19th June 2021, 17:12 | #1121 | Link |
Not generally possible. They may handle fundamentally different actions (e.g. VirtualDub has no substitute to every possible AviSynth filter and NLE feature, whereas AviSynth is not able to select a codec for the compression).
19th June 2021, 18:47 | #1122 | Link | |
19th December 2021, 21:22 | #1124 | Link |
Yo shekh,
If you do get back to this, can I ask if cursor in AVS script editor be sizeable, specifically adjust width wider, on 4K monitor and Windows 10 scaling to 150%, cursor is almost invisible in the editor [W10 scaling or Ease of Access cursor width seems to make no difference]. I quite often find myself having to click with the mouse so I can tell where the cursor is. Thanks muchly
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th December 2021 at 21:25. |
11th September 2022, 03:54 | #1130 | Link |
Due to circumstances involving my laptop's GPU being busted, I am foced to use my Woindws XP comuter. I wanted to convert my videos to .mp4 but while converting my video, I encountered an error called "Requested frame not found". I am not sure what has caused this error but I want to convert my videos using Virtualdub2. Can anyone help me?
11th September 2022, 16:51 | #1131 | Link |
With my limited knowledge I would say that
the video stream is defect in some way. Try different decoder (at VD2's open dialog), or try avidemux. If successfull check the audio (sync and quality). |
12th September 2022, 15:43 | #1132 | Link | |
From another of your threads, [EDIT: GAP threads] Quote:
https://forum.doom9.org/showthread.php?t=183052 Maybe suggest trying the batch script with that error producing clip, BAT(same thread) = https://forum.doom9.org/showthread.p...05#post1948505 See if ffmpeg gives any further info in error message for the missing frame, perhaps it can even auto conceal the error. (producing legal output clip) EDIT: OR smaller bat script. Output UT_Video, AVI. SomethingOrOther.bat Code:
setlocal REM Where to Find ffmpeg set FFMPEG="C:\BIN\ffmpeg.exe" REM Where to get input file, No terminating Backslash, "." = current directory set INDIR="." REM Where to place output file, No terminating Backslash. set OUTDIR="D:" FOR %%A IN (*.wmv *.mpg *.avi *.flv *.mov *.mp4 *.m4v *.RAM *.RM *.mkv *.TS *.ogv *264 *.webm *.m2v *.VOB) DO ( %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" ) Pause Create CONVERT Folder. Copy bat and source clips into that folder. Ensure FFMPEG line points to your ffmpeg binary. Run the bat. (The Bat dont like SPACES nor weird foreign chars in filenames)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th September 2022 at 01:34. |
19th September 2022, 21:53 | #1134 | Link | |
SuperVirus
<OT>
Next time please try to write just "non-ASCII characters". It's true that the Amerikans have the bad habit of assuming that they are the center of the universe; however it's easy to forget that they inherited this bad habit from the Brits. </OT> |
19th September 2022, 23:02 | #1135 | Link |
I consider my bottom well smacked ! (but will likely repeat said faux pas )
One day we will take back that colony and re-establish the center of the Universe
5th November 2022, 12:35 | #1137 | Link | |
Until today (v44282) all virtualDub2 versions work with XP, some third party plugins (as Filtres_JPSDR) may fail. Last edited by isidroco; 5th November 2022 at 13:16. |
5th November 2022, 13:28 | #1138 | Link | |
You may try to fix corrupted video: http://www.risingresearch.com/en/dvr/ |
