Old 21st October 2019, 07:17   #4901  |  Link
I already had the minimum and additional 2019 runtimes installed (x86 and x64), did I really need this to install 2015-2019 Redistributable?
ryrynz is offline
Old 21st October 2019, 07:30   #4902  |  Link
StainlessS
StainlessS's Avatar
If your already had all required installed then probably not, Pinterf provides exe both with and without runtimes.
[you would likely have found out pretty quiickly whether you needed runtime updates or not].
I sometimes post sober.
StainlessS is offline
Old 21st October 2019, 08:51   #4903  |  Link
You may need one or another Visual C++ Runtime for one or another plugin, too ...
LigH is offline
Old 21st October 2019, 09:30   #4904  |  Link
Groucho2004
EDIT: Two problems revealed already for avs+ 3.4.0,
Problems apps,
Groucho2004 Universal Avisynth Installer, and
Shekh The Magnificent's VirtualDub2.
EDIT: Breaks Potplayer [Freezes],
script
Version
As I mentioned in the other two threads, install the non-GCC version.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 21st October 2019, 09:46   #4905  |  Link
pinterf
Originally Posted by qyot27 View Post
https://github.com/AviSynth/AviSynthPlus/releases
AviSynth+ 3.4.0 has been released. I debated whether to post a new thread in order to make sure it was visible, but I figured that even if a dedicated release post gets made, it should also be posted here too.
What a day! An Avisynth version from the original master branch, great. I still hope I'm returing here soon, my schedule is too busy since August to allow doing free-time projects.
pinterf is offline
Old 21st October 2019, 09:50   #4906  |  Link
StainlessS
StainlessS's Avatar
So, is this now considered a continuation of the fabled and abandoned v3.0 Avisynth ?
EDIT: Avisynth v3.0 on Wiki:- http://avisynth.nl/index.php/AviSynth_v3
Old 21st October 2019, 10:04   #4907  |  Link
Groucho2004
Sorry Stainless, I deleted my post to which you replied. Anyway, this seems to confirm that it is indeed basically pinterf's r2915:
3.4 is pretty boring, all told. As the big changes from pull request #101 were already committed to MT several months ago, 3.4 basically catches up with pinterf's development branch (r2915 from late August) and has a small number of additional patches to smooth over the packaging process and officially roll over to the new versioning.
Old 21st October 2019, 10:05   #4908  |  Link
real.finder
I think it's not, avs 3.X is not avs+ 3.X
but anyway the goals of avs 3.X is similar to avs+
See My Avisynth Stuff
real.finder is offline
Old 21st October 2019, 10:17   #4909  |  Link
StainlessS
StainlessS's Avatar
It portrays itself like so :-
EDIT: This posted here:- https://forum.doom9.org/showthread.p...79#post1886179
Is still an issue in v3.4,
when Length=1, (for both BlankClips) it dont work, (ConditionalFilter fails)
Failing script
ROW      = True
LIMITLO  =  74.0     # >= is Target
LIMITHI  = 100.0     # <= is Target
INCOLOR  = $008080   # Set where in target range
OUTCOLOR = $FF8080   # Not in target range
SHOW     = false     # Return StackHorizontal, original as Y8, and mask.
Colorbars.Trim(0,-100).convertToY8
MskByRowAveY(Row=ROW,LimitLo=LIMITLO,LimitHi=LIMITHI,InColor=INCOLOR,OutColor=OUTCOLOR,Show=SHOW)
Return Last
Function  MskByRowAveY(clip c, Bool "Row", Float "LimitLo", Float "LimitHi", Int "InColor", Int "OutColor", Bool "Show") {
#   Where AveLuma of pixel Row/Coloumn is between LimitLo<===>LimitHi, then set to Incolor, else OutColor. Colors Specified as YUV, where only Y8 returned.
    c                                           myName="MskByRowAveY: "
    Row=Default(Row,true)                       LimitLo=Default(LimitLo,  0.0)          LimitHi=Default(LimitHi,127.5)
    InColor =Default(InColor ,$000000)          OutColor=Default(OutColor,$FF8080)      Show=Default(Show,False)
    Assert(0.0 <= LimitLo <= LimitHi,myName+String(LimitLo,"0.0 <= LimitLo(%f)") + String(LimitHi,"  <= LimitHi(%f)"))
    Assert(LimitHi <= 255.0,myName+String(LimitHi,"LimitHi(%f) <= 255.0"))
    ConvertToY8.KillAudio                       O=Last
    (Row) ? SeparateRows(O.Height)  : SeparateColumns(O.Width)
    FAIL=false # toggle to fail
    len = (FAIL) ? 1 : Last.Framecount
    InC = Last.BlankClip(Length=Len,Color_YUV= InColor)    OutC= Last.BlankClip(Length=Len,Color_YUV=OutColor)
    Last.ConditionalFilter(InC,OutC,String(LimitLo,"(%f<=AverageLuma<=")+String(LimitHi,"%f)"))
    (Row) ? WeaveRows(O.Height) : WeaveColumns(O.width)
    Return (SHOW) ? StackHorizontal(O,Last) : Last
Old 21st October 2019, 12:37   #4910  |  Link
pinterf
Failing script
ROW      = True
Return Last
Output frame count of ConditionalFilter will be max(InC.FrameCount, OutC.FrameCount). When you set it to 1 (FAIL=true case), ConditionalFilter output will be a single frame result. Which is then fed into WeaveRows, which needs at least O.Height of clip length to work properly.
pinterf is offline
Old 21st October 2019, 16:14   #4911  |  Link
StainlessS
StainlessS's Avatar
Nice theory P
But, what about this one then [no SeparateRows]
FAIL = False  # Force Falure ?
