Old 25th April 2010, 07:56   #21  |  Link
copaceticgeek
Out of curiosity, is it possible to have both the x86 and x64 Megui installed at the same time? What conflicts may arise?
copaceticgeek is offline   Reply With Quote
Old 25th April 2010, 08:07   #22  |  Link
Eretria-chan
Yep. It's possible. I have both installed.
I've seen no conflicts whatsoever so far.
Eretria-chan is offline   Reply With Quote
Old 25th April 2010, 17:26   #23  |  Link
aegisofrime
Originally Posted by quantum5uicid3 View Post
64bit mencoder.exe
I tried Googling around but apparently there are no 64-bit builds of Mencoder. Zathor could you confirm? Thanks!
aegisofrime is offline   Reply With Quote
Old 25th April 2010, 23:08   #24  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Well,I think that 64-bit mencoder.exe doesn't exist, at least for now. Who knows what future could bring to us, Zathor ?
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
Old 26th April 2010, 00:19   #25  |  Link
quantum5uicid3
it's possible, but alot of stuff is broken, so i don't think anyone has made it widely available. we just need a build with avs input and ffvhuff out. i tried to get ffmpeg to do it but it wont for some reason. it starts but end up dropping all frames.
>ffmpeg -i test.avs -vcodec ffvhuff -context -2 -vstrict -1 -an
test.avi
FFmpeg version SVN-r22941, Copyright (c) 2000-2010 the FFmpeg developers
  built on Apr 22 2010 06:18:44 with gcc 4.4.2
  configuration: --cross-prefix=x86_64-w64-mingw32- --cc=ccache-x86_64-w64-mingw
32-gcc --extra-cflags='-Dstrtod=__strtod' --arch=x86_64 --target-os=mingw32 --en
able-runtime-cpudetect --enable-avisynth --enable-gpl --enable-version3 --enable
-bzlib --enable-libgsm --enable-libfaad --enable-pthreads --enable-libvorbis --e
nable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --ena
ble-libxvid --enable-libschroedinger --enable-libx264 --enable-libopencore_amrwb
 --enable-libopencore_amrnb
  libavutil     50.14. 0 / 50.14. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.61. 0 / 52.61. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
Input #0, avs, from 'test.avs':
  Duration: 00:00:04.21, start: 0.000000, bitrate: 0 kb/s
    Stream #0.0: Video: rawvideo, yuv420p, 1280x720, 265155 kb/s, 23.98 tbr, 23.
98 tbn, 23.98 tbc
File 'test.avi' already exists. Overwrite ? [y/N] y
Output #0, avi, to 'test.avi':
  Metadata:
    ISFT            : Lavf52.61.0
    Stream #0.0: Video: ffvhuff, yuv420p, 1280x720, q=2-31, 200 kb/s, 23.98 tbn,
 23.98 tbc
Stream mapping:
  Stream #0.0 -> #0.0
Press [q] to stop encoding
frame=    1 fps=  0 q=0.0 size=     675kB time=0.04 bitrate=132520.3kbits/s dup=
frame=    1 fps=  1 q=0.0 size=     675kB time=0.04 bitrate=132520.3kbits/s dup=
frame=    1 fps=  0 q=0.0 Lsize=     675kB time=0.04 bitrate=132524.9kbits/s dup
=0 drop=100
video:669kB audio:0kB global headers:0kB muxing overhead 0.832433%
quantum5uicid3 is offline   Reply With Quote
Old 26th April 2010, 22:20   #26  |  Link
Romario
Romario's Avatar
Well,life is hard enough,you can't expect from devs to compile all things in 64=bit so fast.
See, Avisynth also have big problems to compile in 64-bit mode. I don't know is the 64-bit asm code is perfect,but. at least, we have it.
Old 27th April 2010, 22:09   #27  |  Link
quantum5uicid3
when a queue is running, i've gotten this error a few times when it starts the next job. it has happened when starting a 1st pass on one file and the second pass on another, so appears to be randomly occuring. if i restart the queue with no changes besides resetting the failed job, it runs again np. like it's failing to open another ffms instance or something immediately sometimes. i have not experienced this in the 32bit build using identical settings.
megui error:
-[Information] Log for job16 (video, so.avs -> )
--[Information] [4/27/2010 3:46:49 PM] Started handling job
--[Information] [4/27/2010 3:46:49 PM] Preprocessing
-[NoImage] Error starting job
--[NoImage] Exception message
---[NoImage] Calling setup of processor failed with error 'The file C:\vidz\so.avs cannot be opened.
---[NoImage] Error message for your reference: Evaluate: Unrecognized exception!
---[NoImage] (C:\vidz\so.avs, line 2)'
--[NoImage] Stacktrace: at MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job)
--[NoImage] Inner exception: null
--[Information] [4/27/2010 3:49:06 PM] Started handling job
--[Information] [4/27/2010 3:49:06 PM] Preprocessing
--[NoImage] Job commandline: "C:\Program Files\megui\tools\x264\x264.exe" --tune film --pass 1 --bitrate 4694 --stats "C:\vidz\so.stats" --b-adapt 2 --merange 64 --me umh --direct auto --subme 10 --partitions all --trellis 2 --no-fast-pskip --level 4.1 --bframes 3 --ref 6 --slices 4 --aud --nal-hrd vbr --b-pyramid strict --keyint 24 --min-keyint 2 --vbv-bufsize 14000 --vbv-maxrate 14500 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --output NUL "C:\vidz\so.avs"
avs
LoadCPlugin("C:\Program Files\megui\tools\ffms\ffms2.dll")
FFVideoSource("capture0223.mkv",colorspace="YV12")
Spline64Resize(1280,720)
addition:
ive tried to crash the same avs outside of megui by opening many instances simultaneously starting them back to back and they just keep opening. i can reproduce by running a queue of about 20 or so 2pass 200 frame encodes from an HD source. it looks like megui memory usage just keeps going up... at about 1.5GB used it starts crashing intermittently on a core2quad@3 4gb vista
32bit megui.exe does not exhibit the same memory usage beahvior on this computer
Old 30th April 2010, 16:45   #28  |  Link
Buggle
Thank you so much for all this hard work!
