Old 23rd July 2016, 17:59   #2201  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by Reel.Deel View Post
Ok, figured out the problem, I had FFMS2.avsi file in there as well from an earlier FFMS2 version. The odd thing is that is has always been there and have not had a problem until now.
Edit: The ffms2.avsi was from v2.21. updating to the latest script fixed it.
Ok, that helps. Fix in next build.
AviSynth+
ultim is offline
Old 23rd July 2016, 18:56   #2202  |  Link
Groucho2004
Originally Posted by Sparktank View Post
Muli-threading support: Yes
Damn, I only now noticed that typo. Must have been there for quite a while.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 23rd July 2016, 22:38   #2203  |  Link
Originally Posted by ultim View Post
Is the difference really significant? I mean, are you sure it's not within the tolerance of measurement errors?
I'm sure, I did multiple runs and each time the CPU usage was a few percent lower, significant.. not really but then this script is only using ~25% CPU so this equates to 10% less CPU.
I'll upload the pics from Task manager later and also perform it again with some settings that push the CPU harder.
The differences are significant when I increase the load by substituting spline36 with nnedi3, here's the script.
ffdshow_source()
input4x = last.nnedi3_rpow2(rfactor=2, nsize=4, nns=1).nnedi3_rpow2(rfactor=2, nsize=4, nns=1,cshift="Spline36Resize")
edgemask = last.aSobel.aBlur
aWarp4(input4x,edgemask,depth=2)
Prefetch(4)
With SetFilterMTMode("DEFAULT_MT_MODE", 2) at top of script
Without
What's going on? Am using latest build 2082 with nnedi3 0.9.4.24 and pinterf's Awarpsharp.
ryrynz is offline
Old 24th July 2016, 11:24   #2204  |  Link
ultim
AVS+ Dev
ultim's Avatar
ffdshow_source()
Prefetch(4)
Tried to reproduce it but cannot, with or without ffdshow_source.
I also do not yet see how this could be possible. Anyone else seeing this on their computer?
AviSynth+
ultim is offline
Old 24th July 2016, 11:42   #2205  |  Link
I am using ffdshow raw with 16 read ahead buffers and MPC-BE if it makes any difference.
ryrynz is offline
Old 24th July 2016, 16:46   #2206  |  Link
ultim
AVS+ Dev
ultim's Avatar
r2085 solves "Parse: Unrecognized exception!", and the problem with eedi3 (actually any plugin that uses OpenMP).
AviSynth+
ultim is offline
Old 24th July 2016, 17:17   #2207  |  Link
Wilbert
Originally Posted by pinterf
Bit-depth conversions (no dithering, no range conversion, etc...)[LIST][*]ConvertTo8bit()[*]ConvertTo16bit()[*]ConvertToFloat()
[/L IST]
Btw, regarding the functions ConvertTo8Bits(), etc ...
What about replacing them with a single one:
ConvertToBitDepth(bit-depth=8/16/float, dither=none/random/ordered/...)
http://forum.doom9.org/showthread.ph...17#post1773217
Wilbert is offline
Old 24th July 2016, 19:56   #2208  |  Link
pinterf
Originally Posted by Wilbert View Post
Didn't forget. And since there seem to be more new functions, once hight bit-depth rgb, planar rgb and the 10-14 bit things get added, somehow we'll have to keep order.
pinterf is offline
Old 24th July 2016, 22:06   #2209  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
No more crashes with .avsi in plugin_dir.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline
Old 25th July 2016, 12:02   #2210  |  Link
yup
Hi all!
Please advice way overwrite existing Avisynth.dll under Windows 10.
I am try using Freecommander run like admin, I do not see Avisynth.dll Windows/system32, but windows search show me at Windows/system32.
On my PC also run Avira antivirus.
yup.
yup is offline
Old 25th July 2016, 12:06   #2211  |  Link
If you use a 32 bit application as file manager, you have only access to the 32 bit system directory which is camouflaged as "Windows\system32" to a 32 bit application, but instead is "Windows\SysWOW64" in the file system under a 64 bit Windows OS. You need to use a 64 bit application as file manager to have access to both locations if you have a 64 bit Windows OS.
Being old enough to have used the Norton Commander during the DOS era, I still enjoy the Far manager. It is abailable as both 32 bit and 64 bit application.
