17th February 2011, 04:18 | #11281 | Link | ||
17th February 2011, 08:11 | #11282 | Link | |
donation done. thx again for your work! |
17th February 2011, 11:37 | #11283 | Link |
BD Rebuilder n00b here and I have a couple of questions.
1. Should I set FFDSHOW-MPEG 2 to libavcodec or libmpeg2? 2. Since I'm using the BD25 output and I don't want to mess with the HD audio in any way, is it necessary to check these audio encoding options - Do not convert DTS to AC3, do not reencode AC3 & keep HD audio for BD 25 encoding or should I leave them unchecked? Thanks! |
17th February 2011, 15:47 | #11285 | Link | |
17th February 2011, 22:37 | #11286 | Link |
Still no Luck with this Movie LET_ME_IN..
Here are my logs: [19:52:49] BD Rebuilder v0.37.04 (beta) - Source: LET_ME_IN - Input BD size: 28.86 GB - Approximate total content: [01:55:47.940] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:52:51] PHASE ONE, Encoding - [19:52:51] Extracting A/V streams [VID_00001] - [20:55:34] Reencoding: VID_00001 (1 of 1) - [20:55:34] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 166,584 frames - Bitrate: 20,937 Kbs - [20:55:34] Reencoding: VID_00001, Pass 1 of 1 - [09:28:42] Video Encode complete - [09:28:42] Reencoding audio tracks (if req'd) - [09:28:42] Multiplexing M2TS [10:08:20]PHASE ONE complete [10:08:20]PHASE TWO - Rebuild Started - [10:08:20] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - [10:25:27] - Failed to REBUILD |
18th February 2011, 00:53 | #11287 | Link |
@big_moviefreak;
To confirm tsMuxeR is the culprit here, could you load the VID_00001.AVS.264, 00001.track_4352.ac3 ( or .thd ), and 00001.track_4608.sup, found in the Workfiles folder, into tsMuxeR GUI, select Blu-ray as your output and try a mux that way. Does that work? If not, try removing the subtitle track and run it again. http://www.videohelp.com/tools/tsMuxeR |
18th February 2011, 19:24 | #11289 | Link |
Bitter Old Geek
Failed attempt at Alternate Setting on BDRB Movie
OK, I may have been the culprit myself in that this is a bit off the wall, but I was attempting to take a BD-9 created by BD-RB and converting that with BD RB to DVD5 so it would play in my car for an upcoming trip. It is apparently not movie specific, because after the error, I tired several BD-RB BD-9s with the exact same result- extracts the first stream and reports failure. Not sure if it is really a bug, since it it works if I go back to the original BD (doing it right now) to make the DVD5. I can post more info if anyone is interested, but as I said, it may be a known limitation.
18th February 2011, 19:38 | #11290 | Link |
@larrsz
Hi! I'd speculate that the problem your having is due to the fact that the differing versions of BD-RB you're using use different/incompatible versions of supporting tools (e.g. x264). BTW - Are you certain that your auto's playback system won't play BD9s? |
18th February 2011, 20:25 | #11291 | Link | |
Bitter Old Geek
And, I am sure my vehicle only has an old fashioned DVD player. |
18th February 2011, 23:36 | #11292 | Link | |
Was the BD-9 a full backup or a movie-only backup? Last edited by jdobbs; 18th February 2011 at 23:42. |
18th February 2011, 23:51 | #11295 | Link | |
Can you post your INI file so I can use the exact same settings as you? |
19th February 2011, 00:04 | #11296 | Link |
JDOBBS, first just wanted to thank you for creating such a versatile tool like BD-Rebuilder. I have been using it for over a year now and it amazes me everytime how good the output quality of the video and audio is. I would appreciate it if you could answer my 2 questions:
I only create BD-25 backups and recently with the newer release of BD-Rebuilder 0.37.04 I see that there are 2 new settings that I am not used to seeing: 1. "Use DECOMB filter on interlaced source" ---->I am familiar with de-interlacing but my question is; Do I need to enable this option if I am only doing BD-50 to BD-25 backups. I figured the movies are progressive (1080p) so I wouldnt need this optional enabled. 2. "Use X264's internal LAVF for decoding" ----->I see that in 0.37.04 this optional is turned ON by default. I just dont know what are the benefits and drawbacks of using this option. For me it was disabled in the past when doing BD-50 to BD-25 backups. Do you recommend turning this ON or OFF for BD-25 backups? thanks in advance for you time. |
19th February 2011, 01:44 | #11297 | Link | |
2. Actually LAVF should be off by default. I'd recommend to do a test and compare the speed. The quality will be the same -- and on some systems LAVF is faster -- but contrary to what I'd originally thought, it can also be slower on some (that's why I changed it back to "off" as the default. |
19th February 2011, 01:58 | #11298 | Link | ||
19th February 2011, 03:43 | #11299 | Link |
OK guys, third time didn't work.
I reinstalled all the files from the first page of this thread as it says in the instructions. Been a few days because I didn't have a bluray to burn. Got Inglorious Bastards in from Netflix. Put Inglorious Bastards in, DID NOTHING WITH THE SETTINGS AT ALL, and hit back up "full backup" to bd 25 size disc.
Hit backup and twice this happened: [19:41:09] BD Rebuilder v0.37.05 (beta) - Source: ING_BASTERDS - Input BD size: 44.52 GB - Approximate total content: [04:15:55.430] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:41:11] PHASE ONE, Encoding - [19:41:11] Extracting A/V streams [VID_00151] - [19:41:15] DoEncoding() 00006 1607 [19:41:57] - Failed to complete. So I switched the setting to Movie Only backup. it says current progress 19% and then I get the error " Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed." See below: ----------------------- [19:42:27] BD Rebuilder v0.37.05 (beta) - Source: ING_BASTERDS - Input BD size: 34.86 GB - Approximate total content: [02:32:59.628] - Target BD size: 22.95 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:42:29] PHASE ONE, Encoding - [19:42:29] Extracting A/V streams [VID_00010] - [20:56:54] Reencoding: VID_00010 (1 of 1) - [20:56:54] Collecting video information - [20:56:54] Keeping original video (no reencode) - [20:56:54] Reencoding audio tracks (if req'd) - [20:56:56] Multiplexing M2TS - Error in attempt to multiplex: MUX_00010.meta - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. [20:56:59] - Failed to build structure, aborted I use windows XP, I have a LG burner and am using Verbatim 25 gb BD-R discs. I have gotten this error now with Eat Pray Love, Avatar, Dinner for Schmucks and Machete. Always the same error. I am only installing the programs and then trying this. Not checking or unchecking any boxes. I also don't know what to pick when AnyDVD HD asks me what region (no region, region a, B or C). There must be a reason I keep getting the same 'pes packet len too large' error. HELP! |
