Old 27th September 2015, 17:15   #4721  |  Link
Barough
Barough's Avatar
Originally Posted by Morku View Post
Another question:
Why does the updater delete any other file when tools get updated?
For example, when I got the qaac update, I had to copy back the DLL files from Apple to make qaac work again.
<snip>
Was about to ask the same myself. The update function didn't remove them earlier.
All files in the QTfiles folder got renamed to *.backup after the latest qaac update
Old 27th September 2015, 17:24   #4722  |  Link
Zathor
2598 [Log]                  delete log files after 90 days
2597 [QAAC]                 do not delete portable dll files during update
2596 [DGIndexIM/NV]         improved error handling
2595 [DGIndexIM/NV]         fixed crash when the indexer directory is not available (regression of 2585)
Old 27th September 2015, 17:30   #4723  |  Link
Barough
Barough's Avatar
Thnx for the fixes Zathor
Old 27th September 2015, 20:13   #4724  |  Link
hello_hello
Zathor,
MeGUI 2598 is deleting the SelectedProfiles.xml file when it runs (or when it closes) and as a result, the selected profiles function is broken. Edit: I tried copying SelectedProfiles.backup and renaming it to SelectedProfiles.html and the html file isn't being deleted when MeGUI starts any longer, but MeGUI seems to be ignoring it anyway. Something odd is going on there.
Creating backups for all the profiles, that's new isn't it? Is there a reason for doing so? (I'm just curious)
I'll upload my OneClick profiles for you shortly.
Cheers.
Old 27th September 2015, 20:28   #4725  |  Link
hello_hello
Seems the change to not delete the portable files when updating QAAC isn't working as expected. MeGUI is isn't deleting them, but it's changing their file extensions to "backup".
Feature request:
Could we have an option for MeGUI not to delete old files, such as old log files? The latter certainly took me by surprise after the last update. It also annoyed me a bit. I sometimes search through old log files to help me remember what filtering I might have used for a particular encode, or what the source file was etc, and up until a few minutes ago I could use the Windows search function to quickly search through three or fours years worth of log files. Now it only goes back a few months.....
"Fortunately" my second PC had a hard drive failure a few days ago, so I copied the MeGUI folder from this PC to the other one and I now know to at least backup those log files before updating MeGUI there.
And those old files in the update_cache folder marked as obsolete..... I backed that folder up as soon as a saw it happen, but what should I expect there? I assume at some stage MeGUI will delete them all without asking?
Old 27th September 2015, 20:48   #4726  |  Link
hello_hello
Originally Posted by Zathor View Post
I have tried to reproduce the OnceClick profile button oddness with my virtual XP machine and there ii works also as expected. Are you able to upload your profiles which you use for the test?
I created two new profiles, as mine use my own encoder configurations, so they'd probably give you errors when you try to load them. These OneClick profiles use "scratchpad" encoder and avisynth presets, but the oddness hasn't changed.
no video encode profile:
<?xml version="1.0"?>
<GenericProfileOfOneClickSettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <Name>no video encode</Name>
  <Settings>
    <VideoProfileName>x264: *scratchpad*</VideoProfileName>
    <AvsProfileName>AviSynth: *scratchpad*</AvsProfileName>
    <PrerenderVideo>false</PrerenderVideo>
    <AudioProfileName>migrated</AudioProfileName>
    <AudioEncodingModeString>migrated</AudioEncodingModeString>
    <AudioSettingsString>
      <OneClickAudioSettings>
        <AudioEncodingModeString>Always</AudioEncodingModeString>
        <Language>[default]</Language>
        <Profile>FFmpeg AC-3: *scratchpad*</Profile>
        <UseFirstTrackOnly>true</UseFirstTrackOnly>
      </OneClickAudioSettings>
    </AudioSettingsString>
    <DontEncodeVideo>true</DontEncodeVideo>
    <SignalAR>false</SignalAR>
    <AutomaticDeinterlacing>false</AutomaticDeinterlacing>
    <AutoCrop>true</AutoCrop>
    <KeepInputResolution>true</KeepInputResolution>
    <OutputResolution>720</OutputResolution>
    <Filesize xsi:nil="true" />
    <SplitSize xsi:nil="true" />
    <ContainerCandidates>
      <string>AVI</string>
      <string>MKV</string>
    </ContainerCandidates>
    <LeadingName />
    <WorkingNameReplace />
    <WorkingNameReplaceWith />
    <UseChaptersMarks>true</UseChaptersMarks>
    <UseNoLanguagesAsFallback>false</UseNoLanguagesAsFallback>
    <DisableIntermediateMKV>false</DisableIntermediateMKV>
    <DefaultWorkingDirectory>D:\</DefaultWorkingDirectory>
    <DefaultOutputDirectory>D:\</DefaultOutputDirectory>
    <DefaultLanguage>English</DefaultLanguage>
    <DefaultAudioLanguageString>
      <string>English</string>
    </DefaultAudioLanguageString>
    <DefaultSubtitleLanguageString>
    </DefaultSubtitleLanguageString>
    <IndexerPriorityString>
      <string>DGI</string>
      <string>DGM</string>
      <string>D2V</string>
      <string>LSMASH</string>
      <string>FFMS</string>
      <string>AVISOURCE</string>
    </IndexerPriorityString>
  </Settings>
</GenericProfileOfOneClickSettings>
with video encode profile:
  <Name>with video encode</Name>
  <Settings>
    <DontEncodeVideo>false</DontEncodeVideo>
    <KeepInputResolution>false</KeepInputResolution>
    <LeadingName />
  </Settings>
Old 27th September 2015, 22:27   #4727  |  Link
Zathor
I need to test it with backup enabled.
