Old 12th September 2016, 07:19   #101  |  Link
shekh
Yes, but I am not fast at updating ffmpeg (still at 2016-04-28). Maybe will pull it before declaring this preview version done.
Old 24th September 2016, 21:59   #102  |  Link
shekh
New version.
Among other fixes, ffmpeg-based input driver can now work with direct stream copy and smart rendering, but only with I-frame formats.
It is hard to tell generic rule, but I expect anything you can put in AVI with all keyframes should work. Actually tried direct copy with utvideo, x264, mjpeg, ffv1, huffyuv, and smart rendering with x264 and maybe something else.
VirtualDub2
Old 25th September 2016, 09:45   #103  |  Link
StainlessS
StainlessS's Avatar
We love this project, thank you Shekh.
I sometimes post sober.
Old 25th September 2016, 19:43   #104  |  Link
kolak
Yep!
Latest ffmepg got finally MOV edit list support which is very useful. No more unwanted frames in MOVs with edit list.
I hope this will come to plugin also at some point.
Old 25th September 2016, 20:20   #105  |  Link
shekh
Originally Posted by kolak View Post
Yep!
Give me a clue (and sample files) how to approach this, I will see if it is easy
VirtualDub2
Old 30th September 2016, 11:06   #106  |  Link
kolak
I can prepare something.
Simplest way to do is to take any some MOV file open in QT7 on Mac or Qt7 Pro on PC, select some segment at the start and delete it. Then save this MOV (not Save As). This will add some edit metadata. If you open such a file in Qt7 you should see your adjusted start point. If you open in Vdub than it will show original start.
New ffmpeg will respect edited in point.
Old 30th September 2016, 11:11   #107  |  Link
shekh
Then I think it already works? I saw some code int ffmpeg adjusting index etc. for edit lists.
VirtualDub2
Old 30th September 2016, 11:14   #108  |  Link
kolak
Yes, ffmpeg has support for edit list in MOV now, so I hope this will come to Vdub source plugin also.
Old 30th September 2016, 11:22   #109  |  Link
shekh
Can you make a timecoded video with some edits?
Btw how do you know it was added recently?
VirtualDub2
Old 30th September 2016, 23:03   #110  |  Link
kolak
https://git.ffmpeg.org/gitweb/ffmpeg...de12842d8f0ca3
I tested it and it does work.
I will prepare something soon.
Old 5th October 2016, 16:30   #111  |  Link
kolak
Sorry, but I was bit busy.
Here are some files:
https://drive.google.com/file/d/0B5S...ew?usp=sharing
they have descriptions in the name. Main file is 10 seconds as is. Then there is one which has first 2 sec edited out, last 2 seconds edited out and 2-5sec edited out. If you open them in QT player you will see everything as they have TC and frames burned in.
Latest ffmpeg respects editing, few weeks old won't.
Old 5th October 2016, 16:53   #112  |  Link
shekh
Everything looks fine
I built last version with 2016-09-22 FFMPEG
VirtualDub2
Old 5th October 2016, 22:46   #113  |  Link
kolak
Great, with new ffmpeg it should.
Try old one and you will see that all edits are ignored.
Old 11th October 2016, 04:31   #114  |  Link
v0lt
MKV(H.264+AC3). Direct copy not worked.
http://imgur.com/a/KqkSr
v0lt is online now   Reply With Quote
Old 14th October 2016, 10:04   #115  |  Link
shekh
I was on vacation and could not reply, but you probably already know only I-frame video is currently supported. Btw I put all relevant info here: https://sourceforge.net/p/vdfiltermod/wiki/direct_copy/
Implementing universal support for direct copy mode is of extra low priority for me but with I-frame formats it is really simple so this is why I made it.
VirtualDub2
Old 19th October 2016, 10:43   #116  |  Link
v0lt
I figured out after.
Do you plan to support other formats for writing? For example a plug-in that could be mixed strems to MKV with an external ffmpeg.exe.
Old 30th December 2016, 20:48   #117  |  Link
shekh
Version 14
Quick summary: completed YUV 16-bit pixel formats (supported by input and output).
Display of those formats is now faster, for example:
CFHD decoded as v210 - compared on same fragment and same pc
official VD: throughput about 32fps
FilterMod 14: throughput about 100fps
FilterMod 14, decoding as rgb24: throughput about 135fps (for reference)
(v210 is expanded to friendly YUV422P16)
VirtualDub2
Old 31st December 2016, 09:00   #118  |  Link
StainlessS
StainlessS's Avatar
Lovely, thanx Shekh
Old 4th January 2017, 15:07   #119  |  Link
Reel.Deel
Thanks for the update shekh. Any plans on adding high bit depth support for AviSynth+ scripts?
Reel.Deel is offline   Reply With Quote
Old 4th January 2017, 15:36   #120  |  Link
shekh
I dont have any todo list about it.
But there is a chance it might already work to some extent, currently accepted bitmap formats:
b64a = packed rgba 4*16-bit
BRA[64] (AV_PIX_FMT_BGRA64) = packed rgba 4*16-bit
P210 = interleaved YUV 422*10-bit
P216 = interleaved YUV 422*16-bit
Y3[10][10] (AV_PIX_FMT_YUV422P10) = planar YUV 422*10-bit
Y3[10][16] (AV_PIX_FMT_YUV422P16) = planar YUV 422*16-bit
BRA[64], P210 and Y3[10][10] actually work with MagicYUV decoder.
VirtualDub2
