14th June 2015, 19:37 | #13581 | Link |
I would check CPU stability and memory first. Overheating cpu or faulty memory may case those glitches.
14th June 2015, 21:39 | #13582 | Link |
Thought I would comment that this program works greatly! Very easy to use and a simple GUI. One function I would suggest is an option in batch mode to auto crop. It is a very painful process when trying to auto crop a number of files manually. That is all =)
14th June 2015, 21:41 | #13583 | Link |
OKay here is what I found using 1.18.2 with the firewall off.
XMen Days of future past. First Pass very slow fps 8-10 Second Pass seemed normal 15 to 20 fps Encoded file did not save First Pass again 2320 to 31 fps Second pass Seemed slow some 2 to 16 fps Files saved properly 1.18.1 First Pass 20-32 fps Second Pass 15 to 20 fps File saved properly Riddick Roughly the same numbers as above as well for versions 1.18.2 & 1.18.1 First file did not save either. Did not try a second attempt with 1.18.2. Went straight to 1.18.1 In summary 1.18.1 is much more efficient and reliable in converting movies... |
15th June 2015, 01:58 | #13584 | Link |
Registered Loser
Since Upgrading to 1.18.2, I'm getting audio encoding timeouts, which I have never gotten before (going back several years):
E:\Temp\RipBot264temp\job44>"D:\RipBot\tools\avs2pipemod\avs2pipemod.exe" -wav "E:\Temp\RipBot264temp\job44\job44_AUDIO1.avs" | "D:\RipBot\Tools\opus-tools\opusenc.exe" --bitrate 240 --ignorelength --quiet - "E:\Temp\RipBot264temp\job44\Encoded_Audio_1.opus" avs2pipemod[error]: DirectShowSource : Timeout waiting for graph to start. (E:\Temp\RipBot264temp\job44\job44_AUDIO1.avs, line 6) Error parsing input file: - This is what I get when running "jobXX_EncodeAudio1.cmd" manually. However, I can just run it again, and it usually works. I then just run the jobXX_Muxfiles. However, I'm getting maybe a 50% failure rate. Ideas? I can use eac3to and pipe it to opusenc.exe and never get any problems. System is a i7-4770, 16gb RAM. Temp drive is a RAID-0 pair of disks. |
15th June 2015, 10:46 | #13586 | Link |
at this point I can only advise you to uninstall avisynth, haali, ffdshow. Reboot and install everything again. Btw use latest avisynth 2.60
16th June 2015, 05:33 | #13588 | Link | |
https://dl.dropboxusercontent.com/u/...ieEncoding.pdf I tried it with no success. I use AnyDVD HD to rip the blu ray and then use RipBot264 to encode to an MKV. So I decided to use MakeMKV to rip the Blu ray. It of course creates a MKV file. When I use that MKV file with RipBot264 it works perfectly and very fast. So I decided to try another Blu-ray disc, The last of the Mohicans. I ripped with AnyDVD HD and tried to encode. RipBot crashed halfway thru Pass 2. It gave me the following error: I will be using MAKEMKV again to see if that will work... |
16th June 2015, 12:14 | #13589 | Link |
Viper714
There should be a log saying what went wrong. See \Logs\Jobx_log.txt Regarding encoding speed. What is CPU usage when you see fps drop? Thanks. I think I know what happens here. Fix is on the way.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th June 2015 at 12:39. |
16th June 2015, 16:40 | #13590 | Link |
agressiv & Viper714
This patch should solve that DirectShowSource Timeout error. Also EncodingServer has been updated and hopefully fixed. http://www.mediafire.com/download/uc...1.18.3_beta.7z Make sure that every PC has updated EncodingServer.exe. Also re-fresh already created jobs (select job -> Edit -> Done)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th June 2015 at 16:44. |
16th June 2015, 17:01 | #13591 | Link | |
Also BTW the above error shows in all 4 PC's not just the one that is handling the distributed encoding. Log Files Encoding Riddick #1 Failed Ripped via AnyDVD HD https://dl.dropboxusercontent.com/u/...9/Job5_log.txt Encoding Riddick #2 Failed Ripped via AnyDVD HD a second time https://dl.dropboxusercontent.com/u/...9/Job1_log.txt Encoding Riddick #3 Success Ripped via MakeMKV https://dl.dropboxusercontent.com/u/...9/Job2_log.txt Encoding Last of the Mohicans #1 Failed Ripped via AnyDVD HD https://dl.dropboxusercontent.com/u/...9/Job3_log.txt Hope this helps!! |
16th June 2015, 17:09 | #13592 | Link |
Also show me 1.txt , 2.txt and so on files from \jobx\chunks\ folder. Pack them into one archive.
16th June 2015, 17:10 | #13593 | Link | |
16th June 2015, 18:35 | #13594 | Link |
Atak,
First findings,
Will get back to you after encoding... Last edited by Viper714; 16th June 2015 at 18:39. |
16th June 2015, 18:46 | #13595 | Link |
I'm Windows 7 guy so this won't be "fixed". On my OS I do not get those silly popups . Besides How am I supposed to fix this? It is sad that with every new version user is treated like 10 year old kid.
16th June 2015, 19:00 | #13596 | Link | |
https://dl.dropboxusercontent.com/u/...led%20job3.zip |
16th June 2015, 19:06 | #13597 | Link |
Atak, when trying to encode all of the servers are blinking from "encoding" to "idle" over and over. This is even happening on the local machine... I rest the router and n the same issue. New IP addresses were given to some of the machines, but I re-authorized firewall access which happens on start of Ripbot264.
I turned off the firewall just in case with no joy. |
16th June 2015, 19:20 | #13599 | Link | |
for example \\SERVER-PC\RipBot264temp\job1\Chunks\1.cmd
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th June 2015 at 19:27. |
