Old 14th June 2019, 18:55   #6841  |  Link
ChaosKing
Different settings affect the CRF output: https://x265.readthedocs.io/en/defau...r-enhancements
Preset: change param defaults for veryslow and slower preset. Replace slower preset with defaults used in veryslow preset and change param defaults in veryslow preset as per experimental results.
AQ: change default AQ mode to auto-variance
Old 14th June 2019, 20:54   #6842  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Filesize is probably due to the default aq-mode being 2 now. It often causes a higher average bitrate with the same CRF than aq-mode 1.
Old 15th June 2019, 01:25   #6843  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
The preset changes also mean veryslow is radically different relative to 2.4.
[edit] Just saw this was mentioned already [/edit]
Old 15th June 2019, 16:13   #6844  |  Link
katzenjoghurt
The zones feature is broken in 3.0+2, it encodes to the end but returns an error code, cmd/batch users normally don't check for the exit code, so they don't notice the problem but staxrip treats this a fatal and aborts further processing.[...]
Could some kind soul please, please, pretty please investigate this bug?
It is so annoying.
It means that after every encoding with zones (with an affected tool) your would need to do the muxing manually afterwards
as the tool crashes away due to the returned x265 error code.
See also: https://bitbucket.org/multicoreware/...hen-using-zone
Old 15th June 2019, 17:43   #6845  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
My settings were 100% identical.
Old 15th June 2019, 21:56   #6846  |  Link
Boulder
Pig on the wing
Boulder's Avatar
No they're not if you look at the output in your post. I still think the biggest difference comes from aq-mode changing from 1 to 2. The other changes should cause a much smaller change in the bitrate.
EDIT: as mentioned earlier, the presets have been changed. Veryslow in v2.4 is different from v3.0.
Old 15th June 2019, 22:29   #6847  |  Link
Barough
Barough's Avatar
x265 v3.1_RC1+3-3bdf06e3c628 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.1.0)
https://bitbucket.org/multicoreware/x265/commits/branch/Release_3.1
Old 16th June 2019, 07:09   #6848  |  Link
StvG
It is so annoying.
Use VS20xx not GCC x.x build from here.
StvG is offline   Reply With Quote
Old 16th June 2019, 10:49   #6849  |  Link
katzenjoghurt
Hey StvG,
in fact I already do. I'm using the VS2019 versions from there.
Old 16th June 2019, 11:01   #6850  |  Link
katzenjoghurt
Oh my.
Am I the only one having such a hard time encoding scenes with red light / red backgrounds?
Oh man. I THINK I finally found a solution for my neverending problem with red areas getting blurred and/or blocky.
People already gave me a hint to use 10bit encoding or playing around with the crqpoffs parameter. Both didn't really help.
This changed drastically now after I converted the source to YV24 colorspace and encoded it with Main 444 10.
Suddenly the crqpoffs parameter started to work wonders and setting it to -1 already brought back most of the details.
How to do it in StaxRip 1.7.0.6:
1) Click on the "AVS Filter" label. Click "Profiles".
2) Find the [Misc] section and add this line to the bottom: ConvertToYV24 = ConvertToYV24()
3) Add the Filter now via right-click -> Misc -> ConvertToYV24
4) Go into the x265 encoder settings
5) In "Basic" chose the Main 444 10 profile.
6) In "Rate Control 1" set CR QB Offset to -1.
Old 17th June 2019, 05:20   #6851  |  Link
StvG
Hey StvG,
Hey. A week ago or so I tested VS2019 builds and I had no problems when using zones. GCC builds were crashing when using zones.
Old 17th June 2019, 09:12   #6852  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
I thought CRF actually meant something. Not really a given bitrate but something close to it.
Old 17th June 2019, 11:05   #6853  |  Link
mini-moose
the lower the CRF value, the higher the bitrate. slowdown is due to preset changes, bitrate differences are due to AQ mode changing from AQ1 default to AQ2 default.
I found that AQ1 was giving a higher bitrate than AQ2, but I suppose it depends on source. I think AQ1 is constant while AQ2 is variable.
mini-moose is offline   Reply With Quote
Old 18th June 2019, 07:19   #6854  |  Link
CRF means: Constant Rate Factor. It keeps an internal distortion metric in the encoding workflow (called "rate factor") below a threshold. But many details are part of the RF calculation, and not all represent your personal subjective quality impression perfectly. Yet, it is a much better one than PSNR and allows an easy adjustment of the quantization with some respect to the encoding complexity. But a few seemingly paradox results may happen. Heavier efforts do not always result in more efficient video stream code or visually more convenient pictures, exceptions from a general rule aren't impossible.
Old 18th June 2019, 14:33   #6855  |  Link
jlpsvk
welcome back LigH. Missing new builds from you. Haven't seen you for a longer time here active.
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 18th June 2019, 17:51   #6856  |  Link
katzenjoghurt
Oh man. You put my hopes so high...
Tried out RC1+3 (built with VS2019) but... no luck - it still crashes for me.
Video encoding [...] failed with exit code: -1073740940 (0xC0000374)
The exit code might be a system error code: Ein Heap wurde beschädigt.
x265 [info]: HEVC encoder version 3.1_RC1+3-3bdf06e3c628
*sigh*
Old 19th June 2019, 03:19   #6857  |  Link
benwaggoner
Error disabling --hdr-opt
So, I am trying to do a lossless HDR encoding test.
x265.exe - --y4m --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --hdr --hdr-opt -o 4K_LOSSLESS.hevc
And I get this error, which sounds like hdr-opt is getting deactivated because it is confused about the metadata?
Output #0, yuv4mpegpipe, to 'pipe:':
Metadata:
encoder : Lavf58.27.103
Stream #0:0: Video: wrapped_avframe, yuv420p10le, 3840x2160, q=2-31, 200 kb/s, 24 fps, 24 tbn, 24 tbc
Metadata:
encoder : Lavc58.53.100 wrapped_avframe
y4m [info]: 3840x2160 fps 24/1 i420p10 unknown frame count
raw [info]: output file: D:\Octarine\foo_4k_HDR.hevc
x265 [info]: build info [Windows][MSVC 1921][64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [error]: Recommended Settings for HDR: colour primaries should be BT.2020,
transfer characteristics should be SMPTE ST.2084,
matrix coeffs should be BT.2020,
the input video should be 10 bit 4:2:0
Disabling offset tuning for HDR videos
x265 [warning]: Turning on repeat-headers for HDR compatibility
Everything seems set up just fine. Any thoughts about what might be going on here?
Ben Waggoner
My Compression Book
Old 19th June 2019, 08:43   #6858  |  Link
Ah, well ... had some issues with other projects compiled in MABS, and more work thus less spare time. And there are so many competitors now. But a "merge with stable" is a reason to publish another one.
Old 19th June 2019, 09:33   #6859  |  Link
Blue_MiSfit
@benwaggoner I'd suggest patching out the feature that disables hdr-opt in certain conditions. You certainly know what you're doing and it's a one-line fix
Old 19th June 2019, 17:08   #6860  |  Link
benwaggoner
First off, I want to know what the conditions are. I don't dismiss the possibility that I don't know what I'm doing in some aspect .
Ben Waggoner
My Compression Book