C=0
For(i=0,255) {
    C2=BlankClip(Pixel_Type="Y8",Length=1,Color_YUV=(i*256+$80)*256+$80)
    C=(!c.IsClip) ? C2 : C ++ C2
C    # 256 frames, Y ascending
Len = (FAIL) ? 1 : FrameCount
K=Last.BlankClip(Length=Len,Pixel_Type="Y8",Color_YUV=$008080).Subtitle("[FAIL=" + String(FAIL) + "] Is NOT greater than 100.0",Align=5)
W=Last.BlankClip(Length=Len,Pixel_Type="Y8",Color_YUV=$FF8080).Subtitle("[FAIL=" + String(FAIL) + "] Is greater than 100.0",Align=5)
ConditionalFilter(W,K,"averageLuma >= 100.0 ",Show=true)
C=C.Scriptclip("""Subtitle(String(current_frame,"%.0f] Y=") + String(AverageLuma,"%.2f"))""")
StackHorizontal(C,Last)
#Trim(255,-1)    # Only show last frame where result should be WHITE.
I had posted this earlier in this thread [as EDIT] but forgot, here:- http://forum.doom9.org/showthread.ph...79#post1886179
EDIT: both W and K have to be single frame to fail, I cant re-check as I'm in middle of system restore from image.
EDIT: I would expect it to behave like the other runtime filters, it is commonplace to return a single frame in eg Scriptclip, makes no difference to length of outut
clip, which is guaranteed same as input.
Old 21st October 2019, 18:48   #4912  |  Link
markfilipak
markfilipak's Avatar
Location: Mansfield, Ohio (formerly San Jose, California)
markfilipak,
Avoid r1576, is from several years ago [4 or 5].
Get This one AviSynthPlus_3.4.0_20191020.exe from here:- https://github.com/AviSynth/AviSynthPlus/releases
Now I have the latest installed. Thanks for the link. And I found the example AVS scripts.
I have crawled through what documentation I could find. I apparently missed some [1].
I was hoping avisynth could serve video files, starting with something simple, like this:
return read('d:\path\movie.mkv')
I see how to create a blank clip or color bars, but I can't find anything like the above. A link to info would be fine of course.
[1]
I can't find a link between this:
http://avisynth.nl/index.php/Internal_functions
and this:
http://avisynth.nl/index.php/AviSynth_Syntax
so it appears I'm missing some crucial info.
markfilipak is offline
Old 21st October 2019, 18:55   #4913  |  Link
poisondeathray
[1]
and this:
You need a source filter to load videos. Common ones are ffms2 and lsmash. They are separate .dll's which will autoload if placed into the plugins directory, or you can explicitly load them with LoadPlugin . Certain source filters have various pros/cons in different situations and for different types of video
FFVideoSource("d:\path\movie.mkv")
or
LWLibavVideoSource("d:\path\movie.mkv")
avisynth is a bit different in that there is an "implied last" , so you don't have to return an output node such as in vapoursynth, you can omit it entirely
If you omit it, it really means
return last
poisondeathray is offline
Old 21st October 2019, 19:36   #4914  |  Link
markfilipak
Originally Posted by poisondeathray View Post
You need a source filter to load videos. Common ones are ffms2 and lsmash. They are separate .dll's ...
There are no DLLs there (https://github.com/FFMS/ffms2). A search for 'ffms2.dll' fails.
Old 21st October 2019, 19:45   #4915  |  Link
poisondeathray
For Github, usually there are compiled releases under "releases" (click on "releases") for all types of projects listed on Github
But for ffms2 , those are old . (You actually might want even older if you were dealing with MPEG2 / DVD, but I would avoid it completely and use MPEG2Source, hence the pros/cons warning earlier . There are many "gotchas" and quirks for various source filters)
You can find latest in the development threads . Go to the end of each and work your way backwards . You might want to download the old "official" ones , because they have the documentation. Some of the "new" releases are just the .dll's without source or documentation
https://forum.doom9.org/showthread.php?t=167435
https://forum.doom9.org/showthread.php?t=127037
It's not a great way of organizing things, it's just they way it is. Sometimes you have to search quite a bit for matching or proper .dlls for certain plugins. There is a project similar to vapoursynth repo called avsrepogui from CK too that might be helpful for some people
https://forum.doom9.org/showthread.php?t=176443
Old 21st October 2019, 19:53   #4916  |  Link
ChaosKing
I would say this is currently the safest ffms2 dll with the latest codec support like av1 https://forum.doom9.org/showthread.p...90#post1886890
With safe I mean frame accurate. See table here https://forum.doom9.org/showthread.php?t=176231
Or you can lsmash via the avsrepogui tool :P
ChaosKing is offline
Old 21st October 2019, 23:17   #4917  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Just so I've got this straight, pinterf forked the "official" Avisynth+ to update it, and now the "official" Avisynth+ has incorporated his work into itself?
wonkey_monkey is offline
Old 21st October 2019, 23:24   #4918  |  Link
StainlessS
StainlessS's Avatar
Perhaps I'm old and tired, but I think that the chances of finding out what's actually going on are so absurdly remote that the only thing to do is to say, "Hang the sense of it," and keep yourself busy. I'd much rather be happy than right any day.
EDIT: And you can quote me on that [and I feel that somebody defo will].
Old 21st October 2019, 23:25   #4919  |  Link
wonkey_monkey
And are you?
Old 21st October 2019, 23:33   #4920  |  Link
StainlessS
StainlessS's Avatar
Truth be told, I'm always right, I've never been happy, hang the sense of it, lets get pissed instead.
