14th December 2015, 04:33 | #1321 | Link |
http://lamexp.sourceforge.net/doc/FAQ.html#9fd53558
Is it really this hard to rename the LameXP executable? Cheers manolito |
14th December 2015, 21:40 | #1322 | Link |
Software Developer
18th December 2015, 15:17 | #1323 | Link | |
edit: Actually it's not that simple it seems. The portable version LM posted has very different file size. Last edited by Octo-puss; 18th December 2015 at 19:12. |
19th December 2015, 20:55 | #1324 | Link | |
Software Developer
Another reason for different file size is that the compiler/linker could have "optimized out" the function that checks for "portable mode" at runtime, as it now doesn't get called at all. That would only be a few bytes though. And, of course, the size of a compressed file will always differ to some extent, even if you change the input file only very slightly. It's like rolling the dice again...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th December 2015 at 20:59. |
20th December 2015, 20:12 | #1326 | Link |
Software Developer
Effect would be the same, yes
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th December 2015 at 23:50. |
25th December 2015, 13:25 | #1327 | Link |
As depicted by the christmas tree on the encode process of 2014's LameXP, it seems you have trackback access to LameXP, so I blocked it with a firewall.
Just wanted to let people know that this program has access to internet, fishy to say the least (no info on this nonconsent action is elaborated on FAQ). |
25th December 2015, 13:45 | #1328 | Link | |
Software Developer
And I even have less of an idea what you think you "blocked with a firewall", because the only Internet/network communication LameXP will ever do is for checking for updates. If you don't want that, just don't make it check for updates...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 26th December 2015 at 18:03. |
25th December 2015, 13:55 | #1329 | Link | |
FYI, original here (link). |
25th December 2015, 13:59 | #1330 | Link | |
Software Developer
(Yes, there is a christmas tree icon in the upper left corner. So far, so obvious. But that's neither a new "feature", nor a particularly interesting one. What's the relevance of pointing this out?)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 26th December 2015 at 18:11. |
27th December 2015, 22:01 | #1332 | Link |
Life's clearer in 4K UHD
Please give it a rest Dogway!
3rd January 2016, 12:47 | #1333 | Link |
sox temp folder didn't change with lamexp temp folder, and if I had low space in c:\ lamexp will encode 12 kb file with ogg and normalization
unless I did it in cmd and put --temp "E:\temp" in sox
See My Avisynth Stuff Last edited by real.finder; 3rd January 2016 at 13:01. |
3rd January 2016, 16:10 | #1334 | Link | |
Software Developer
LameXP does explicitly set the "working" directory for the SoX process, to the user-selected TEMP directory. However, the function that actually launches the process was overriding the "working" directory to where the EXE file resides Try with this TEST build please: http://sourceforge.net/projects/lame...4.exe/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd January 2016 at 20:07. |
3rd January 2016, 17:19 | #1335 | Link | |
See My Avisynth Stuff |
9th January 2016, 13:35 | #1336 | Link |
I get an error when i tried to convert. dts audio file to. aac. What should i do?
http://i.cubeupload.com/hIrU7I.jpg |
9th January 2016, 13:39 | #1337 | Link | |
Software Developer
9th January 2016, 21:02 | #1338 | Link |
I've been doing some tests using the DCA encoder (dcaenc-2) and have noticed that when I play the multi-channel encodes using my Oppo and LG television (and pass the bit-stream to my surround sound amplifier) the audio sounds distorted.
I can confirm that the 768Kbps dts encode sounds much less distorted than the 1536Kbps dts encode. The strange thing is, the same encodes sound fine when played using MPC-BE with LAV! Any ideas what might be causing this?
31st January 2016, 16:42 | #1339 | Link | |
Software Developer
LameXP v4.14 Alpha 2
http://sourceforge.net/projects/lame...1.zip/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 4th February 2016 at 21:01. |
3rd February 2016, 15:03 | #1340 | Link |
A person called Case (foobar2000 forum) has continued to develop fhg aac:
Here and Here I tried to LameXP but not working, why it is not compatible? Edit: these are two files. Last edited by GMJCZP; 3rd February 2016 at 15:33. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
