24th July 2020, 13:15 | #29701 | Link | |
24th July 2020, 13:16 | #29702 | Link |
Here's the log
[07.24.20] BD Rebuilder v0.61.09 [09:09:06] Source: LUCYUHD - Input BD size: 58,50 GB - Approximate total content: [01:42:30.060] - Target BD size: 47,85 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), CQM - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [09:09:09] PHASE ONE, Encoding - [09:09:09] Processing: VID_00000 (1 of 3) - [09:09:09] Extracting A/V streams [VID_00000] - Extracting video streams [VID_00000] - Extracting audio/subtitle streams [VID_00000] - [09:15:57] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 128.721 frames - [09:15:57] Performing CQM Prediction... - Analyzing 1,00 [1,00] - [09:16:50] Encoding using constant quality mode. - [10:08:10] Video Encode complete - [10:08:10] Processing audio tracks - Track 4353 (eng): Keeping original audio - Track 4354 (deu): Keeping original audio - [10:08:11] Multiplexing M2TS - [10:10:00] Processing: VID_00003 (2 of 3) - [10:10:00] Extracting A/V streams [VID_00003] - [10:10:04] Reencoding video [VID_00003] - [10:10:04] Keeping original video (no reencode) - [10:10:04] Processing audio tracks - [10:10:04] Multiplexing M2TS - [10:10:08] Processing: VID_00004 (3 of 3) - [10:10:08] Extracting A/V streams [VID_00004] - [10:10:12] Reencoding video [VID_00004] - [10:10:12] Keeping original video (no reencode) - [10:10:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:10:12] Multiplexing M2TS [10:10:16]PHASE ONE complete [10:10:16]PHASE TWO - Rebuild Started - [10:10:16] Rebuilding BD file Structure [10:10:22] - Encode and Rebuild complete [10:10:22] Writing BD structure to ISO file - ImgBurn completed successfully [10:13:00] JOB: LUCYUHD finished. [/QUOTE] and the .inf [QUOTE][Status] LABEL=LUCYUHD VERSION=v0.61.09 SOURCE_SIZE=62817573023 SOURCE_VIDEO_SIZE=62142130176 TARGET_SIZE=51380224000 REDUCTION=.815948552284787 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=3 REBUILD_COMPLETE=1 [00000] AUDIO=011 PGS=111111111111 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=50587878624 NSTART=26999955 NEND=268593181 NSIZE=36097812480 FLINK=0 MLINK=0 [00003] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=10026 USE_ORIGINAL=1 NSTART=27000000 NEND=27011261 NSIZE=12288 FLINK=0 MLINK=0 [00004] USE_ORIGINAL=1 AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=116892502 NSTART=27000000 NEND=28081080 NSIZE=143271936 FLINK=0 MLINK=0 currently CQM is set, but LASTCMD states "--vbr 0 --vbr-quality <cqm-prediction-result>" ... shouldn't that be "--cqp <cqm-prediction-result>" ? Last edited by cartman0208; 24th July 2020 at 23:31. |
24th July 2020, 13:35 | #29703 | Link | |
I guess it's possible that shrinking the original by such a low factor might result in a value of 1.00, especially if the original was purposely oversized to force the need for a dual-layer disc -- but I would think that would be extremely rare (although I have seen it before). What happens if you select a 25GB target size? Did you get a chance to look at the size of the sample file? Last edited by jdobbs; 24th July 2020 at 13:45. |
24th July 2020, 13:48 | #29704 | Link |
I'm currently on another encode (where everything looks fine, several numbers on prediction, the sample file is around 750MB) but will retry the one in question after
I should mention, the one I posted, was way undersized ... around 35GB |
24th July 2020, 13:48 | #29705 | Link | |
In your INF file it looks like the output M2TS size is actually smaller than the target size, even with a CQM value of 1.00. That makes me wonder if the original actually was purposefully oversized. I've even seen M2TS files that were padded with zeros to make them larger. The one here is a pretty short film (about 90 minutes). Weird. I would have thought, though, that BD-RB would have noticed (after extracting the HEVC elementary stream) that no reencoding was needed and would have kept the original (unless "force_encode" was asserted). It is probably possible to pad an elementary stream too, I guess (you just wouldn't use zeros). Curious. Last edited by jdobbs; 24th July 2020 at 14:04. |
24th July 2020, 14:06 | #29706 | Link |
But would a CQM value of 1.00 not result in a HUGE output file, since its almost lossless?
