20th March 2019, 09:25 | #201 | Link | |
re (1) - x265 w/ closed-gop and custom keyframes intval 100 - IDR keyframes at positions: 1, 101, 201, 301, 401 | simple (non-IDR) I frames: none re (2) - x265 w/ open-gop and custom keyframes intval 100 - IDR keyframes at positions: 1 | simple (non-IDR) I frames at positions: 97, 197, 297, 397 re (3) - x265 w/ open-gop and no custom keyframes intval - IDR keyframes at positions: 1 | simple (non-IDR) I frames at positions: 247 not sure how ffms2 works, but if it reads file (2), then sees the specified GOP size with keyintval of 100 (in the encoding settings), and then does not find the IDR frames in the correct positions, or matter of fact does not find any IDR frames at all (b/c ffmpeg w/ open-gop only places simple I frames), then that may be the reason why it acts up... Last edited by Iron_Mike; 20th March 2019 at 09:28. |
20th March 2019, 09:50 | #202 | Link |
There are new ffms2 / lsmash builds up. But seems to behave the same.
And I tested the mp4 with the old ffms2 and it has no seeking problems. https://github.com/FFMS/ffms2/releas...2.23.1-msvc.7z (This is the second file what has no problems with the old version) I tested also a build by HolyWu (ffmpeg 4.1.1) https://forum.doom9.org/showthread.p...11#post1866411 -> Seeking issues
20th March 2019, 15:27 | #204 | Link |
It's ok display order wise.
The offset position and encoding order does not necessarily reflect the display order of the frames. That utility does not display the GOP number , display frame number, encoded frame number , but hey it's free There is another analyzer, GitlHEVCAnalyzer on sourceforge but it only supports 8bit HEVC . But you guys are using 8bit here, but it will display a graph like elecard with "I" slices in red. But you can see they are placed correctly. Another method, with avisynth ffms2 is to use FFInfo() and it will display the pic type. But again, it does not distinguish between IDR types , or non IDR "i". Just simple I,P,B slices . Or commercial analyzers ($) . |
20th March 2019, 16:11 | #205 | Link | |
or just text.FrameProps() to show all frame props
20th March 2019, 16:14 | #206 | Link | ||
These are the SSIM:GMSD (Downsample=False) obtained with Wolfberry's ffms2 (default seekmode=1) Code:
crowd_run_1080p50_y4m_x265_CRF28_v2.mp4: stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 crowd_run_1080p50_y4m_x265_CRF28_KeyInt100_v2.mp4: stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 Code:
crowd_run_1080p50_y4m_x265_CRF28.mp4: stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 stop 436.0761918885030863357599170 83.36467719049633404160282170 crowd_run_1080p50_y4m_x265_CRF28_KeyInt100.mp4: stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 stop 435.9938560956790122302706430 83.19534706841788751496835637 In fact the two crowd_run_1080p50_y4m_x265_CRF28.mp4 files are byte identical and the crowd_run_1080p50_y4m_x265_CRF28_KeyInt100.mp4 files differ by only 5 bytes. Still, here are the re-encoded files (omitting -threads 6): crowd_run_1080p50_y4m_x265_CRF28_v2
Nostalgia's not what it used to be Last edited by WorBry; 20th March 2019 at 21:37. |
20th March 2019, 16:54 | #207 | Link |
Maybe not enough vertical motion to exhibit the frame threads effect in this shot. No idea why your values where consistently slightly higher than Iron_Mikes' (frame threads would have been a nice way to explain it) . Maybe some more inconsistencies between runs or systems
But beyond that , look at the bitrate / filesize between your uploads and his. Way different. Some settings are actually different too looking at mediainfo . psy-rdoq is 0 for his 1 for yours for the keyint 100 encode, rd4 vs 2 etc... . Need to compare apples to apples . Or at least look at the same physical file |
20th March 2019, 17:30 | #208 | Link |
He modified the 'original' test encode settings for those uploads - changed -preset slow to fast and added -rc-lookahead=100:
https://forum.doom9.org/showthread.p...02#post1869402 Why, I don't know. So he should upload x265 files encoded with the 'original' scripts for valid comparison: https://forum.doom9.org/showthread.p...90#post1869390
Nostalgia's not what it used to be Last edited by WorBry; 20th March 2019 at 21:28. |
20th March 2019, 23:21 | #209 | Link | |
you misread my post (the last post you linked to): rc-lookahead was ALWAYS a parameter I included if I specified custom keyframes... but I did ONE TEST to see if specifically the rc-lookahead parameter was the problem for ffms2, hence I removed that param in that ONE encode... which is stated in my original post, and as you can see in point (2) in that post - which you removed from the quote - I have used the rc-lookahead param... All files uploaded by me were done w/ the rc-lookahead param (if custom keyframes were specified), only reason I had to re-upload once is b/c I used incorrect syntax for the no-open-gop flag on one of the three files... so, if a custom keyframes intval was specifed these three params were added to the x265-params: keyint=100:min-keyint=100:rc-lookahead=100 |
21st March 2019, 00:41 | #210 | Link |
No I didn't misread your post. You changed the preset to fast also. First you are following my encode script, as a common ground - now you're not. Have you even taken the trouble to test the files I uploaded and post the results, as I did yours ? Really can't be bothered with this.
