9th January 2018, 17:25 | #24 | Link | |
What this means is that, 999 times out of 1000, the FFMS2 core in the C-plugin builds will be the same as it is as of the HEAD position of upstream's master branch at the time I built it, exempting a couple spots required to get MinGW-w64 to build it at all (and those commits are old and already in the c_plugin branch). It's not really relevant to a comparison with the upstream release builds or the test builds in the FFMS2000 thread, though, because those are the standard C++ plugin, and that's separate from the C-plugin's code. The FFMS2000 changes were merged back into the master branch in November, and the builds from after that are just normal HEAD builds from upstream/master. |
1st February 2018, 02:39 | #25 | Link |
Broadcast Encoder
I got half green screen, decoding an MPEG-2 .ts file.
It didn't happen in the former version of ffms. It seems like it's somehow expecting high bitdepth, but MPEG-2 files are 8bit. This is the result: Image It's a common MPEG-2 .ts file, except for the fact that it's 4:2:2 and it didn't go on air; there shouldn't be any problem with it anyway. Avisynth: 2.6.1 OS: Windows XP Professional x86 with extended support ID : 21 (0x15) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format settings, BVOP : No Format settings, Matrix : Custom Format settings, GOP : Variable Codec ID : 2 Duration : 23 min 9 s Bit rate mode : Constant Maximum bit rate : 50.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Last edited by FranceBB; 1st February 2018 at 02:44. |
1st February 2018, 03:08 | #27 | Link |
Broadcast Encoder
Yes, it behaved exactly the same, but I just found out that the file is corrupted.
(MD5 doesn't match). I'm just gonna transfer it again. Nothing to be worried about, my bad. ^_^ |
22nd April 2018, 03:57 | #28 | Link |
FFMS2 C-plugin r1315+118 (Final LastXP build)
Optimized for Pentium-III and SSE (32-bit) Optimized for Core2 (64-bit) ffmpeg version r90798 master-21da248b5f HEAD-a56580b117 contains: lastxp_wincrypt Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7.2.0 (GCC) libavutil 56. 13.100 / 56. 13.100 libavcodec 58. 17.100 / 58. 17.100 libavformat 58. 11.101 / 58. 11.101 libavfilter 7. 15.100 / 7. 15.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 0.102 / 5. 0.102 libswresample 3. 0.101 / 3. 0.101 libpostproc 55. 0.100 / 55. 0.100 32-bit configuration: Code:
--prefix=/home/qyot27/ffmpeg_build_for_ffms2/32bit --cross-prefix=i686-w64-mingw32- --enable-gpl --enable-version3 --disable-w32threads --enable-avresample --disable-encoders --disable-muxers --disable-doc --disable-debug --disable-devices --disable-avdevice --extra-cflags='-mfpmath=sse -march=pentium3 -msse -mtune=pentium3' --target-os=mingw32 --arch=x86 Code:
--prefix=/home/qyot27/ffmpeg_build_for_ffms2/64bit --cross-prefix=x86_64-w64-mingw32- --enable-gpl --enable-version3 --disable-w32threads --enable-avresample --disable-encoders --disable-muxers --disable-doc --disable-debug --disable-devices --disable-avdevice --extra-cflags='-march=core2' --target-os=mingw32 --arch=x86 So yeah, at this point there's no point keeping my cross environment compatible with XP from the MinGW-w64 level. EDIT 2018-04-25: Newer build available; check first post. Last edited by qyot27; 25th April 2018 at 23:30. |
22nd April 2018, 05:45 | #30 | Link |
From the file name 'ffms2_r1315+117-avs+vsp_lastxp' I assumed these should also work with Vapoursynth.