EDIT: works as expected. are you sure qaac has been updated with build 2598? Or which portable files do you use?
Mhm, I can merge this option with the backup option. So if backup is disabled it will delete the files, if not they stay.
Old 27th September 2015, 22:47   #4728  |  Link
Zathor
The file extension is xml
I found the problem and have fixed it locally.
Yes, if the new xml file cannot be created the backup will be restored. But as this will be done in one step I should delete the backup files at the end.
Old 27th September 2015, 23:07   #4729  |  Link
hello_hello
I wrote xml the first time, but now I can't remember whether I renamed it xml or html for testing. Oh well.... you've found the problem anyway.
Old 28th September 2015, 17:21   #4730  |  Link
LeMoi
With latest version (2598), every time I launch the program, my default video profile always changes to x264: Android G1, instead of the one i always use. This did'nt happen with previous versions...
LeMoi is offline   Reply With Quote
Old 28th September 2015, 18:51   #4731  |  Link
Zathor
2601 [OneClick]             fixed DAR button behaviour
2600                        obsolete packages and log files will only be deleted if the backup option is disabled
2599 [Profile]              fixed unsaved selected profile (regression of 2590)
Old 28th September 2015, 23:08   #4732  |  Link
hello_hello
Awesome! I haven't downloaded the update yet, but thanks!
So the OneClick DAR button problem..... I wasn't imagining it? What was the cause?
Cheers.
Old 28th September 2015, 23:10   #4733  |  Link
LeMoi
Can't find the update yet with the MEGUI included updater?
Old 28th September 2015, 23:12   #4734  |  Link
kotuwa
Today I updated MeGUI. Development Servers.
and faced a thing that I never faced yesterday. Not sure whether the reason is the updating it or something else changed in the system.
FFAudioSource failed to open a MKV file, that was opened successfully before updating.
It gives this message in the Log.
Failed opening the file with FFAudioSource(). Script error: There is no function named 'HelpMeRondaLoadPlugin'.
NicAudio, LWLibavAudioSource used for AC-3, LWLibavAudioSource used for MKV as FFAudioSource fails.
Any idea why, and how to fix!
kotuwa is offline   Reply With Quote
Old 28th September 2015, 23:18   #4735  |  Link
hello_hello
Sorry, I missed your question earlier.
Yes, I'm sure QAAC was updated. It went through the "build 2598 is required" process on both PCs and restarted MeGUI before then updating QAAC.
QAAC is in the "MeGUI\tools\qaac" folder.
The portable files are located in "MeGUI\tools\qaac\QTfiles"
QTfiles has a subfolder: "MeGUI\tools\qaac\QTfiles\Microsoft.VC80.CRT"
All the files in the "QTfiles" and "Microsoft.VC80.CRT" folders had backup added as their file extension.
At least it's not just me this time.
http://forum.doom9.org/showthread.ph...28#post1740628
Old 28th September 2015, 23:24   #4736  |  Link
Zathor
Sorry, silly remaining code in the sources. It is now fixed with build 2602 (online on one of the two servers as the other is currently not available)
Old 28th September 2015, 23:26   #4737  |  Link
Zathor
I have all necessary files directly copied in the qaac directory without any subdirectories. Can you try that as well please? Btw I have used the recent makeportable script with the recent Itunes installer.
Old 29th September 2015, 00:23   #4738  |  Link
kuchikirukia
Could we get finer control of x264 qcomp? In 2525 you can manually enter it in the box and it will enter it into the commandline, but MeGUI rounds to tenths it for display which gives a display mismatch (if you entered 0.65 you can't just look at the qcomp box to see what you have entered since it's now saying 0.7.), and the arrows move it by tenths. Considering the rather large effect, movement by hundredths makes more sense than tenths, and it should certainly display to hundredths. Going from qcomp of 0.6 to 0.7 can increase file size in CRF encoding upwards of 25%, and 0.8 is pretty much always going to be complete bloat, so going by tenths basically only gives you the option of, "Do I want qcomp 0.60 or 0.70?"
kuchikirukia is offline   Reply With Quote
Old 29th September 2015, 03:46   #4739  |  Link
hello_hello
I tried that and some of the files had the extension backup added and some didn't. Here's a list of the extracted Apple files before re-installing QAAC:
From the QTfiles folder
ASL.dll
CoreAudioToolbox.dll
CoreFoundation.dll
icudt46.dll*
icuin40.dll*
icuuc40.dll*
libdispatch.dll
libicuin.dll
libicuuc.dll
objc.dll
pthreadVC2.dll*
From the Microsoft.VC80.CRT folder
Microsoft.VC80.CRT.manifest*
msvcp80.dll*
msvcr80.dll*
After copying all the files to the qaac directory and re-installing QAAC, the files marked with an asterisk were given a backup extension. The others weren't (as opposed to when they were left in the sub-directories and they were all given a backup extension).
The four original QAAC files in the QAAC folder remained, with a backup copy also created. I guess that's to be expected.
libsoxconvolver.dll
libsoxr.dll
qaac.exe
refalac.exe
I used makeportable and the QuickTime installer to extract the required files. I'm pretty sure it was makeportable 0.9 and QuickTime 7.7.7, but to be sure I downloaded them both again (QuickTime 7.7.8) and ran makeportable. Exactly the same files were extracted (still CoreAudioToolbox 7.9.8.3), just with more recent modified dates.
You're not using an old makeportable or QuickTime installer are you? I'm pretty sure the files extracted changed at some stage, but that was a fair while ago. Or does it extract different files for XP....
Cheers.
Old 29th September 2015, 04:27   #4740  |  Link
kotuwa
Hey, updated to 2602.
Now a different error message...
Failed opening the file with FFAudioSource(). I don't know what 'xxxx' means.
