1st February 2017, 20:44 | #14681 | Link |
@Atak_Snajpera
Hi. First of all, thanks for the RipBot distributed encoding...using 32 cores on my LAN I am able to get 30fps with HEVC slow settings. Hust a few suggestions. - Why you still require ffdshow, which are old and no longer maintained? What about switch to LAV Filters? - option to output filename preset... for example if file is INPUT.MKV than after selecting it, output will automatically be named INPUT_HEVC.mkv or whatever I set - option not to demux audio...spare time, when I want to mux external audio later - option to set DEFAULT, FORCED signs to audio/subtitle tracks, and codepage to SRT subtitle tracks (for the muxing part) And one question...what aboout audio delays? If the source file's audio has some delay, will it be maintained after encoding and muxing? |
6th February 2017, 18:50 | #14682 | Link | |
ByteShare
Would that also mean that "BDO strength" doesn't have an affect when doing DE with CQ? |
8th February 2017, 18:25 | #14683 | Link |
ByteShare
DE Stalls
When encoding on 1 machine with 2-4 encoding clients on the 1 machine at the end of the encode the server window (shows the status of each chunk and such) stays open and shows my encoding clients as idle. If I close the server window the completed chunks mux with the audio as desired and I get the file I want.
It doesn't happen with every file. What logs should I provide on files this does happen with? Windows 7 SP1 RipBot 1.19.5 |
8th February 2017, 19:37 | #14684 | Link | |
I think simple screenshot describing this issue should be enough for start. It is always easier for me to understand problem if I can see what you see.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th February 2017 at 19:41. |
9th February 2017, 07:53 | #14685 | Link | |
Windows 10 |
9th February 2017, 16:27 | #14687 | Link | |
ByteShare
I had it happen not long ago, but didn't take a screen capture; I'll take a screen capture next time. The log for the encode is this, Main: Code:
C:\>"C:\Users\[User]\Desktop\RipBot264v1.19.5\EncodingClient.exe" "C:\Temp\RipBot264temp\job73\job73_EncodingClient.meta" C:\>"C:\Users\[User]\Desktop\RipBot264v1.19.5\tools\mkvtoolnix\mkvmerge.exe" -o "C:\A\Batman Beyond s01e01 rebirth (p 1) (DVDRemux).mkv" --compression 0:none --title "Batman Beyond s01e01 rebirth (p 1) (DVDRemux)" --default-duration 0:24.27fps "C:\Temp\RipBot264temp\video.265" --compression 0:none --language 0:und --aac-is-sbr 0:0 "C:\Temp\RipBot264temp\job73\Encoded_Audio_1.aac" mkvmerge v9.8.0 ('Kuglblids') 32bit 'C:\Temp\RipBot264temp\video.265': Using the demultiplexer for the format 'HEVC/h.265'. 'C:\Temp\RipBot264temp\job73\Encoded_Audio_1.aac': Using the demultiplexer for the format 'AAC'. 'C:\Temp\RipBot264temp\video.265' track 0: Using the output module for the format 'HEVC/h.265 (unframed)'. 'C:\Temp\RipBot264temp\job73\Encoded_Audio_1.aac' track 0: Using the output module for the format 'AAC'. The file 'C:\A\Batman Beyond s01e01 rebirth (p 1) (DVDRemux).mkv' has been opened for writing. 'C:\Temp\RipBot264temp\video.265' track 0: Extracted the aspect ratio information from the HEVC video data and set the display dimensions to 716/536. The cue entries (the index) are being written... Multiplexing took 2 seconds. ------------------------- Code:
Node Address : 10.10.10.5:1000 Encoded Chunks : 6 of 22 (27%) Encoded Frames : 8631 Encoding Speed : 4 fps Node Work Time : 00:33:57 ----------------------------------- Node Address : 10.10.10.5:2000 Encoded Chunks : 5 of 22 (23%) Encoded Frames : 7210 Encoding Speed : 4 fps Node Work Time : 00:30:01 ----------------------------------- Node Address : 10.10.10.5:3000 Encoded Chunks : 6 of 22 (27%) Encoded Frames : 8991 Encoding Speed : 4 fps Node Work Time : 00:35:07 ----------------------------------- Node Address : 10.10.10.5:4000 Encoded Chunks : 5 of 22 (23%) Encoded Frames : 7207 Encoding Speed : 4 fps Node Work Time : 00:30:03 ----------------------------------- in this case seems to have been stuck for about 3.5 hours. |
9th February 2017, 19:18 | #14688 | Link | |
9th February 2017, 19:25 | #14689 | Link |
ByteShare
Here is a screen cap of the issue:
http://imgur.com/a/opFts I might have been wrong, looks like the encoding clients do turn off |
9th February 2017, 19:27 | #14690 | Link |
What has happened to those buttons? Did encoding client combine chunks?
