15th March 2018, 19:57 | #15681 | Link |
It works for others but not for you ,so it means that problem is on your side. Simple. Do not waste your time...
15th March 2018, 20:18 | #15682 | Link | |
And it can't be determined by the errors given and logs, so I can solve this and get it working for me also? Regards MaistroX Last edited by MaistroX; 15th March 2018 at 21:14. |
15th March 2018, 21:10 | #15683 | Link |
Try running Ripbot264 DE mode on virtual machine (win7 SP1 x64).
15th March 2018, 21:21 | #15685 | Link |
You do not have to activate win7. This ISO is good
https://thepiratebay.org/torrent/722...hed___Windows7
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th March 2018 at 21:23. |
15th March 2018, 21:55 | #15686 | Link | |
And still The HardWare I have dont support Win7, that why I was forced to upgrade to Win10. + Torrents, thatīs a no-go! |
16th March 2018, 00:01 | #15687 | Link | |
https://www.w7forums.com/threads/off...wnloads.12325/
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
16th March 2018, 01:32 | #15688 | Link | |
Maybe you should consider trying Atak's "Windows 7 Image Updater" !! Windows 7 SP1 x64 Professional, or Ultimate, should support most modern hardware. |
16th March 2018, 10:14 | #15690 | Link | |
Ryzen is FULLY supported on win7! https://support.amd.com/en-us/downlo...s%207%20-%2064 APU also works. You just have to re-add few entries in main GPU driver (.inf). ThreadRipper is also working without any issues! https://hardforum.com/threads/thread...ost-1043435113
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th March 2018 at 22:35. |
24th March 2018, 17:25 | #15692 | Link |
Hi.I have a little problem with HEVC profiles.Everything works fine when I encode with default Main10 or Main8 progressive profile,but when I want to tune preset with Slow and Animation option I got an error.Can you tell me what's wrong?
27th March 2018, 14:19 | #15693 | Link |
I just wanted to write again about the bug that replaces a job if your editing or setting options for a newly demuxed job during the combining/muxing phase. The job that is being muxed will have it's job number and title changed to the job that is being edited. Stopping Ripbot264, editing jobs.list and manually fixing the replaced line with the correct job number and the name brings the job back after starting Ripbot264 back up.
30th March 2018, 14:44 | #15694 | Link |
Recommendation?
Sorry if this is the wrong place Atak and everyone else, Your program has worked very well for years, thank you for your effort in creating it.
Would you be able to recommend or create an easy to use program that would edit mp4 metadata, specifically adding the cover images to existing files? Ripbot works for new encodings of course. But I have about 10,000 mp4s I've made that I would like to add this data to. All tv seasons so they would only need the same cover for each season. (I travel where there is no streaming for weeks at a time) I'd pay good money for a program that can do this :-) Thanks in advance, Have a good one. Just in case anyone is asking how am I bringing this data around, Its easy, Run twonky on a tall Intel NUC with 2.5tb internal storage and two tiny 4tb WD drives :-). VLC on tablet/phone for playback. |
31st March 2018, 13:03 | #15695 | Link | ||
Encode fails after Auto update
Normally RipBot 1.22.0 generates me a file job9.avs which contains a line:
My solution is to disable Auto Update and do a reinstall of RipBot and everything works again. |
31st March 2018, 13:15 | #15696 | Link | |
You mentioned 1.22.0, should be 1.22.2..with a Ripbot.exe build date of 28/03/18. Have got avisynth up to date (in Tool's folder) Last edited by burt123; 31st March 2018 at 13:19. |
31st March 2018, 14:46 | #15697 | Link |
@george84
My solution is to add ConvertToYV12(matrix="rec709") to your PhotoDirList.xml.smil.avs. Problem solved.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 31st March 2018 at 14:59. |
31st March 2018, 17:45 | #15699 | Link |
no .
31st March 2018, 18:15 | #15700 | Link | |
Yesterday I was running 1.21, than there was an automatic update, which caused problems. Then I downloaded 1.22.0 and it worked again. Today in the morning everything worked, at noon there was an automatic update which caused problems. |