[edit] Mediainfo Output on the sample file Code:
General ID : 1 (0x1) Complete name : U:\BD-Output\WORKFILES\00000.AVS.SMPL.m2ts Format : MPEG-TS File size : 604 MiB Duration : 1 s 1 ms Overall bit rate mode : Variable Overall bit rate : 4 956 Mb/s FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 s 2 ms Bit rate : 4 711 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 23.690 Stream size : 1.10 GiB Writing library : ATEME Titan KFE 3.7.3 (4.7.3.1003) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 400 cd/m2 Menu ID : 4096 (0x1000) Menu ID : 1 (0x1) Duration : 1 s 1 ms List : 256 (0x100) (HEVC) Service name : Service01 Service provider : FFmpeg Service type : digital television Last edited by cartman0208; 24th July 2020 at 23:30. |
24th July 2020, 14:15 | #29707 | Link | |
By the way, the sample file is nothing more than sets of frames pulled intact from the original stream. So what you are seeing there is the original information. The only way to know is to look at the command line in LASTCMD.TXT (before the next encode starts) and see if it was actually used for the encode. Last edited by jdobbs; 24th July 2020 at 14:21. |
24th July 2020, 14:19 | #29708 | Link | |||
[edit] Well well ... on target-size BD25 I get: Quote:
24th July 2020, 17:04 | #29710 | Link |
Wow. That is an illegally high bitrate, even for a UHD/BD. I have to believe MEDIAINFO is reporting it incorrectly. It could be due to the way in which BD-RB creates the sample file by pulling sets of frames in small groups and throwing them together as an M2TS for sample reencoding. The PTS values might look a little crazy to it, as they start over again with each I frame at the start of a grouping. It won't affect the decoding/reencoding for sampling -- but might look goofy as a whole when trying to analyze it.
24th July 2020, 19:48 | #29711 | Link | |
Sorry to be annoying, but I found another thing:
On Alternate Output the Cropping-Borders-Feature seems broken: Quote:
[00003] caption=MKV, HEVC, 1080p, Auto-AC3 aBitrate=640 aType=0 cType=1 vEncoder=1 vFormat=5 vKeyint=Auto vBitrate=0 Code:
#Created by BD Rebuilder - v0.61.09 DirectshowSource("U:\FULLDISC\UHD_ASTERIX\BDMV\STREAM\00002.m2ts", fps=23.976, framecount=123617, audio=false) Spline16Resize(1920,1080) LoadPlugin("U:\BD_Rebuilder\tools\autocrop.dll") Autocrop(mode=0, hMultOf=4) ConvertToYV12().AssumeFPS(24000,1001) I made a list of different scenarios, where autocrop is working or not: Code:
Source: h264 1080p, Target: h264 1080p, Decoder: DShow, Encoder: x26x - working Source: h264 1080p, Target: h264 1080p, Decoder: DShow, Encoder: NVenc - failed Source: h264 1080p, Target: h264 1080p, Decoder: DGdecNV, Encoder: x26x - failed Source: h264 1080p, Target: h264 1080p, Decoder: DGdecNV, Encoder: NVenc - failed Source: h264 1080p, Target: hevc 1080p, Decoder: DShow, Encoder: x26x - hanging Source: h264 1080p, Target: hevc 1080p, Decoder: DShow, Encoder: NVenc - working Source: h264 1080p, Target: hevc 1080p, Decoder: DGdecNV, Encoder: x26x - hanging Source: h264 1080p, Target: hevc 1080p, Decoder: DGdecNV, Encoder: NVenc - failed Source: hevc 2160p, Target: h264 1080p, Decoder: DShow, Encoder: x26x - failed Source: hevc 2160p, Target: h264 1080p, Decoder: DShow, Encoder: NVenc - failed Source: hevc 2160p, Target: h264 1080p, Decoder: DGdecNV, Encoder: x26x - failed Source: hevc 2160p, Target: h264 1080p, Decoder: DGdecNV, Encoder: NVenc - failed Source: hevc 2160p, Target: hevc 1080p, Decoder: DShow, Encoder: x26x - working Source: hevc 2160p, Target: hevc 1080p, Decoder: DShow, Encoder: NVenc - failed Source: hevc 2160p, Target: hevc 1080p, Decoder: DGdecNV, Encoder: x26x - working Source: hevc 2160p, Target: hevc 1080p, Decoder: DGdecNV, Encoder: NVenc - failed Source: hevc 2160p, Target: h264 2160p, Decoder: DShow, Encoder: x26x - failed Source: hevc 2160p, Target: h264 2160p, Decoder: DShow, Encoder: NVenc - failed Source: hevc 2160p, Target: h264 2160p, Decoder: DGdecNV, Encoder: x26x - failed Source: hevc 2160p, Target: h264 2160p, Decoder: DGdecNV, Encoder: NVenc - failed Source: hevc 2160p, Target: hevc 2160p, Decoder: DShow, Encoder: x26x - working Source: hevc 2160p, Target: hevc 2160p, Decoder: DShow, Encoder: NVenc - failed Source: hevc 2160p, Target: hevc 2160p, Decoder: DGdecNV, Encoder: x26x - working Source: hevc 2160p, Target: hevc 2160p, Decoder: DGdecNV, Encoder: NVenc - failed Last edited by cartman0208; 25th July 2020 at 07:21. |