Currently running a DVD backup and it's working fine
On a small note: maybe it would be possible to grey out options that cannot be used due to no (suitable) plugin/program available? Then limitations are more clear. For instance, to my knowlede there currently is no Nero AAC x64 edition, so the path to the external program could be greyed out.
Old 30th April 2010, 19:34   #29  |  Link
quantum5uicid3
the 64bit nicaudio will feed 32bit audio encoders. i know ac3 to nero aac works. old version, so some files like mp3s give
Script error: there is no function named "NicMPG123Source"
though. i think it's slower too, but haven't compared side by side.
can someone confirm that memory usage gradually keeps going up while queue is running?
Old 30th April 2010, 23:33   #30  |  Link
Buggle
the 64bit nicaudio will feed 32bit audio encoders. i know ac3 to nero aac works. old version, so some files like mp3s give though. i think it's slower too, but haven't compared side by side.
Well I've tried to encode to Nero AAC and that did not work (AC3 source), unfortunately. I have to use the MeGUI 32 to encode audio. But hey, I do not consider that to be a great problem, since I can run them in parallel.
Old 1st May 2010, 13:41   #31  |  Link
quantum5uicid3
it works fine. megui is going to look for nicaudio.dll in the megui\tools\avisynth_plugin\*
did you get squid*80's build? did you install it?
i even did a quick speed comparison against the current nicaudio and i was wrong.
source: 6channel ac3 600MB 2h 11mn 640 Kbps
same script on both except the paths being different. using sets 32 bit vs sets 64bit port
encoder
32bit neroAacEnc.exe on both
avs
Avisynth script
---[NoImage] LoadPlugin("C:\Program Files (x86)\megui\tools\avisynth_plugin\NicAudio.dll")
---[NoImage] NicAc3Source("C:\movies\01\F1_T3_Audio - English.ac3")
---[NoImage] 6<=Audiochannels(last)?x_stereof33140e04faa4519b7c2353a5997f465(ConvertAudioToFloat(last)):last
---[NoImage] Normalize()
---[NoImage] return last
---[NoImage] function x_stereof33140e04faa4519b7c2353a5997f465(clip a)
---[NoImage] {
---[NoImage] fl = GetChannel(a, 1)
---[NoImage] fr = GetChannel(a, 2)
---[NoImage] c = GetChannel(a, 3)
---[NoImage] lfe = GetChannel(a, 4)
---[NoImage] sl = GetChannel(a, 5)
---[NoImage] sr = GetChannel(a, 6)
---[NoImage] l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
---[NoImage] c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
---[NoImage] r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
---[NoImage] l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
---[NoImage] r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
---[NoImage] return MergeChannels(l, r)
---[NoImage] }
--[NoImage] Commandline used: -ignorelength -q 0.3 -if - -of "{0}"
total encoding time from job start to job finished
32bit
12min 18sec
64bit
11min 22sec
edit
i guess i should reiterate that its old and is missing many fixes and it predated NicMPG123Source, so several inputs are broken.
directshowsource and avisource look to be ok too
Old 1st May 2010, 20:24   #32  |  Link
Zathor
Thats the reason why I have not included it. The source is available so maybe someone can compile a 64bit build.
Old 4th May 2010, 21:50   #33  |  Link
KSab
Good afternoon!
Help to understand. At start MeGUI.exe drops out here with such error.
From the first post I have copied the necessary files. Versions MeGUI x86 works normally! Operating system - Windows Server 2003 Enth Eng x64.
KSab is offline   Reply With Quote
Old 5th May 2010, 09:40   #34  |  Link
Zathor
Please post the error message or upload the picture to an external hoster.
Old 5th May 2010, 14:44   #35  |  Link
KSab
ok, sorry.
Old 5th May 2010, 23:10   #36  |  Link
quantum5uicid3
64bit programs go in the \program files\. did you install libraries in proper directories? and make sure .NEt is current
Program Files 64bit programs
System32 64bit libraries
Program Files (x86) 32bit programs
syswow64 32bit libraries
no one else is experiencing high memory usage? i mean megui.exe just keeps allocating more and more ram over an extended period of time.
Old 6th May 2010, 08:24   #37  |  Link
KSab
I have copied the files specified in the first message (ICSharpCode.SharpZipLib.dll, LinqBridge.dll, MessageBoxExLib.dll, and MeGUI.exe x64) in a folder with established MeGUI x32.
Has transferred from a folder "Program Files (x86)" to a folder "Program Files". Has changed Nothing.
Old 8th May 2010, 10:24   #38  |  Link
rogersnm
I get the same error as KSab on Windows Server 2003 x64, the x86 version runs fine however the x64 version gives the error message "This application has failed to start because the application configuration is incorrect", regardless of where I run it from. In comparison, on Windows Server 2008 R2 x64 I can execute the x64 version straight from the .zip and it runs fine.
The two operating systems have the same packages installed (according to "Add/Remove Programs") however it fails to run on 2003.
rogersnm is offline   Reply With Quote
Old 8th May 2010, 11:37   #39  |  Link
Zathor
I am just guessing - maybe you have to install the visual c++ runtimes for x64?
Old 8th May 2010, 20:07   #40  |  Link
KSab
For me Microsoft Visual C ++ 2008 x64 is already installed.