Once again for a clarification:
a) You have a 32-bit version of Windows (usual up to Windows 7, later deprecated):
  • Windows\system32 is your system directory for 32 bit DLLs and tools.
b) You have a 64-bit version of Windows (most probable from Windows 8 on, although already available earlier):
  • Windows\system32 is your system directory for 64 bit DLLs and tools. Only 64 bit applications will see this directory at all. It is hidden from 32 bit applications.
  • Windows\SysWOW64 is your system directory for 32 bit DLLs and tools. Only 64 bit applications will see this directory with this name. 32 bit applications will see this with the fake name Windows\system32.
This technique will ensure that each kind of application (32 or 64 bit) will look for their matching system DLLs always in a directory named "Windows\system32", and only the matching one is visible to them under this name.
LigH is offline
Old 25th July 2016, 12:49   #2212  |  Link
yup
LigH!
Thanks for clarification.
I am install Multi Commander 64 bit and lucky.
yup.
yup is offline
Old 25th July 2016, 17:50   #2213  |  Link
yup
"14.0.24210" is indeed the latest, my mistake. As for your problem, I have no idea, try cleaning up the auto-load directory so you have only the DLLs installed with AVS+.
Thanks for advice!
Problem was related with jpsdr build nnedi3, after update all O'k.
yup.
yup is offline
Old 25th July 2016, 18:19   #2214  |  Link
burfadel
14.0.24210 is buggy. Microsoft released an update for it, but have seemed to have stuffed up the distribution of it! The updated version is 14.0.24212.
You can use my Redist installer, it has all the last runtimes for 2005 through to 2015, x86 and x64 versions (including the new 24212):
Visual C++ Redist Installer V44 - https://1drv.ms/u/s!AmGuHbW3zvrBmJFCnPBSK-pMSdxshA
burfadel is offline
Old 26th July 2016, 08:58   #2215  |  Link
jpsdr
And so, how did you get it ?
jpsdr is offline
Old 26th July 2016, 10:09   #2216  |  Link
yup
After update to last version avs+ i am changed my script from
SetMemoryMax(1536)
SetFilterMTMode("DEFAULT_MT_MODE",3)
Edibob=AVISource("pre14last.avi")## source YUY2 50 fps bobbed
SetFilterMTMode("DEFAULT_MT_MODE",2)
Edibob=Edibob.AssumeTFF()
Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF()
QTGMC(Tuning= "DV-SD",preset="Slow", Ediext=Edibob, Edithreads=1, EZDenoise=6, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2,dct=5, search=5)
nnedi3_rpow2(rfactor=2,nns=2, qual=1, fwidth=1004, fheight=752,cshift="Spline36Resize").Crop(22,16,-22,-16)
unsharp(varY=465,varC=232,strength=0.3,U=3,V=3)
ConvertToYV12(interlaced=false)
ColorMatrix(mode="Rec.601->Rec.709")
PreFetch(8)
to
PreFetch(8)
All work stable, speed little lower if comparing to Set Mt version, but stability more important.
I am using 32 bit version because not all plugin available for 64.
yup.
yup is offline
Old 26th July 2016, 10:37   #2217  |  Link
burfadel
The 24212 runtime packages are available to download from Microsoft if you know where to look. It appears they haven't updated the articles properly, but there are Microsoft download links that direct to the new version.
burfadel is offline
Old 26th July 2016, 11:39   #2218  |  Link
real.finder
14.0.24212-x86
http://download.microsoft.com/downlo...redist.x86.exe
14.0.24212-x64
http://download.microsoft.com/downlo...redist.x64.exe
See My Avisynth Stuff
real.finder is offline
Old 29th July 2016, 10:59   #2219  |  Link
Groucho2004
I made a new installer with the latest r2085 binaries.
Also, ricktendo updated his AIO runtime installer to include the 14.0.24212 runtimes.
With ricktendo's installer you can also selectively install runtimes. I made a batch file for that:
@echo off
:VS2005
start/wait VBCRedist_AIO_x86_x64 /ai5
:VS2008
start/wait VBCRedist_AIO_x86_x64 /ai8
:VS2010
start/wait VBCRedist_AIO_x86_x64 /aiX
:VS2012
start/wait VBCRedist_AIO_x86_x64 /ai2
:VS2013
start/wait VBCRedist_AIO_x86_x64 /ai3
:VS2015
start/wait VBCRedist_AIO_x86_x64 /aiV
There are a few more options, use "VBCRedist_AIO_x86_x64 /?".
Old 29th July 2016, 11:06   #2220  |  Link
tormento
Acid fr0g
tormento's Avatar
@turment on Telegram
tormento is offline
