Old 19th January 2018, 12:48   #3881  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Lots of filters added to clip B eliminate the phantom frames:
A=Colorbars.KillAudio.Trim(0,-10).ShowFrameNumber   # 10 frames
#B=A.Trim(0, -1) ## broken
#B=A.Trim(0, -1).Info ## fixed
#B=A.Trim(0, -1).Invert.Invert ## fixed
#B=A.Trim(0, -1).TurnLeft.TurnRight ## fixed
#B=A.Trim(0, -1).AssumeFrameBased ## broken
#B=A.Trim(0, -1).AssumeFPS(A) ## broken
B=A.Trim(0, -1).ChangeFPS(A) ## fixed
StackHorizontal(A,B)
raffriff42 is offline
Old 19th January 2018, 14:13   #3882  |  Link
StainlessS
StainlessS's Avatar
Originally Posted by davidhorman View Post
That sounds like a fantastic idea. I also propose that davidhorman_trim(100,200) would return frames 100-199 (100 frames)
Sounds great, could give it a monika of DavidHorman_VirtualDub_Compatible_Trim().
I sometimes post sober.
StainlessS is offline
Old 19th January 2018, 19:40   #3883  |  Link
@raffriff42:
So, which of them is the most performant "NOP filter" preserving the specified behaviour? ... J/K
LigH is offline
Old 19th January 2018, 20:05   #3884  |  Link
StainlessS
StainlessS's Avatar
I would think that the raw elegance of current AVS+ trim is the most performant NOP, really need more tests from those willing to partisipate.
EDIT: Above, guess I misinterpreted Ligh's post, 8 or 9 pints of bitter seem to have that effect on me.
Old 19th January 2018, 22:37   #3885  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
It must be ChangeFPS, since it has no need to do anything to the actual video except pass the frame through, just as trim() does. There's just the trivial overhead of determining which frame to pass.
wonkey_monkey is offline
Old 19th January 2018, 22:51   #3886  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
I've heard tell ChangeFPS does some caching; maybe that's the reason it works here -
Originally Posted by Didée
https://forum.doom9.org/showthread.p...20#post1473320
ffvideosource("source.mkv")
changefps(last,last,true) # cache a few frames of input - dont ask, just do. ;-)
Old 20th January 2018, 14:49   #3887  |  Link
tormento
Acid fr0g
tormento's Avatar
Always present in my scripts. Don't ask why, I don't know
@turment on Telegram
tormento is offline
Old 20th January 2018, 16:07   #3888  |  Link
To cache explicitly, you may use RequestLinear (TIVTC.dll); AviSynth MT also provided Preroll (or even any AviSynth v2.6+?). Does AviSynth+ offer anything similar in its kernel?
LigH is offline
Old 22nd January 2018, 01:56   #3889  |  Link
kuchikirukia
On a hunch, try the latest MaskTools. (I've seen artifacts with 3.357 that seem to be gone now)
That's what I am using.
avs+ 2.6.0.5 ?
913,920 byte version from March 7, 2016. Reports itself as 2.6.0.5 in properties.
kuchikirukia is offline
Old 22nd January 2018, 02:22   #3890  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
AviSynth+ version number is currently 2.60, the same as AviSynth. The way to tell AVS+ versions apart is with the Version & VersionString functions.
For example, the current VersionString is:
"AviSynth+ 0.1 (r2580, MT, i386)" (32-bit)
"AviSynth+ 0.1 (r2580, MT, x86_64)" (64-bit)
Old 22nd January 2018, 08:17   #3891  |  Link
Use AVSMeter(64) to discover the version string of your currently installed AviSynth.
LigH is offline
Old 22nd January 2018, 09:13   #3892  |  Link
Or read the 'product name' line under the details tab when you right click -> properties.
ryrynz is offline
Old 22nd January 2018, 09:15   #3893  |  Link
StainlessS
StainlessS's Avatar
This is pretty easy too
Version.avs
Version
Old 22nd January 2018, 09:30   #3894  |  Link
pinterf
Version.avs
Version
2016? Then it's time for a change.
pinterf is offline
Old 22nd January 2018, 11:10   #3895  |  Link
wonkey_monkey
Whose site is this, which comes up as first Google result for AviSynth+?
http://avs-plus.net/
Old 22nd January 2018, 11:33   #3896  |  Link
ChaosKing
The git link on the page links to https://github.com/pylorak/avisynth so I would assume it's ultims site aka the thread creator.
ChaosKing is offline
Old 22nd January 2018, 11:42   #3897  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
This is funny, avs+ creators so bad at making releases the official site is forgotten...
Myrsloik is online now
Old 22nd January 2018, 11:45   #3898  |  Link
Like I said earlier with Ultim basically out of it and with the commits that have been done long since stabilizing things it's about time things got tidied up and merged.
Need a proper version number release.
ryrynz is offline
Old 22nd January 2018, 16:57   #3899  |  Link
wonkey_monkey
I'm confused by the convertbits Wiki page:
bool  truerange = true
        Use the default value unless you know what you are doing.
        (TODO if false, seems to either do nothing or corrupt output)
        Only allowed with Planar color formats.
        If true (default), convert 10-16 bit formats without re-scaling underlying pixel data. For example,
          clip10bit.ConvertBits(16, truerange=false)
        will leave pixel data in the 0..1023 range, but will change the color format from YUVxxxP10 to YUVxxxP16.
It says true will not "re-scale underlying pixel data" but then says false will leave pixel data in the original 10-bit range. Is this a mistake, or ambiguous terminology?
I'd also argue that "truerange" is not a good name for the parameter anyway, as it gives little hint as to what it does, either as false or true.
Old 22nd January 2018, 21:18   #3900  |  Link
poisondeathray
nice catch , it is contradictory
What would be a better "name" ? Maybe "scalerange" ?
poisondeathray is offline
