9th August 2014, 23:22 | #20741 | Link | ||
24400 - 24450 was a pretty good target on 0.47.06, but looks like it's no longer the case with 0.47.07. Quote:
9th August 2014, 23:24 | #20742 | Link |
A gigabyte perhaps. But a couple hundred megabytes? You would have to play the two different types next to each other to see the difference. If any
10th August 2014, 00:04 | #20743 | Link | |
Mind you that I have said many times and I repeat: "Change the output size settings if you feel you must -- but please don't post a bug report when it oversizes". Last edited by jdobbs; 10th August 2014 at 00:08. |
10th August 2014, 00:08 | #20745 | Link | |
OK. That's weird, because I thought I had a pretty good idea of what BD-RB tends to output when the job has a lot of blanked titles and/or blanked audio tracks. A few titles I expected to come out very close to a full BD25 turned out 1-1.5 GB undersized on the 0.47.07. Welp, can't be helped, it's all good.
10th August 2014, 00:11 | #20746 | Link | |
10th August 2014, 10:12 | #20748 | Link | |
10th August 2014, 23:47 | #20749 | Link |
Problem with Need for Speed EAN 8713045242589, around the 1h24min mark (just around chapter change i think) the all sound is lost on the backup of the 2D Disc. Log below, anydvd rip same problem with PowerDVD, skipping along to 1.27min fixes it in PDVD but not standalone. I've got a feeling that (atleast on the backup) it's down to the 2 way split because it's pretty much right down the middle.
08/10/14] BD Rebuilder v0.47.07 (beta) [02:48:35] Source: NEED_FOR_SPEED - Input BD size: 41,05 GB - Approximate total content: [03:03:15.414] - Target BD size: 22,95 GB - Windows Version: 6.0 [6002] - MOVIE and MENUS mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [02:48:36] PHASE ONE, Encoding - [02:48:36] Blanking: VID_00004 (1 of 14) - [02:48:36] Blanking: VID_00005 (2 of 14) - [02:48:36] Processing: VID_00015 (3 of 14) - [02:48:36] Extracting A/V streams [VID_00015] - [03:04:22] Reencoding video [VID_00015] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 187.896 frames - Bitrate: 12.178 Kbs - [03:04:22] Reencoding: VID_00015, Pass 1 of 1 - [04:29:12] Video Encode complete - [04:29:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [04:29:12] Multiplexing M2TS - [04:43:26] Processing: VID_00032 (4 of 14) - [04:43:26] Extracting A/V streams [VID_00032] - [04:44:15] Reencoding video [VID_00032] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 3.393 frames - Bitrate: 8.632 Kbs - [04:44:15] Reencoding: VID_00032, Pass 1 of 1 - [04:45:33] Video Encode complete - [04:45:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:45:33] Multiplexing M2TS - [04:45:43] Processing: VID_00034 (5 of 14) - [04:45:43] Extracting A/V streams [VID_00034] - [04:46:50] Reencoding video [VID_00034] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 14.040 frames - Bitrate: 9.485 Kbs - [04:46:50] Reencoding: VID_00034, Pass 1 of 1 - [04:52:14] Video Encode complete - [04:52:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:52:14] Multiplexing M2TS - [04:52:42] Blanking: VID_00046 (6 of 14) - [04:52:42] Blanking: VID_00054 (7 of 14) - [04:52:42] Blanking: VID_00055 (8 of 14) - [04:52:42] Processing: VID_00064 (9 of 14) - [04:52:42] Extracting A/V streams [VID_00064] - [04:52:48] Reencoding video [VID_00064] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1 frames - Bitrate: 21.129 Kbs - [04:52:48] Reencoding: VID_00064, Pass 1 of 1 - [04:52:48] Video Encode complete - [04:52:48] Processing audio tracks - [04:52:48] Multiplexing M2TS - [04:52:52] Blanking: VID_00065 (10 of 14) - [04:52:52] Blanking: VID_00088 (11 of 14) - [04:52:52] Blanking: VID_00089 (12 of 14) - [04:52:52] Processing: VID_00091 (13 of 14) - [04:52:52] Extracting A/V streams [VID_00091] - [04:54:04] Reencoding video [VID_00091] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 17.366 frames - Bitrate: 9.556 Kbs - [04:54:04] Reencoding: VID_00091, Pass 1 of 1 - [05:00:47] Video Encode complete - [05:00:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [05:00:47] Multiplexing M2TS - [05:01:21] Processing: VID_00092 (14 of 14) - [05:01:21] Extracting A/V streams [VID_00092] - [05:02:33] Reencoding video [VID_00092] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 15.600 frames - Bitrate: 9.557 Kbs - [05:02:33] Reencoding: VID_00092, Pass 1 of 1 - [05:08:39] Video Encode complete - [05:08:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - [05:08:39] Multiplexing M2TS [05:09:27]PHASE ONE complete [05:09:27]PHASE TWO - Rebuild Started - [05:09:27] Rebuilding BD file Structure [05:10:44] - Encode and Rebuild complete [05:10:44] Writing BD structure to ISO file - ImgBurn completed successfully - NEED_FOR_SPEED folder removed. - WORKFILES folder removed. [05:23:28] JOB: NEED_FOR_SPEED finished. Last edited by Ch3vr0n; 11th August 2014 at 02:02. |
11th August 2014, 10:49 | #20750 | Link | |
I am sorry to bother everyone once more, I just have not gotten any replies on my message. I would really like some help with an issue if anyone has any tips or assistance for me. Once again, here is my original message:
11th August 2014, 17:41 | #20751 | Link | |
anyway, changing the working folder to C: seems to have solved it. Last edited by Archer_Jonathan; 11th August 2014 at 17:46. |
11th August 2014, 20:07 | #20752 | Link |
Update on Need For Speed: Seems to have been a faulty rip/encode. Ripped again with anydvd, ran it straight to BDRB and skipped ahead to 1h23m, crossed the problematic area of 1h24 with no problems and continued WITH audio for the rest of the movie
11th August 2014, 21:02 | #20753 | Link | |
11th August 2014, 21:19 | #20754 | Link |
the only diff was that DGdecNV was used and not x264/LAVF, i can run it again if you want using LAVF. Hadn't noticed until job done that a diff frameserver was used. But seeing as both use x264 for the actual encoding, dno if its needed
12th August 2014, 03:28 | #20756 | Link |
That's my thought too. Comparing the 2 versions I'm pretty sure a few frames were missing, faulty version didn't show a certain billboard, the working version did. Just for the sake of being thorough I'll run the job a 3rd time but with lavf again and see if it happens again.