@Poisondeathray, I'm interested to know how your results with the files I uploaded compare anyway. Cheers.
Nostalgia's not what it used to be Last edited by WorBry; 21st March 2019 at 00:46. |
21st March 2019, 01:24 | #211 | Link | |
Think I'll switch to LWLibavSource for future metric testing.
Nostalgia's not what it used to be |
21st March 2019, 01:30 | #212 | Link | |
Not able to replicate the 12th or whatever tiny decimal error with seekmode=0 over 10 runs . 100% consistent Tried 2 computers, but both were 4C/8T Intels . I also have a really old AMD (with XP!) lying around but I didn't test on that EDIT #1: also on the other file, with default settings (no custom keyint) , it was inconsistent too. Iron_Mike reported "big" inconsistent results on some runs only when using custom keyint . I'm seeing inconsistent everywhere with ffms2 default seekmode on these. EDIT #2: remuxing to mkv with mkvmerge made everything consistent for the keyint 100 file (10 runs matched) with default seekmode, as CK also reported . This makes me think it has something to do with ffms2 reading the timebase and timecodes in the container , or container mux, or interpretation issue ffmpeg -i input.ext Code:
mkv Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 1k tbn, 50 tbc (default) mp4 Stream #0:0(und): Video: hevc (Main) (hev1 / 0x31766568), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 15411 kb/s, 50 fps, 50 tbr, 12800 t bn, 50 tbc (default) Last edited by poisondeathray; 21st March 2019 at 01:52. |
21st March 2019, 02:01 | #213 | Link | |
The preset does NOT matter in any of this - no idea why you say any of that. I also don't care if you test ffms2 or not. I posted and proved that there are issues w/ seekmode=1, other people confirmed. Don't care whether you personally test this or not. The only reason why I even bothered to write here is b/c you spend some time doing some tests and if you ever are subject to this behavior - or other inconsistent behavior we've not yet discovered - then your posted results here would be pointless. Hence, it's always good if another source confirms general trends of test results of these metrics... which I did. Last edited by Iron_Mike; 21st March 2019 at 02:05. |
21st March 2019, 02:23 | #214 | Link | |
WorBry - crowd_run_1080p50_y4m_x265_CRF28.mp4 - seekmode=1 - GMSD/SSIM stop 83.36467719049633404160282170 436.0761547550154326735594167 stop 83.36467719049633404160282170 436.0761547550154326735594166 stop 83.36467719049633404160282170 436.0761547550154326735594166 stop 83.36467719049633404160282170 436.0761547550154326735594166 stop 83.36467719049633404160282170 436.0761547550154326735594166 WorBry - crowd_run_1080p50_y4m_x265_CRF28_KeyInt100.mp4 - seekmode=1 - GMSD/SSIM stop 124.0039187143357256870590535 227.9924869038146211797091216 stop 83.19534706841788751496835637 435.9938219159915119282899813 stop 120.1705765900797210909978223 248.1439760410638495358170989 stop 122.2412107559194712758099402 236.4289261580102229909350346 stop 122.2412107559194712758099402 236.4289261580102229909350346 matches my previously reported behavior... Last edited by Iron_Mike; 21st March 2019 at 02:27. |
21st March 2019, 02:26 | #215 | Link | |
21st March 2019, 03:10 | #216 | Link | |
OK, are we done ?
Nostalgia's not what it used to be Last edited by WorBry; 21st March 2019 at 03:20. |
21st March 2019, 03:18 | #217 | Link | |
Nostalgia's not what it used to be Last edited by WorBry; 21st March 2019 at 03:36. |
21st March 2019, 03:23 | #218 | Link | |
yes, you are done, Brian. go take a nap. |
21st March 2019, 03:38 | #219 | Link | |
Very juvenile, but I had that sense already.
Nostalgia's not what it used to be Last edited by WorBry; 21st March 2019 at 03:50. |
21st March 2019, 03:47 | #220 | Link | |
as far as I can see, the ONLY one that it has been fully "reliable" w/ seekmode=1 w/ custom keyframes is you... I posted it, CK confirmed and poisondeathray confirmed... As I stated pages ago, it would not surprise me if it turns out to be a package difference, and by that I mean a specific VS plugin difference, but w/o a direct, convenient method to list version/release data of all VS plugins involved in the VS chain, it'll be hard to compare... easiest way to confirm it is to create a minimal VS venv - only what's needed for this ffms2 read test - zip it, upload it and then everybody test in that venv on their machines... for VS, I created an isolated venv, but I used CK's Fatpack as a base, and there's too many other things included that are not needed for this minimal test... good news is that seekmode=0 is rock solid on my end (and not slower), and Lsmash as well, so it's not a show stopper... |
