Old 23rd April 2022, 22:47   #31241  |  Link
MrVideo
MrVideo's Avatar
The video track is flagged as DV and tsMuxeR sees that
That is why there is no info under Vi
But, doesn't the stream info under the DV tab satisfy the spec that JD listed? The tsmuxer programmer strive to satisfy the specs. Are you saying they got this wrong?
Old 23rd April 2022, 23:29   #31242  |  Link
gonca
If my suspicions are half right tsMuxeR got it right
If there is no info to input, it can't set the info
Don't forget, in BD Dolby vision is "usually" a two track thing, standard 4K HDR track + DV track
The "failure" might be in the remuxing to MKV
Old 24th April 2022, 00:10   #31243  |  Link
No. I'm saying that the video stream entry is listed under the DV section, not the Vi section. screengrab
The screengrab link doesn't seem to work.
Old 24th April 2022, 00:12   #31244  |  Link
If I read the spec correctly, if a video stream exists -- the frame rate has to be set (in the video entry).
Old 24th April 2022, 01:22   #31245  |  Link
gonca
@jdobbs
I did two remuxes of a DV movie, one with MakeMKV and the second with MKVtoolNIX
mediainfo reports
makemkv
General
Unique ID                                : 51054395928025620456322350733546145217 (0x2668B80FCBF508D87377603C94BAC5C1)
Complete name                            : J:\No Time to Die\makemkv.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 66.2 GiB
Duration                                 : 2 h 43 min
Overall bit rate                         : 58.0 Mb/s
Movie name                               : No Time to Die
Encoded date                             : UTC 2022-04-23 23:51:01
Writing application                      : MakeMKV v1.16.7 win(x64-release)
Writing library                          : libmakemkv v1.16.7 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 58.0 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.292
Stream size                              : 66.2 GiB (100%)
Default                                  : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1000 cd/m2
Maximum Frame-Average Light Level        : 902 cd/m2
Original source medium                   : Blu-ray
mkvtoolnix
General
Unique ID                                : 332274804988886377338244567194467391288 (0xF9F9CCB72174D9811EC018C8BF995738)
Complete name                            : G:\mkvtoolnix.mkv
Format                                   : Matroska
Format version                           : Version 4
Encoded date                             : UTC 2022-04-24 00:01:17
Writing application                      : mkvmerge v65.0.0 ('Too Much') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Cover                                    : Yes
Attachments                              : cover.jpg
Video #1
Format                                   : HEVC
HDR format                               : SMPTE ST 2086, HDR10 compatible
Bit depth                                : 10 bits
Video #2
Format                                   : HEVC
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bit depth                                : 10 bits
Note that the mkvtoolnix report shows two tracks, video and DV layer
The makemkv report shows one track, a DV layer
I also remuxed to BD with tsMuxeR and the mkvtoolnix version shows all the info in BDedit while the makemkv version only shows the DV data
Old 24th April 2022, 01:52   #31246  |  Link
MrVideo
MrVideo's Avatar
Do it again. Something is up with vidiot.com, while vidiot.net works. Both report to the same computer (same IP).
Old 24th April 2022, 02:02   #31247  |  Link
MrVideo
MrVideo's Avatar
Somehow, two of my DNS record's IP addresses were changed and they weren't changed by me. I've changed them back, but it will take a wee bit for the change to spread.
Old 24th April 2022, 02:22   #31248  |  Link
MrVideo
MrVideo's Avatar
Thinking about it, I didn't think that DV could be done with only one video track. I prefer not to have DV video as it is not displayable via projectors. If it is all I have, then the projector will just ignore it.
Now I know what to look out for. Maybe BDRB can put out a warning that these videos are not valid DV videos.
Learn something new every day.
Old 24th April 2022, 02:49   #31249  |  Link
gonca
Wouldn't say not valid
Maybe not valid for BDs but is valid for mp4 and mkv
Problem is playing back these DV mp4 and mkv files
Old 24th April 2022, 03:44   #31250  |  Link
MrVideo
MrVideo's Avatar
Because BDRB is being used for BD/UHD creation, then they would be invalid.
My BD player has no problem with these files authored onto BDs.
Old 2nd May 2022, 23:41   #31251  |  Link
Players will do all kinds of things that they weren't supposed to
...until they don't.
Old 3rd May 2022, 01:06   #31252  |  Link
MrVideo
MrVideo's Avatar
So true.
Old 6th May 2022, 20:26   #31253  |  Link
I'm looking at making a change so that if the video entry is empty, BD-RB will gather info from the DV entry. It shouldn't have to... but this wouldn't be the first time BD-RB did something it shouldn't have to.
[edit] Ughh... I just looked at the code and this isn't going to be as easy as I'd hoped. Oh well...
Old 6th May 2022, 23:15   #31254  |  Link
MrVideo
MrVideo's Avatar
But, it will be greatly appreciated.
Old 7th May 2022, 15:41   #31255  |  Link
Ch3vr0n
Then you possibly may have been subject do DNS poisoning or an unauthorized change. Maybe look into DNSSec on your provider level
Old 7th May 2022, 22:31   #31256  |  Link
MrVideo
MrVideo's Avatar
I suspect it is something that I did. Hover is my domain name holder. I seriously doubt that they got hacked. Plus, only 2 of the 5 entries was incorrect. And, it wasn't a random IP address pointing to a nefarious location.
Old 8th May 2022, 21:46   #31257  |  Link
@MrVideo
Can you tell me how you create a structure that will cause the error you mentioned (DV has an entry but VID doesn't)? Here's what I did:
1. Use MKVMERGE to create an MKV file from an M2TS that has DV.
2. Use TSMUXER (UHD Version) to create a UHD/BD structure from the MKV file.
When I do it, it seems to create the structure fine, and I don't get the error.
Old 8th May 2022, 23:01   #31258  |  Link
gonca
If you use MakeMKV and then create the BD structure with tsMuxeR you will get DV info only
EDIT
see my post above
Old 8th May 2022, 23:47   #31259  |  Link
EDIT
see my post above
Oh. I see. It requires that the MKV be created by MakeMKV. Interesting. If I use MKVMERGE, it creates an MKV with two video tracks which imports fine into an UHD-BD structure.
Old 9th May 2022, 00:57   #31260  |  Link
EDIT
see my post above
So the question would be... why take this circuitous route of creating a movie-only BD structure anyway? To run into this problem you have to:
1. Use MAKEMKV to decrypt/create an MKV from the original disc.
2. Use TSMUXER to create a BD structure from the MKV.
3. Use BD-Rebuilder to create a Movie-Only version that is smaller.
Why not just:
1. Use MAKEMKV to decrypt/copy the BD structure to your hard drive.
2. Use BD-Rebuilder to create a Movie-Only version that is smaller.
If you also want an MKV, BD Rebuilder can do that for you too.
Am I missing something?