Update: I reckon that application is unable to completely close main form after work. It looks like it hung after form1.close command. Weird...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th February 2017 at 19:43. |
10th February 2017, 17:23 | #14692 | Link |
ByteShare
I can confirm since switching over to the full/official 19.5 (not just the update from 19.4 to 19.5) something has changed with the window behavior in Windows 7. I haven't tested on Windows 8. I know you applied some fixes for loosing window control that I know I personally had with the server window in Windows 8.
I used to use a program called Turbo Mouse (clicks for you really fast) so I could move things around the queue with less work and faster, but not the program no longer works in the RipBot window, but still works in other applications normally. I wonder if this is related to the issue with the server window getting stuck open and not auto muxing a video on complete when in DE mode? |
10th February 2017, 21:40 | #14693 | Link |
Tomorrow I will post improved EncodingClient for testing. It should fix all those odd behaviours (stalls and so on). I've just noticed that I had very ugly code here and there remembering 1.17.x times.
11th February 2017, 15:40 | #14695 | Link |
byteshare check this http://www.mediafire.com/file/zat5jd...dingClient.exe
11th February 2017, 16:47 | #14696 | Link | |
ByteShare
I'll let you know how it goes |
11th February 2017, 18:49 | #14697 | Link |
Take your time. I can wait few days...
12th February 2017, 03:48 | #14698 | Link |
ByteShare
Hasn't been stalling like before, but I did get an unusual crash (went through 13 encodes no problem rather than the 1-5 before a stall):
Problem signature: Problem Event Name: APPCRASH Application Name: EncodingClient.exe Application Version: 1.7.0.0 Application Timestamp: 2a425e19 Fault Module Name: StackHash_75b5 Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: 00000000 Exception Offset: 00000000 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 75b5 Additional Information 2: 75b52eca4d1a1e3be01b2a7f70df718c Additional Information 3: 47c1 Additional Information 4: 47c1690b41f4145092bfe6c76f595c85 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Doesn't show much but the job log file: Code:
C:\>"C:\Users\Money\Desktop\RipBot264v1.19.5\EncodingClient.exe" "C:\Temp\RipBot264temp\job125\job125_EncodingClient.meta" C:\>"C:\\RipBot264v1.19.5\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Stephen Colbert 2017 01 13 Cuba Gooding Jr 720p HDTV x264-FLEET.mkv" --compression 0:none --title "Stephen Colbert 2017 01 13 Cuba Gooding Jr 720p HDTV x264-FLEET" --default-duration 0:60000/1001fps "C:\Temp\RipBot264temp\video.265" mkvmerge v9.8.0 ('Kuglblids') 32bit 'C:\Temp\RipBot264temp\video.265': Using the demultiplexer for the format 'HEVC/h.265'. 'C:\Temp\RipBot264temp\video.265' track 0: Using the output module for the format 'HEVC/h.265 (unframed)'. The file 'C:\Stephen Colbert 2017 01 13 Cuba Gooding Jr 720p HDTV x264-FLEET.mkv' has been opened for writing. 'C:\Temp\RipBot264temp\video.265' track 0: Extracted the aspect ratio information from the HEVC video data and set the display dimensions to 1280/720. The cue entries (the index) are being written... Multiplexing took 6 seconds. ------------------------- Elapsed Time: 02h:21m:23s Last edited by byteshare; 12th February 2017 at 04:01. |
12th February 2017, 22:20 | #14700 | Link |
Hi Atak_Snajpera, I've noticed a problem with the last two blu-rays I've tried to recode. I'm using 1.19.5 and distributed encoding with a total of 4 computers. For some reason one of the chunks is much smaller and at a much lower bit rate than all the rest. If you look at my attachments, block 1.264 is much smaller than all the other following pieces despite it's similar 1 minute duration. The video is highly pixellated and macroblocked compared to all the following pieces which encoded properly. This occurred with another movie but it was more towards the end of the movie. Again it was only one block with all the rest being normal. Please let me know if there is any other info you require. Thanks.
