19th November 2017, 14:05 | #5761 | Link |
Well, maybe I misinterpreted these brief reports.
Your analysis seems to suggest that MeGUI should "temporarily register AviSynth to the local copy" if AviSynth was not yet installed in the system? I hope I understood this time. |
19th November 2017, 14:12 | #5762 | Link |
Yes. Installing Avisynth is not necessary but these 3 entries must be there. Xvid will then use the standard Windows search hierarchy to look for avisynth.dll/devil.dll. However, auto-loading plugins will not work without additional registry entries.
Groucho's Avisynth Stuff |
19th November 2017, 14:19 | #5763 | Link |
I guess these will have been redirected to MeGUI's selection while it is active, anyway.
_ P.S.: But that also means that making xvid_encraw use native AviSynth API would be quite an overhaul? That may not be worth the efforts, with an expectable obsolescence... Last edited by LigH; 19th November 2017 at 14:38. |
19th November 2017, 14:51 | #5764 | Link |
Definitely not worth it.
19th November 2017, 18:08 | #5766 | Link | |
My report in the other forum really was not very precise. But the reg keys pointed out by Groucho are the ones who have been reported missing by Process Monitor and after writing them everything is fine. MeGUI will now check first if those exist and if not it will create them (in the HKCU part). Directly after xvid starts they will be removed again.
These are the keys (stripped down to the bare minimum): Quote:
2779 [Xvid] added a workaround to be able to use Xvid in portable AviSynth mode 2778 [Chapter] fixed non-ASCII handling (regression of 2753). bug #898 2777 [Settings] changed the default value of "delete completed jobs" to be enabled 2776 [OneClick] added support for MKV attachments. If the MKV source does have such attachments, it will be copied to the target MKV. feature request #617 |
19th November 2017, 18:24 | #5768 | Link | ||
With the recent issue posts about lsmash I think about to move the default priority back to ffms. |
19th November 2017, 22:37 | #5770 | Link |
2784 [AVS Script Creator] fixed DirectShowSource/AVISource not available if the portable AviSynth is used. bug #896 DirectShowSource/AVISource are disabled by default and have to be enabled in the MeGUI settings 2783 [AVS Script Creator] improved the file extension filters of the "video input" file open dialogue 2782 [L-SMASH Indexer] delete always the index file after it has been copied (and not only when "delete intermediate files" is selected) 2781 [Settings] removed "improved AVS opening" setting. It is now always enabled. 2780 [Update] removed the abort button |
20th November 2017, 19:03 | #5772 | Link |
Thanks, but I will wait for 3.35:
https://forum.doom9.org/showthread.p...50#post1824950 3.33 seems to be fine for the MeGUI functions used for the moment. |
21st November 2017, 10:49 | #5773 | Link |
There are also new LAME binaries: http://www.rarewares.org/mp3-lame-bundle.php
EDIT: Bug: Since Build 2784 (propably 2783) I can't select *.mpls files in the AVS script creator at video input as "All supported files". I have to change to "All files(*.*)" Last edited by Morku; 21st November 2017 at 15:07. |
21st November 2017, 20:43 | #5774 | Link | ||
MPLS is also not in the default file open filter of the file indexer. Are there any other filters missing? |
21st November 2017, 21:10 | #5775 | Link | |
21st November 2017, 21:31 | #5776 | Link |
Thats weird. I use Windows Defender and it's not detecting a virus. Also virustotal gives a good reputation: https://www.virustotal.com/de/file/3...is/1511295863/
If not a bug, can I change the behaviour to make "All files (*.*)" as default? Since DGIndexNV supports mpls files, I prefer this way over finding out the m2ts files (especially when the movie is parted in many m2ts files). |
21st November 2017, 21:43 | #5777 | Link | |
Care to tell what AV your using Zathor? Sent from my SM-G935F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else. |
21st November 2017, 21:43 | #5778 | Link | |
Btw why do you open the mpls in AVS Creator? Why not directly with file indexer / oneclick? |
21st November 2017, 22:04 | #5779 | Link |
Uh, good question. I have never tried the One Click before, so I use the "manual way" for years. I use AVS Creator to index the file and crop if necessary, "HD streams extractor" to get subtitles and audio. Convert audio with a bat, convert subs with SubtitleEdit and after all bring together with MeGUI. But I will have a look into the One Click Encoder
21st November 2017, 22:29 | #5780 | Link |
OK, but then AVS Script Creator will just open the File Indexer, a bit faster would be to open directly the file indexer.
I will implement MPLS support in the same way as with IFO so that also the other indexers will work. DGIndexIM/NV will directly use the mpls, for the others eac3to will demux it. |
