Old 28th March 2020, 10:33   #5301  |  Link
Fortunately, DosBox emulates GUS (Gravis Ultrasound) devices nicely.
LigH is offline
Old 29th March 2020, 14:35   #5302  |  Link
Stereodude
Originally Posted by wonkey_monkey View Post
Quick question: is the horizontally shifting chroma bug from <=2.61 fixed in Avisynth+?
http://avisynth.nl/index.php/Known_I...sitioning_Bugs
No, it's not (or at least something is still wrong with the chroma handling)
You can quickly test for it by doing an integer point resample modification to the chroma and back. It should be lossless, but using the built in avisynth+ functions it's not. Using avsresize (z.lib) it is lossless.
Lossless:
z_ConvertFormat(pixel_type="YUV422P10", resample_filter="point", colorspace_op="170m:601:170m:f=>170m:601:170m:f")
z_ConvertFormat(pixel_type="YV12", resample_filter="point", colorspace_op="170m:601:170m:f=>170m:601:170m:f")
not lossless
ConvertToYUV422(matrix="PC.601", chromaresample="point")
ConvertToYUV420(matrix="PC.601", chromaresample="point")
Stereodude is offline
Old 30th March 2020, 06:37   #5303  |  Link
real.finder
can someone add HBD to http://avisynth.nl/index.php/MedianBlur2 and http://avisynth.nl/index.php/AddGrainC ?
they are very basic functions that needed in many scripts
See My Avisynth Stuff
real.finder is offline
Old 30th March 2020, 07:34   #5304  |  Link
DJATOM
DJATOM's Avatar
AddGrain already have vapoursynth version, probably not that difficult to port back.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline
Old 30th March 2020, 08:45   #5305  |  Link
real.finder
so you will do it?
I kinda shy to ask pinterf since he already did many ports and work for avs
if not you then maybe jpsdr or MeteorRain
for MedianBlur2 there are also https://forum.doom9.org/showthread.p...20#post1810220
Old 30th March 2020, 09:08   #5306  |  Link
StvG
AddGrain port of the vs version.
StvG is offline
Old 30th March 2020, 09:39   #5307  |  Link
real.finder
thanks, it work but even in 8 bit it darker (1/255) than the original input or old AddGrain
Old 31st March 2020, 00:13   #5308  |  Link
real.finder
so, anyone will pickup MedianBlur2?
Old 31st March 2020, 07:40   #5309  |  Link
pinterf
I'll check how difficult it is. If project can be done in a day then probably ok.
pinterf is offline
Old 31st March 2020, 14:04   #5310  |  Link
mcjordan
Pinterf, i have a try to compile your last build of AviSynthPlus (VC2019),
but several times I encounter the following messages:
Error C3447 third operand to the conditional operator ?: is of type 'void', but the second operand is neither a throw-expression nor of type 'void'
and also
C2440 'return': cannot convert from 'AVSMapValue' to 'AVSMapValue &'
It is critical? I read some things in the following forum:
https://cboard.cprogramming.com/c-pr...type-void.html
Thank you in advance and sorry for disturbance. I'm not deep familiar with C/C++ programming.
mcjordan is offline
Old 31st March 2020, 14:16   #5311  |  Link
pinterf
Check it again please, work in progress.
pinterf is offline
Old 31st March 2020, 14:19   #5312  |  Link
mcjordan
Thank you. I'll try again later.
mcjordan is offline
Old 31st March 2020, 14:51   #5313  |  Link
mcjordan
Also in strings.cpp ->
Warning C4996 'std::codecvt_utf8_utf16<wchar_t,1114111,(std::codecvt_mode)0>': warning STL4017: std::wbuffer_convert, std::wstring_convert, and the <codecvt> header (containing std::codecvt_mode, std::codecvt_utf8, std::codecvt_utf16, and std::codecvt_utf8_utf16) are deprecated in C++17. (The std::codecvt class template is NOT deprecated.) The C++ Standard doesn't provide equivalent non-deprecated functionality; consider using MultiByteToWideChar() and WideCharToMultiByte() from <Windows.h> instead. You can define _SILENCE_CXX17_CODECVT_HEADER_DEPRECATION_WARNING or _SILENCE_ALL_CXX17_DEPRECATION_WARNINGS to acknowledge that you have received this warning.
and
error C2039: 'unique_ptr': is not a member of 'std'
message : see declaration of 'std'
syntax error: missing ';' before '<'
error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
Sorry for double post.
mcjordan is offline
Old 31st March 2020, 15:55   #5314  |  Link
pinterf
Put an
#include <memory>
in strings.h
rare case when gcc and clang was o.k., but msvc not.
pinterf is offline
Old 31st March 2020, 17:56   #5315  |  Link
feisty2
I'm Siri
feisty2's Avatar
Put an
#include <memory>
in strings.h
you could probably write a very high level script-like API wrapper, like I recently did, if you wanna make the coding process painless for people that wish to write their own plugins but with little knowledge of C or C++
feisty2 is offline
Old 31st March 2020, 18:31   #5316  |  Link
mcjordan
#include <memory>
in strings.h
works like a charm.
Thank you, Pinterf.
mcjordan is offline
Old 1st April 2020, 07:33   #5317  |  Link
pinterf
I enjoy your coding experiments despite the fact that sometimes I feel myself dummy and too old for those abstractions that are allowed by modern C++ syntax. I have the similar feelings when I'm looking into secrit-twc's repos who solves problems in two elegant lines which I'm doing with a half page of code. Probably my son will do it better than me (he's studying informatics), they had already C++ basics, C++11, 14 and 17 are covered by second half-year course, so he cannot help me right now in interpreting those magics you are doing.
pinterf is offline
Old 1st April 2020, 10:06   #5318  |  Link
MeteorRain
結城有紀
I'd really hope someone's gonna write a wrapper like what I did to make a plugin dual interface, but in a more elegant and clean way.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline
Old 2nd April 2020, 09:48   #5319  |  Link
MeteorRain
結城有紀
I actually took some time to read F2's code. I'm impressed by how elegant it's done. In my dual interface framework I put wrapper as template parameter, while he put the filter engine as template parameter. Very interesting design.
Lots of features are not supported yet -- lots of C++20 things. So no MSVC at this point == no chance for AviSynth+ for Windows.
Projects
Old 2nd April 2020, 10:37   #5320  |  Link
feisty2
I'm Siri
feisty2's Avatar
I actually successfully compiled GCC 10 (trunk ver) from the scratch in Cygwin for windows a few days ago. I'll admit that it was not a pleasant experience...
feisty2 is offline
