Old 26th February 2019, 15:32   #1481  |  Link
sneaker_ger
CDEF patch is merged now.
Old 26th February 2019, 15:53   #1482  |  Link
Here is an up-to-date performance comparison of aomdec vs dav1d (I believe some of the tests are still running as I write this)
https://docs.google.com/spreadsheets...gid=1835354908
Single-Threading, it still loses in some cases on SSE 4.1 CPUs (aom implements mostly SSE4.1 for pre-AVX), but Multi-Threading it makes up for that.
One missing part is prep_8tap, which can have a decent impact.
Their goal for releasing dav1d 0.2.0 is to be faster then aomdec in 8-bit in all targeted scenarios.
Old 26th February 2019, 17:03   #1483  |  Link
sneaker_ger
There are some user benchmarks on an iPhone with crazy results.
1080p with 46 to 74 fps. Years ago we told people they would never be able to watch new codecs on a phone if it didn't have ASIC for the codec ...
Old 26th February 2019, 17:27   #1484  |  Link
They really still shouldn't want to/have to, since it'll make the phone hot and the battery empty.
Old 26th February 2019, 18:00   #1485  |  Link
benwaggoner
Alliance for Open Media codecs
Fun way to amaze yourself - figure out how long ago you first got a computer that was more powerful than your current phone (benchmark/metric of your choice). A modern iPhone has lots of fast cores with SIMD instructions and a pretty darn powerful GPU. It would smoke any hot gaming rig of 10 years ago, and a typical laptop of 5 years ago.
Generally each new codec generation aims to be more than twice as complex to decode as the prior generation. With Moore’s Law gains, computing devices get a LOT more than 2x faster in that time.
The bigger challenge with software codecs is getting them integrated into hardware DRM required to play premium content above 480p.
It’s exciting to see these perf gains with AV1. Hopefully we’ll get to a reasonably “done” version of dav1d later this year so we can ballpark decoder requirements for AV1 versus other codecs. I’m particularly interested in how much parallelism is possible. VP9 was nearly single-threaded, which was problematic
A big question for AV1’s viability is how many extra transistors (and thus how much extra die size and SoC cost) full HW decode will take. I’ve not heard any details from anyone who has taped out an implementation yet. Anyone else?
Ben Waggoner
My Compression Book
Old 26th February 2019, 18:16   #1486  |  Link
NikosD
Unfortunately, in single-threading mode, dav1d looses even using SSSE3 in Dua Lipa clip.
It needs further optimization for pre-AVX2 SIMD, but the multi-threading performance especially for AVX2 is impressive.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 26th February 2019, 20:10   #1487  |  Link
EwoutH
@nevcairiel You're fast
That bench included !604 (prep_8tap), so this is most likely the performance as it's going to look like at 0.2.0 release. Not all prep_8tap functions are converted to ssse3 yet, so there is potentially another 5-12% speedup possible for ssse3, highly depending on content.
EwoutH is offline   Reply With Quote
Old 28th February 2019, 08:34   #1488  |  Link
iwod
Originally Posted by GTPVHD View Post
https://aomediacodec.github.io/av1-avif/
v1.0.0, 19 February 2019 but page still says it is a draft.
That is the Image format AVIF you are looking at. Not sure if that is what you want.
iwod is offline   Reply With Quote
Old 28th February 2019, 10:45   #1489  |  Link
Q3CPMA
Q3CPMA's Avatar
Personally, I find AVIF a lot more interesting than AV1 seeing as JPEG is technologically much more obsolete than AVC (if you don't consider 4K, of course). I just hope they don't force chroma subsampling like on webp.
Q3CPMA is offline   Reply With Quote
Old 28th February 2019, 13:01   #1490  |  Link
hajj_3
Jpeg XL will be ratified later this year, that should be much nicer than AVIF.
Old 28th February 2019, 22:05   #1491  |  Link
Rumbah
Will it be royalty free?
Rumbah is offline   Reply With Quote
Old 1st March 2019, 05:40   #1492  |  Link
Zebulon84
In this document (Final Call for Proposals for a Next-Generation Image Coding Standard (JPEG XL)) issued in last April, it is stated page 3:
This new JPEG activity aims to develop a new image coding standard that provides state-of-the-art image compression performance, and that addresses shortcomings in current standards. To encourage widespread adoption, an important goal for this standard is to support a royalty-free baseline
So probably partially. But will il be enough to have wider adoption than previous standards (JPEG 2000, JPEG XR...) ?
Zebulon84 is offline   Reply With Quote
Old 1st March 2019, 23:27   #1493  |  Link
mzso
There's a solution.
Yay! Two more formats to sink into obscurity...
Old 2nd March 2019, 02:08   #1494  |  Link
hajj_3
It looks like the dav1d decoder v0.2.0 has been released: https://code.videolan.org/videolan/d...f534b9fe6f169a
Old 2nd March 2019, 07:31   #1495  |  Link
marcomsousa
Isn't release yet, just a change for the next release.
Wait until there is a 0.2.0 tag and/or release.
https://code.videolan.org/videolan/dav1d/tags
AV1 win64 VS2019 builds
Last build here
marcomsousa is offline   Reply With Quote
Old 2nd March 2019, 08:07   #1496  |  Link
marcomsousa
Originally Posted by Wolfberry View Post
The version has already bumped to 0.2.0
Are you sure that 0.2.0 is finished?
There isn't a tag neither a release version.
https://code.videolan.org/videolan/dav1d/releases
That change was in 25/02 and the other was 13 hours ago.
I think that the final version of 0.2.0 isn't release yet, but it's seems that will be release in the follow hours/days.
But I confirm that this is a litle strange. They have a version without being finished. That it seems that is the way before, they don't use -dev neither -snapshot.
Last build here
Old 2nd March 2019, 09:14   #1497  |  Link
The release is scheduled for Monday currently. The version bump means nothing, its only in preparation for the release, only tags really matter. You would typically do that a few days earlier to ensure everything comes out as expected.
Its not really that strange either, you guys are just overthinking it.
Old 2nd March 2019, 09:46   #1498  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
The version bump means nothing.
Just like this commit
It seems like 0.1.1 is just a transition from 0.1.0 to 0.2.0 and will never get released. But I can be wrong, anyway.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 2nd March 2019, 10:35   #1499  |  Link
0.1.1 was never released indeed, the changelog entries being created for it have been recycled into the 0.2.0 changelog.
Old 2nd March 2019, 12:03   #1500  |  Link
sneaker_ger
Now dav1d is like 55% faster on i5-2500K (AVX, no AVX2) than libaom on Blackmagic Pocket Cinema "Nature" sample 1080p24.