24th July 2020, 23:29 | #29713 | Link | |
For the next long list I'll use CODE, but else I would rather use QUOTE, if that is OK? |
25th July 2020, 15:02 | #29715 | Link | |
I have just been testing each "session" with "UHD_LIMIT_ENCODE=1" before I create the full length MKV, so that I dont waste 2-4 days processing a video that will fail. Oh, btw, I am only doing software encoding at this time, if that matters. On the videos that fail, I create the MKV file with "cropping borders" unchecked, but with all other videos, I like having this feature checked. Last edited by BuddTX; 25th July 2020 at 15:05. |
26th July 2020, 14:27 | #29716 | Link |
Unfortunately AUTOCROP is simply an AVISYNTH PlugIn that I added to the BD-RB package. BD-RB just adds it to the AVISYNTH file when the box is checked. If it has an issue... there's really not much I can do other than maybe removing it as an option.
If you run into this problem, pretty much all I can recommend is to just use AVISYNTH filters to do the cropping manually. Last edited by jdobbs; 26th July 2020 at 14:30. |
26th July 2020, 18:42 | #29717 | Link | |
I also have been playing with newer versions of Avisynth. (Currently using AviSynthPlus 3.6.1) Wonder if this plugin would work "better" or "more reliably"? RoboCrop https://forum.doom9.org/showthread.p...t=autocrop.dll Version 1.13 has a release date of 2-7-2020 However, I do not see any place to download this dll. In post 95 of the above link, "hello_hello" wrote "RoboCropped.avsi" and posted a link. from the link above: Plugin's for both Avisynth v2.5 and v2.6. RoboCrop is an automatic cropping solution to crop black borders from video clips, loosely based on (but using no code from) Autocrop by Glenn Bussell. For the most part, you can just call it with RoboCrop(clip) and not bother with any other arguements, it is intended to be pretty much autonomous in its decisions. You might however want to alter eg WMod and HMod if your encoder has special requirements, and perhaps Laced if your source is likely to be fully progressive. Borders are detected by sampling at Samples frames, at scanlines (h/v) using AverageLuma (RGB is converted to Luma Y at either TV or PC levels, See Matrix). This sampling is done on all 4 sides of the frame. If a scanline Average luma is below or equal to Thresh, then is considered possible black border, above considered possible image, if Baffle [default=4] adjacent scanlines above Thresh, then it IS image. Thanks JDobbs! |
26th July 2020, 18:45 | #29718 | Link |
Also, maybe I should try using your "officially recommended" avisynth version, or maybe go back to 2.5.7 and see if that "fixes" the problem, the next time I find a video that fails with the autocrop selected, but is sucessful with autocrop unchecked.
26th July 2020, 23:00 | #29719 | Link |
I've dug a little further...
Looking at the software-only results Code:
Source: h264 1080p, Target: h264 1080p, Decoder: DShow, Encoder: x26x - working Source: h264 1080p, Target: hevc 1080p, Decoder: DShow, Encoder: x26x - hanging Source: hevc 2160p, Target: h264 1080p, Decoder: DShow, Encoder: x26x - failed Source: hevc 2160p, Target: hevc 1080p, Decoder: DShow, Encoder: x26x - working Source: hevc 2160p, Target: h264 2160p, Decoder: DShow, Encoder: x26x - failed Source: hevc 2160p, Target: hevc 2160p, Decoder: DShow, Encoder: x26x - working |
27th July 2020, 01:10 | #29720 | Link | |
