27th May 2016, 02:11 | #14402 | Link | |
Generally, if there is any update(s) available, and you're connected online, when you start Ripbot, it will "look" for any available updates, download them into the Updates folder, and then the next time you start Ripbot, it will do an auto update, using the files in the Updates folder. So every time you start Ripbot it WILL "look" for any updates that Atak has submitted. Providing you're online, and have auto update enabled. And yes, it's still 1.19.3 !!!! |
27th May 2016, 17:09 | #14404 | Link | |
yes! i have auto update enable and i am online right now... |
29th May 2016, 10:31 | #14406 | Link |
no you need intermediate file. BTW i'm not sure if ffmpeg decoder in ffms plugin can decode magicyuv. I recommend utvideo for de mode.
30th May 2016, 22:13 | #14408 | Link |
I figured as much and perfect, UTVideo did the trick (MagicYUV didn't work with FFMS so it encoded locally)! Is it possible to extend that hidden "MoveMKVtoSharedFolder" setting to AVIs? I'd rather not copy a 150+GB file if I don't need to. I noticed RipBot is remuxing the AVI to MKV during the copy...is that necessary? FFMS should work naturally with an AVI file (tested and working with UTVideo at the very least). Not sure if the AVI container affects DE at all but I would think the proper indexing with FFMS and the AVS scripts would take care of the frame serving for distribution.
31st May 2016, 15:04 | #14409 | Link |
Update 2016.05.31
changed: Renamed hidden option MoveMKVtoSharedFolder to MoveFiletoSharedFolder. [hidden settings] MoveFiletoSharedFolder=1
1st June 2016, 15:26 | #14411 | Link |
First post has link to latest version.
1st June 2016, 21:03 | #14413 | Link |
@Atak
Re-requesting a feature about aspect ratio I've met 2/1 ratio like House of Cards (1920x960) and a 2.8/1 on some old movies Is it possible to add those two ratios for a proper 1920x1080?
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
3rd June 2016, 17:11 | #14415 | Link |
Just do not crop your blu-rays if you want full 1920x1080 frame.
6th June 2016, 05:10 | #14416 | Link |
Hi Atak,
I sent you a PM a few days ago asking about preview problems when using the 4K preset. You suggested that I change a setting in FFDshow, which I did, sucessfully. Thankyou. However, when trying to DE some 4K encodes, the other servers, have some major problems, but the most obvious problem is that they don't start, in the queue, so there's something strange going on there, if you are using any other preset, it works fine. The local machine encodes no problem, but there's no "help", from the servers Can't explain it much better than that, sorry. |
8th June 2016, 20:59 | #14417 | Link | |
source file could not be indexed
@omegaeel
Running on W10, passwordsharing off, StoreTempFilesin=H not working: "\\UX-MA\Ripbot264temp\Tools\AviSynth plugins\ffms\ffmsindex.exe" -f -k "H:\temp\Ripbot264temp\Job25\video.mkv working: "\\UX-MA\Temp\Ripbot264temp\Tools\AviSynth plugins\ffms\ffmsindex.exe" -f -k "H:\temp\Ripbot264temp\Job1\video.mkv How to get further with this issue? Anyone could give me support?! Thx |
9th June 2016, 14:42 | #14418 | Link |
Thought I would swing by here and ask if RipBot264 can encode to DD+ (e-ac3)? I have some 7.1 tracks I would like to convert from lossless to lossy for space and don't want to use aac for compatibility reasons.
10th June 2016, 13:53 | #14419 | Link |
After Distributed Encode get error.
C:\>"C:\Users\Zenophobe\Downloads\RipBot264\EncodingClient.exe" "C:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
C:\>"C:\Users\Zenophobe\Downloads\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Zenophobe\Videos\Hunger Games, Mockingjay - Part 2, The (2015) [1080p] [PG-13].mkv" --compression 0:none --title "Hunger Games, Mockingjay - Part 2, The (2015) [1080p] [PG-13]" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:eng --sync 0:0 "C:\Temp\RipBot264temp\job1\1_audio_English.flac" --chapters "C:\Temp\RipBot264temp\job1\chapters.txt" mkvmerge v9.1.0 ('Little Earthquakes') 32bit Error: The file 'C:\Temp\RipBot264temp\video.264' could not be opened for reading: open file error. ------------------------- Elapsed Time: 01h:48m:05s Node Address : 192.168.1.197:1000 Encoded Chunks : 45 of 136 (33%) Encoded Frames : 64792 Encoding Speed : 12 fps Node Work Time : 01:28:56 ----------------------------------- Node Address : 192.168.1.197:3000 Encoded Chunks : 45 of 136 (33%) Encoded Frames : 64747 Encoding Speed : 12 fps Node Work Time : 01:31:35 ----------------------------------- Node Address : 192.168.1.197:2000 Encoded Chunks : 46 of 136 (34%) Encoded Frames : 67478 Encoding Speed : 12 fps Node Work Time : 01:34:51 ----------------------------------- this is an e5 2680 v4 using 3 instances of the distributed encoder. Ideas? |
10th June 2016, 13:54 | #14420 | Link | |
FLAC is built in. Use MAKE MKV to pull audio with video and encode with RIPBOT264 |
