26th March 2020, 23:16 | #7481 | Link |
Hi i changed some settings in x265 and for 4k HDR content i came very close to the slow preset quality with 2-3 times faster speed and around 30% smaller file.
here you can check the pictures. https://www.dropbox.com/sh/yabmid1md...PUI5otsna?dl=0 CRF 17 hdr10-opt was used in both rips. |
27th March 2020, 19:00 | #7482 | Link |
SuperVirus
x265.exe 3.3+12-00b686782ad0
(GCC 9.3.0, x64, multilib) Latest changes: Code:
1) Fix: clis in regression txt file. 1. corrects file naming convention. 2. updates deprecated rskip clis options. 2) zone: Enable strict VBV conformance for zone encode as per requirement 3) - Fixes mismatch in BufferRate with dynamic zone reconfiguration when bufferrate varies for each zone - Logs UnclippedBufferFillFinal into csv when csvloglevel greater than 1 4) Add option to get global maxrate. This global maxrate can be used for HRD signaling. 5) zone: Remove unnessary conditions on zone reconfig This commit - Removes unnessary conditions on zone reconfig - Fixes crash with dynamic zone reconfig Last edited by filler56789; 27th March 2020 at 19:01. Reason: edit |
27th March 2020, 19:27 | #7483 | Link | |
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD |
27th March 2020, 21:33 | #7484 | Link |
Other settings are from default medium preset this are the changed ones
--crf 17 --level-idc 5.1 --output-depth 10 --rdoq-level 2 --cu-lossless --aq-mode 4 --max-merge 3 --rc-lookahead 25 --lookahead-slices 4 --ref 4 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "xxx,xxx" --hdr --hdr-opt --repeat-headers --hrd --aud --deblock -1:-1 --no-strong-intra-smoothing |
1st April 2020, 13:03 | #7485 | Link |
SuperVirus
x265.exe 3.3+19-1d2f556
http://msystem.waw.pl/x265/ Changes after commit 00b6867: https://bitbucket.org/multicoreware/x265/commits/all |
1st April 2020, 18:08 | #7486 | Link |
x265 v3.3+17-gdf2ac512d (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.3.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master |
1st April 2020, 20:27 | #7487 | Link | ||
x265 [info]: HEVC encoder version 3.3+19-1d2f556ffb12 x265 [info]: build info [Windows][MSVC 1900][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [error]: internalBitDepth must match compiled bit depth x265 [error]: x265_encoder_open() failed for Enc, x265 [error]: Failure generating stream headers 0 Error: fwrite() call failed when writing frame: 1, plane: 0, errno: 32 Output 34 frames in 24.73 seconds (1.37 fps) Quote:
But it's OK with 3.3+10-g08d8 Last edited by LazyNcoder; 1st April 2020 at 20:38. |
1st April 2020, 21:13 | #7488 | Link |
Herr
LazyNcoder, yeah, I had error in the program "Simple x264 Launcher v2" (set to 10-bit encode) with x265.exe from x265-3.3+19-1d2f556_gcc100-AVX2.7z, but when I instead used x265-10b.exe it worked fine!
With old x265-3.3+10 x265.exe worked in "Simple x264 Launcher v2". |
1st April 2020, 21:14 | #7489 | Link | |
EDIT: I compiled a x265-3.3+15 build and that version works. I would like to compile a x265-3.3+16 build and it's not possible. I've opened an issue. I use the x265_git as source. Last edited by Patman; 2nd April 2020 at 06:23. |
2nd April 2020, 20:20 | #7490 | Link |
Is there any documentation anywhere on this exciting new feature?
ABR-ladder settings --abr-ladder <file> File containing config settings required for the generation of ABR-ladder With scaling also added as a new feature, I presume the file would be a list of resolutions and bitrates at a minimum. But I don't see the syntax documented anywhere yet. |
2nd April 2020, 20:25 | #7491 | Link |
Derek Prestegard IRL
Interesting! They've had this kind of functionality in UHDKit for awhile (commercially productized x265 with lots of neat pro features) so maybe they're bringing some of the features into the open source world
Analysis re-use is a huge deal when implemented correctly (especially for UHD). I wonder if that's part of this! |
2nd April 2020, 21:31 | #7492 | Link | |
2nd April 2020, 21:33 | #7493 | Link |
Silly me, there is help text in the code:
+.. option:: --abr-ladder <filename> + File containing the encoder configurations to generate ABR ladder. + The format of each line is: + + **<encID:reuse-level:refID> <CLI>** + + where, encID indicates the unique name given to the encode, refID indicates + the name of the encode from which analysis info has to be re-used ( set to 'nil' + if analysis reuse isn't preferred ), and reuse-level indicates the level ( ption:`--analysis-load-reuse-level`) + at which analysis info has to be reused. + + A sample config file is available in `the downloads page <https://bitbucket.org/multicoreware/x265/downloads/Sample_ABR_ladder_config>`_ + + Default: Disabled ( Conventional single encode generation ). Experimental feature. + + **CLI ONLY** |
2nd April 2020, 21:40 | #7494 | Link |
And the sample config file.