Trying to use the 64bit version in Vapoursynth with: Code:
# Imports import vapoursynth as vs core = vs.get_core() # Loading Plugins core.std.LoadPlugin(path="G:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Loading F:\TestClips&Co\files\Test-AC3-5.1.avi using FFMS2 clip = core.ffms2.Source(source="F:/TESTCL~1/files/TEST-A~1.AVI",cachefile="H:/Temp/avi_4a88093b3b83d19d00642a5a96b0af78_41.ffindex",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Point(clip, matrix_in_s="470bg") # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip, fpsnum=25, fpsden=1) # Making sure input color range is set to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # adjusting output color from: YUV420P8 to YUV420P10 for x265Model (i420) clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10) # Output clip.set_output() Code:
Failed to evaluate the script: Python exception: No entry point found in G:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1847, in vapoursynth.vpy_evaluateScript File "H:\Temp\tempPreviewVapoursynthFile06_41_54_518.vpy", line 5, in <module> core.std.LoadPlugin(path="G:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") File "src\cython\vapoursynth.pyx", line 1739, in vapoursynth.Function.__call__ vapoursynth.Error: No entry point found in G:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll Cu Selur |
22nd April 2018, 13:26 | #31 | Link |
Thanks so much qyot27 for this new version...
Tested it thoroughly under Win XP and Win 7-64, works like a charm. Maybe a little bit OT since this new version (the absolutely very very last XP version) will be perfect for some time... What will be the alternative for stubborn XP diehards like myself once this version will fail with certain sources (and DSS2Mod will not work reliably)? This is my reasoning: Luckily there are still three folks who still provide XP compatible FFmpeg builds (CoRoNe, Sherpya and AbeChin). Since FFmpeg decoders are updated frequently there is a good chance that these XP compatible builds will open newer source formats in the future. So why can't we use FFmpeg.exe to decode sources and pipe them to stdout and then use some (yet to be written) AviSynth stdin source filter? I had a look at Sashimi, but it seems awfully complex, and it relies on writing an intermediate raw file. Inserting FFmpeg decoded output into a DirectShow Filter Graph seems to be impossible (after doing some research). What does work for me is using FFmpeg to create a lossless intermediate file (I used H264 CRF=0 with FLAC audio) and open this file with DSS2Mod and LAVFilters. Am I right to assume that there will be no seeking issues because the lossless video file only has key frames? The problem is just that the intermediate file will be huge, and creating it is time consuming. Some kind of piping it into AviSynth would be very welcome. Any thoughts? Cheers manolito Last edited by manolito; 22nd April 2018 at 13:44. |
22nd April 2018, 22:19 | #32 | Link | |||
*I managed to partially do so once, to fix an issue with a DirectX .dll. Hopefully the situation is better than it was ca. 2010 and won't trip over itself and die during the compilation process. I don't have a lot of hope for that, but who knows? Quote:
FFmpeg commit a56580b117 (the one used in this build) is the last one that can work on XP without beginning to put in [potentially] a lot of extra leg work to keep it going. Even if it's minimal work to do so right now, it'll get progressively harder to do so. Quote:
23rd April 2018, 03:22 | #33 | Link |
Broadcast Encoder
Few issues with Avisynth 2.6.1 on Windows XP x86.
LoadCPlugin("ffms2.dll") in ffms2.avsi doesn't work, Load_Stdcall_Plugin("ffms2.dll") does. If I try to index an H.264 4:2:0 8bit .mp4 file, it works flawlessly, however when I try to index an H.264 4:2:0 10bit .mkv file, it says: Error requesting frame xxxx Windows error: exception access violation reading 0x00000000. The latest stable ffms build (not ffms2000) from 2016 works fine. I can't test the latest ffms2000 'cause I'm running XP. Nothing special on mediainfo: Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High 10@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 10 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 min 32 s Bit rate : 4 685 kb/s Width : 1 024 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.331 Stream size : 51.4 MiB (91%) Writing library : x264 core 148 r2744kMod b97ae06 Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=17.0000 / qcomp=0.60 / qpmin=5 / qpmax=40 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Language : Japanese Default : Yes Forced : No Color range : Limited Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1 min 31 s Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 4.90 MiB (9%) Language : Japanese Service kind : Complete Main Default : Yes Forced : No |
23rd April 2018, 11:19 | #34 | Link | |
Could it be that you have the old Avisynth_c.dll in your Plugins folder? See this post: https://forum.doom9.org/showthread.p...02#post1835702 Cheers manolito |
23rd April 2018, 11:25 | #35 | Link | |
Thanks for taking the time for explaining... So my only hope for XP is that those 3 guys will find some tricks to maintain XP compatibility for some time to come... Cheers manolito |
23rd April 2018, 13:59 | #37 | Link |
Hotfix build for the 64-bit VapourSynth issue Selur reported earlier.
