Old 13th September 2012, 19:44   #41  |  Link
@Anarchitektur
Please stop posting images with torrent file names. I have deleted your last post.
Old 13th September 2012, 21:21   #42  |  Link
z_mashine
z_mashine's Avatar
Originally Posted by dlind87 View Post
I really like this version of mpc but there is one (for me) major problem: I use middle mousebutton to play/pause the video in all my players, but unbinding left mousebutton in mpc-be removes the ability to move the window when clicking in the video area. Any chance to "fix" that?
This bug is already fixed. Wait for new builds.
z_mashine is offline   Reply With Quote
Old 13th September 2012, 21:37   #43  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Small suggestion. Maybe you want to hide menu by default and instead make this button that firefox (and some other software) uses? But using black color of course =)
Keiyakusha is offline   Reply With Quote
Old 13th September 2012, 21:37   #44  |  Link
Superb
Originally Posted by z_mashine View Post
O -> Playback -> Auto-zoom
Not the same. SD video is re-sized to a larger window...
Superb is offline   Reply With Quote
Old 13th September 2012, 21:45   #45  |  Link
filler56789
SuperVirus
filler56789's Avatar
Hiding or showing the menu bar should be somewhere in the "Options" window.
By default, the menu bar should be turned ON always
Old 13th September 2012, 21:54   #46  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I know.
Who says that? That orange button on screenshot replaces menu. Why you need 2 menu at once?
In case of this option is implemented, you'll go in options and turn old menu on if you need it. It also should be available by pressing alt of course.
Old 13th September 2012, 22:33   #47  |  Link
z_mashine
z_mashine's Avatar
Set Auto-zoom to 100%.
Old 13th September 2012, 22:59   #48  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Already fix - wait next release.
Old 14th September 2012, 01:01   #49  |  Link
turbojet
What needs to be done to open every video as a maximized window?
In HC all that's needed is save window size/position. This doesn't work every time in BE.
Old 14th September 2012, 01:28   #50  |  Link
wanezhiling
Originally Posted by Anarchitektur View Post
hmm... it works even with do not use d3d and with blt mode
Only madVR and standard EVR can support that.
If you use EVR-CP or VMR9 Renderless, you must set"d3d9ex flip win7"
Old 14th September 2012, 01:52   #51  |  Link
Anarchitektur
it seems you are right, i didn't restart player before trying new settings, but that has nothing to do with mcp-be, so Ill skip further conversation about this topic
Anarchitektur is offline   Reply With Quote
Old 14th September 2012, 02:02   #52  |  Link
Aleksoid1978
Originally Posted by VipZ View Post
Sorry I wasn't too clear on this and put steps in detail below,
1. Make sure "Use the preview in the search" is enabled.
2. Ensuring MPC is closed launch a video media file via file association, the bigger the file and slower the disk the better to catch this.
3. Before MPC has had a chance to load the media file and display a video frame, attempt to change the volume as quick as you can with the mouse wheel.
4. MPC window should now stall and crash.
I have confirmed this that is happens 100% of the time on multiple systems providing you catch it on time. Disabling "Use the preview in the search" will result in no crashes in the above steps.
I have also noticed other crashes if you interact with the GUI as media is loading but this one is random and cant put down steps to reproduce but I assume this would be the same bug.
Can't reproduce this bug myself. Can you make a video - i see what you do and what happen.
Old 14th September 2012, 09:53   #53  |  Link
VipZ
Here's the video for you, http://www.mediafire.com/?cd8att53q2m1gts
The above was made with a clean system with this being the 1st run/setup of MPC-BE. The 1st run I missed the timing but the 2nd was good, where when changing the volume while MPC-BE's status bar was saying opening.
Hope this helps.
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 14th September 2012, 10:49   #54  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Hope this helps.
I confirm, I was able to replicate this problem.
VipZ, if not difficult for you, then perform the test on all types of renderer in mpc-be.
I have the following results:
EVR Cust - bug
EVR - bug
VMR7 R - bug
VMR9 R - bug
VMR7 W - good
VMR9 W - good
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 14th September 2012, 13:51   #55  |  Link
VipZ
EVR Cust - bug
EVR - bug
VMR7 R - bug
VMR9 R - bug
VMR7 W - good
VMR9 W - good
Here's my results,
madVR - easy to produce
EVR Cust - easy to produce
EVR - easy to produce
VMR7 R - bit hard to produce, but its very doable
VMR9 R - easy to produce
VMR7 W - harder to produce by dropping files quickly onto window and changing volume, possibly something totally different
VMR9 W - harder to produce by dropping files quickly onto window and changing volume, possibly something totally different
EVR Custom is by far the easiest of the lot to produce the bug.
Old 15th September 2012, 11:07   #56  |  Link
Aleksoid1978
Try this build - http://rghost.ru/40373713
I disable hot key while do loading meida.
Old 15th September 2012, 12:19   #57  |  Link
VipZ
Thanks, with this build I cant seem to generate a crash with changing volume any more. Could I make a suggestion in that maybe disable dropping media onto window while media is loading loading as well to prevent crashing in that regard?
Also thanks, SHOUTcast is working nicely and the title's are a nice touch
If playing say an MP3 or FLAC audio file, it would be nice to say ARTIST - TRACK vs the current TRACK (YEAR) or even make this configurable?
Old 15th September 2012, 13:00   #58  |  Link
roytam1
Firefox User
Do you really need this if you can use most functions via right-click menu?
roytam1 is offline   Reply With Quote
Old 15th September 2012, 14:53   #59  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
The point of this is visual upgrade not functional. If there is normal menu, probably someone needs it. So this button is a cool replacement. And it is not hard to implement, especially if you have projects you can copypaste it from. Personally I don't even use any MPC player
Old 15th September 2012, 15:00   #60  |  Link
filler56789
SuperVirus
There's nothing "cool" in getting rid of the old-n'-good menu bar, according to my book.
I hope this time you understand what I tried to say in my previous post.