Seems pretty straightforward. The "base" stream uses nil for the analysis file, and they chain from the previous one on up the ladder. It presumes a ladder of scaled sources. A lot of cruft comes from using a .yuv file and needing to specify all the color space stuff for each line. Plus calculating PSNR and SSIM and saving those to a log file. I'm not sure how the --scale-factor parameter is derived, but the rule seems to be 0 if the analysis file is the same resolution, otherwise 2. Now that there is a scaling algorithm, an obvious extension would be to allow the scaling to take place within x265 so a single source can be used. Also, it isn't clear at all if these would be encoded in parallel versus serially. I'm guessing serially as it doesn't say otherwise (in contrast to UHDKit, which can already do its own scaling and parallel encoding). [360p:0:nil] --input 640x360_5994fps_8bit_420p.yuv --input-res 640x360 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 145 --ssim --psnr --csv 0.csv --csv-log-level 2 -o 0.hevc --cutree --scale-factor 0 [432p:1:360p] --input 768x432_5994fps_8bit_420p.yuv --input-res 768x432 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 300 --ssim --psnr --csv 1.csv --csv-log-level 2 -o 1.hevc --cutree --scale-factor 0 [540p1:1:432p] --input 960x540_5994fps_8bit_420p.yuv --input-res 960x540 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 600 --ssim --psnr --csv 2.csv --csv-log-level 2 -o 2.hevc --cutree --scale-factor 0 [540p2:10:540p1] --input 960x540_5994fps_8bit_420p.yuv --input-res 960x540 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 900 --ssim --psnr --csv 3.csv --csv-log-level 2 -o 3.hevc --cutree --scale-factor 0 [540p3:10:540p2] --input 960x540_5994fps_8bit_420p.yuv --input-res 960x540 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 1600 --ssim --psnr --csv 4.csv --csv-log-level 2 -o 4.hevc --cutree --scale-factor 0 [720p1:10:360p] --input 1280x720_5994fps_8bit_420p.yuv --input-res 1280x720 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 2400 --ssim --psnr --csv 5.csv --csv-log-level 2 -o 5.hevc --cutree --scale-factor 2 [720p2:10:720p1] --input 1280x720_5994fps_8bit_420p.yuv --input-res 1280x720 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 3400 --ssim --psnr --csv 6.csv --csv-log-level 2 -o 6.hevc --cutree --scale-factor 0 [1080p1:10:540p3] --input 1920x1080_5994fps_8bit_420p.yuv --input-res 1920x1080 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 4500 --ssim --psnr --csv 7.csv --csv-log-level 2 -o 7.hevc --cutree --scale-factor 2 [1080p2:10:1080p1] --input 1920x1080_5994fps_8bit_420p.yuv --input-res 1920x1080 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 5800 --ssim --psnr --csv 8.csv --csv-log-level 2 -o 8.hevc --cutree --scale-factor 0 [1440p:10:720p2] --input 2560x1440_5994fps_8bit_420p.yuv --input-res 2560x1440 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 8100 --ssim --psnr --csv 9.csv --csv-log-level 2 -o 9.hevc --cutree --scale-factor 2 [2160p1:10:1080p2] --input 3840x2160_5994fps_8bit_420p.yuv --input-res 3840x2160 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 11600 --ssim --psnr --csv 10.csv --csv-log-level 2 -o 10.hevc --cutree --scale-factor 2 [2160p2:10:2160p1] --input 3840x2160_5994fps_8bit_420p.yuv --input-res 3840x2160 --fps 59.94 --input-depth 8 --input-csp i420 --min-keyint 60 --keyint 60 --no-open-gop --bitrate 16800 --ssim --psnr --csv 11.csv --csv-log-level 2 -o 11.hevc --cutree --scale-factor 0 |
2nd April 2020, 22:47 | #7495 | Link | |
The older x265 implementation back in 2018 used to be serial (i.e., analysis-save encode had to complete before analysis-load encode starts). This version is closer to parallel -- you only need to finish a number of lower-resolution frames to start encoding at a higher resolution. The older serial implementation gave us about 2.4x speedup on 4K predicted from 1080p vs "standalone" 4K. I don't have results on the new one yet. |
5th April 2020, 10:57 | #7497 | Link |
color primaries
I just re-encoded using this: --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" Now I noticed that the original file and the encoded one have different values in the primaries: Original: Mastering display color primaries : R: x=0.708000 y=0.292000, G: x=0.170000 y=0.797000, B: x=0.131000 y=0.046000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0001 cd/m2, max: 1000.0000 cd/m2 New: Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0001 cd/m2, max: 1000.0000 cd/m2 Does that mean anything or is this bad? -roland |
5th April 2020, 21:06 | #7500 | Link | |
--master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" are correct values for your source
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD Last edited by jlpsvk; 5th April 2020 at 21:11. |
