn updated to 2.4.1.0
As usual, comments and suggestions are welcome.
Bye
MrC
AVStoDVD Homepage
Old 18th May 2008, 17:09   #232  |  Link
wg
Thanks for the new version, I haven't converted any projects yet but I've noticed on the jobs list gui the remove symbol is used to move the job up, & vice versa this could be confusing for new users. Not a complaint, just an observation. I realise with all the work involved compiling a new version small issues are easily missed. Hope this helps.
Cheers!
Old 18th May 2008, 19:24   #233  |  Link
Rogi
First, thank you for new version.
I've also spotted that.
Rogi is offline   Reply With Quote
Old 19th May 2008, 08:00   #234  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@wg & Rogi
thanks for "skin" bug report
If you want to do some manual patching, you can go into "\AVStoDVD\Skins\Default" folder and rename these files:
  • A2D_16_13_JobsList_Move.ico -> A2D_16_14_JobsList_Move.ico
  • A2D_16_14_JobsList_Del.ico -> A2D_16_13_JobsList_Del.ico
you can even modify/replace the icons, if you will.
Please, let me know if everything else is ok when you will go thru a full project.
Bye
MrC
AVStoDVD Homepage
Old 19th May 2008, 14:50   #235  |  Link
wg
@wg & Rogi
Bye
Now correct, will do a project soon & report back.
Cheers!
Old 19th May 2008, 16:44   #236  |  Link
RNiK
RNiK's Avatar
UH??
MediaInfo has been updated to 0.7.7.0 on May 16th.
ATTENTION: with MediaInfo 0.7.7.0 some fields have changed, look at Changes.txt for more info.
RNiK is offline   Reply With Quote
Old 20th May 2008, 07:39   #237  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by RNiK View Post
UH??
Thanks for the warning, RNiK. I was aware of that, but I could not include 0.7.7.0 because AVStoDVD 2.0.0 was pretty ready and I did not want to throw in a new MediaInfo release without testing it.
Btw AVStoDVD 2.0.1 will include surely MediaInfo 0.7.7.0.
Bye
MrC
AVStoDVD Homepage
Old 24th May 2008, 15:02   #238  |  Link
wg
I have done 3 encodes with the latest version & all went perfectly. Very impressed with HCenc OPV, used it for the first time(I usually use HCenc 2 pass VBR). Thanks again MrC.
Cheers!
Old 25th May 2008, 13:15   #239  |  Link
ChickenMan
ChickenMan's Avatar
I just did 4 encodes with latest version also with HCEnc OPV, size set to 1110 and elementary streams only. First M2V came out 1050kb (correct ) , next 873kb, next 922kb, next 860kb. I then did 3 more (size set to 1480), first M2V was 1430kb (correct ), next 1440kb (too large and re-jig kicked in and then crashed with a BSOD in my Vista w/SP1), last one after a PC re-start came out 923kb ( thats 35% to small). I re-encoded the last avi using DVD2SVCD with CCE & D2SRoba and it came out at 1360kb, only 5% to small.
Cheers,
CM
ChickenMan is offline   Reply With Quote
Old 25th May 2008, 14:53   #240  |  Link
tacman1123
If Avisynth already installed?
I already have AviSynth installed, so I chose "no" when prompted to (re-)install it. Now it's coming up with an error message saying that it's not found.
I looked for an .ini file to set the path manually to my location, but don't see one. How can I use my currently-installed Avisynth?
I don't want to install another instance of AviSynth, because I have lots of things in my plug-in directory that I need, and I don't want to duplicate them, or to have to explicitly call the plugin.
Thanks! This looks much, much, much easier than going through all the steps at http://xvid.ru/docs/rip/dvd/avsynen.htm (which by itself is a great way to learn about all the steps involved, but at this point I'm much happier with a "Press a Button" solution).
Tac
tacman1123 is offline   Reply With Quote
[IMG] code is Off