** edit ** job just finished, looks to have been a faulty rip. Skipped ahead to 1h23, passed into 1h25+ without a problem Last edited by Ch3vr0n; 12th August 2014 at 06:25. |
12th August 2014, 03:33 | #20757 | Link | |
Anyone? Any thoughts - I'd really appreciate some help with this ..
12th August 2014, 07:44 | #20758 | Link |
Any news? Not meant as pushy, on the SRT and 720p.
12th August 2014, 14:48 | #20759 | Link |
I put a fix in that worked for me (lowering the font size). It's definitely a TSMUXER issue. The problem is that I'm not sure why it's doing it or whether there might be other sources that would result in the fix making it too small.
12th August 2014, 23:22 | #20760 | Link |
When using Alternate Output --- MKV Intact video and Intact audio 8 channel LPCM gets reprocessed down to 6 channels, DTS tracks retain all 8 channels.
log Code:
08/12/14] BD Rebuilder v0.47.07 (beta) [17:49:06] Source: WAR_00005 - Input BD size: 25.11 GB - Approximate total content: [01:43:00.215] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Automatic cropping of borders enabled - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV [4-way] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [17:49:06] PHASE ONE, Encoding - [17:49:06] Processing: VID_00005 (1 of 1) - [17:49:06] Extracting A/V streams [VID_00005] - [17:58:21] Reencoding video [VID_00005] - [17:58:21] Keeping original video (no reencode) - [17:58:21] Processing audio tracks [18:00:14]PHASE ONE complete [18:00:14]PHASE TWO - Rebuild Started - [18:00:15] Building ALTERNATE OUTPUT Structure [18:11:20] - Encode and Rebuild complete - WORKFILES folder removed. [18:11:21] JOB: WAR finished. Code:
[Options] VERSION=0.47.0.7 MULTIPROCESS=1 FIXED_CRF=18 HC_PROFILE=BEST DEFAULT_LANG=eng ENABLE_TEST=1 ENABLE_BLANKING=0 IMPORT_FOLDER=D:\ KEEP_HD_LPCM=1 DEINTERLACER_TYPE=3 UPRESIZE=LanczosResize SD_PROGRESSIVE=1 MOVIE_ONLY_LOOP=0 REMOVE_IMPORT=1 USE_ZLIB=0 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=1 AUTO_QUALITY=0 MENU_BACKGROUND=D:\IMPORTS\spawn.jpg MIN_M2TS_SIZE=1 IMPORT_THRESHOLD=19 QUICK_PLAY_THRESHOLD=10 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=1 OUTPUT_3D=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=8600 TARGET_SIZE=4469 MOVIEONLY_TYPE=7 ALTCRF=18 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=1 AUTO_BURN=0 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IGNORE_3D=1 OUTPUT_SBS=0 FRIMSOURCE=0 ENCODER=0 DGDECIM=0 TWEAK_PASS_ONE= --tune film TWEAK_PASS_TWO= --tune film [Paths] SOURCE_PATH=J:\ DGIndexNV=C:\Program Files (x86)\dgdecnv\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\dgdecnv\DGDecodeNV.dll WORKING_PATH=G:\ Code:
[Status] LABEL=WAR VERSION=v0.47.07 (beta) SOURCE_SIZE=26961383424 SOURCE_VIDEO_SIZE=26961383424 TARGET_SIZE=4686086144 REDUCTION=.173807332891851 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP= BACKUP_MODE=1 MOVIEONLY_TYPE=7 USE_LAVF=0 INSTANCES=4 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00005] USE_ORIGINAL=1 AUDIO=10000 PGS=0000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=4686086144 NSIZE=0 FLINK=0 MLINK=0 Last edited by gonca; 12th August 2014 at 23:28. |