EDIT 2018-04-25: Newer build available; check first post. Last edited by qyot27; 25th April 2018 at 23:31. |
23rd April 2018, 14:37 | #38 | Link | |||
I've never got ReactOS to run as yet (dont think), and put that down to all of my systems being multi-boot (non-M$/non-Linux boot controller), am hopeful that the new version will at last work (have downloaded, not yet tried). Thanx for the updates qyot27.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd April 2018 at 15:01. |
23rd April 2018, 15:03 | #39 | Link | |
Please let us know once you tried it how it works for you. A lot of stuff I rely on is not available under Linux, and using Wine or have Windows installed in a VM looks clumsy to me. I just hope that ReactOS will succeed... Cheers manolito |
23rd April 2018, 17:33 | #40 | Link | |
Tried on Intel Board/bios core-duo quad m/c with all drives removed, all external cards/usb devices removed, running live USB ReactOS v0.48, and sadly, stopped on about the 4th message "Loading NTOSKRNL.EXE..." "Loading HAL.DLL..." "Loading KDCOM.DLL..." "Loading boot drivers..." Black Screen then nothing (monitor detects active display), CTRL/ALT/DEL reboot is disabled. Tried on a second m/c IBM board/bios, did not remove any drives (3 internal attached), no internal cards attached, a couple of external USB cameras attached; did not remove, same results as previous Intel m/c test, although after about 5 minutes, the fan became quite active but may have been down to it being relatively warm day (does not usually have fan going continuous, which it did for at least 20 mins before shutting down, so CPU does seem to be doing something). I think on a previous attempt (perhaps with v0.47), it put up the usual long list of debug logging driver/system files, and used to hang at "Mup.Sys". This is beginning of debug log (Safe Mode from boot F8 key) for XP SP3. Code:
Loaded driver \WINDOWS\system32\ntkrnlpa.exe Loaded driver \WINDOWS\system32\hal.dll Loaded driver \WINDOWS\system32\KDCOM.DLL Loaded driver \WINDOWS\system32\BOOTVID.dll Loaded driver sptd.sys Loaded driver \WINDOWS\System32\Drivers\WMILIB.SYS Loaded driver \WINDOWS\System32\Drivers\SCSIPORT.SYS Loaded driver ACPI.sys Loaded driver pci.sys Loaded driver isapnp.sys Loaded driver pciide.sys Loaded driver \WINDOWS\system32\DRIVERS\PCIIDEX.SYS Loaded driver MountMgr.sys Loaded driver ftdisk.sys Loaded driver dmload.sys Loaded driver dmio.sys Loaded driver PartMgr.sys Loaded driver VolSnap.sys Loaded driver atapi.sys Loaded driver disk.sys Loaded driver \WINDOWS\system32\DRIVERS\CLASSPNP.SYS Loaded driver fltMgr.sys Loaded driver sr.sys Loaded driver PxHelp20.sys Loaded driver KSecDD.sys Loaded driver WudfPf.sys Loaded driver Ntfs.sys Loaded driver inspect.sys Loaded driver \WINDOWS\System32\DRIVERS\NDIS.SYS Loaded driver \WINDOWS\System32\DRIVERS\TDI.SYS Loaded driver pwdrvio.sys Loaded driver Mup.sys It also used to fail (some prev versions) on a Dell m/c which I've recently consigned to the scrap heap (random failures, probably Motherboard, PSU, or CPU faulty, mem seems ok). Also dumped another Motherboard, down to only 3 now, and not set up to easily test on the 3rd board, so only above two results available. Its strange that they have not been able to get the live image to boot on any of my machines, I presume that the image does not require recent hardware. ReactOS, apparently is able to run in only 96MB of RAM, M$ stuff is way too bloated.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd April 2018 at 17:38. |
