Old 14th March 2020, 13:24   #961  |  Link
shekh
2020 matrix is a known issue, I'll add it when I can.
VirtualDub2
Old 17th March 2020, 08:41   #962  |  Link
hintlou
Can the VirtualDub2 filters be added to avs scripts which aren't be processed in VirtualDub2?
hintlou is offline   Reply With Quote
Old 17th March 2020, 11:38   #963  |  Link
StainlessS
StainlessS's Avatar
LoadVirtualDubPlugin:- http://avisynth.nl/index.php/Plugins
EDIT: For usage, Advanced Search for "LoadVirtualDubPlugin" , select 'posts', not 'threads', and in Avisynth 'Usage forum'.
I sometimes post sober.
Old 17th March 2020, 14:54   #964  |  Link
But ... for many VirtualDub(2) plugins, there are equal (if not even superior) AviSynth plugins available, often for VapourSynth as well. Loading VirtualDub plugins in AviSynth is only recommendable for those without a match.
Old 17th March 2020, 16:41   #965  |  Link
hintlou
Thanks for StainlessS and LigH. I will study it carefully!
Old 18th March 2020, 04:10   #966  |  Link
hintlou
I want to load the VirtualDub2 Plugin "Deinterlace-Blend fields-Keep top fields,interpolate/discard bottom fields" to my avs script,
but I can't find its vdf file and don't know how to set the filtername for its plugin function.
Would anybody give me a hand,please?
Old 18th March 2020, 09:08   #967  |  Link
I believe such basic functions are not a plugin, but in the application core.
Apart from that, discarding and interpolating one field can be achieved easily with AviSynth core functions (SeparateFields, SelectOdd/Even, *Resize).
And it would be one of the worst methods to deinterlace. Why waste quality intentionally (except for academic purposes, to show how bad this result is)?
Recommendable deinterlacers which don't discard a field but use adjacent fields to reconstruct content are, from fast to precious: Yadif(mod), TDeint, QTGMC (that one has a complex installation but will be worth the efforts).
Old 18th March 2020, 13:57   #968  |  Link
hintlou
Thanks for your advice.
I know it's not a modern deinterlacing method.
But the Blend fields plugin of VirtualDub2 can offer me the effect I need in some dvdripping cases.
So can the plugin be loaded in avs scripts?
I really really need it be loaded in my avs scripts instead of being loaded in VirtualDub2 only.
I want to separate the different parts of pictures in video for differently deinterlaced.
Old 19th March 2020, 08:13   #969  |  Link
For the "deinterlace" filter, the responsible "Module" is "(internal)", so it is not a plugin but code in the EXE.
If it is not a plugin, it cannot be loaded. But it can be executed equivalently with AviSynth core functions.
Old 19th March 2020, 10:14   #970  |  Link
hintlou
OK,Thanks....
How can I get the same/similar effect from AviSynth core functions (SeparateFields, SelectOdd/Even, *Resize) ?
Is there a documentation explaining about it?
Old 19th March 2020, 10:46   #971  |  Link
videoh
Useful n00b
Older deinterlacers like FieldDeinterlace() and TDeint() have blend modes. There may be others, such as SmoothDeinterlace().
Old 21st March 2020, 16:35   #972  |  Link
hintlou
Thanks.I tried them:
"FieldDeinterlace(blend=true,full=true)" :
the deinterlacing quality is bad...
"TDeint(mode=2)" this is a blend mode:
the deinterlacing quality is ok,but the blending effect is different from the Blend fields plugin of VirtualDub2.
I don't have 32bit softwares so "SmoothDeinterlace()" isn't suitable.
Old 21st March 2020, 17:02   #973  |  Link
Andouille
Registered sausage
Andouille's Avatar
Try this in Avisynth :
Blur(0,1)
Andouille is offline   Reply With Quote
Old 21st March 2020, 18:15   #974  |  Link
videoh
Useful n00b
What is bad about it? You specified full blending so the progressive parts will not be spared.
Old 21st March 2020, 18:15   #975  |  Link
videoh
Useful n00b
Blur(0,1)
Yup, sounds about right for him.
Old 25th March 2020, 03:54   #976  |  Link
Stereodude
Is it not possible to use CineForm in a .mov using fast recompress? I have AVIsynth spitting out V210 and CineForm is set to 10-bit 4:2:2 and says it will use V210 with no conversion and I get a Video format negotiation failure when using fast recompress. It tells me to use normal recompress or full processing mode.
Old 25th March 2020, 04:49   #977  |  Link
poisondeathray
The short version - nothing funky is going on with full recompression. Make sure you set it up as 10bit in the cineform configuration and YUV 422 10bit. You're actually sending p210 (planar 10bit 4:2:2) with avs script (check with vdub2's file=>file information) and it'a a conversion to v210. It's a lossless re-arrangement of pixel format required for cineform which does not support p210
If you use vapoursynth, there is an enable_v210 switch that sends v210 instead of p210, and you can use fast recompress
Old 25th March 2020, 09:30   #978  |  Link
StainlessS
StainlessS's Avatar
No idea if this helps:- http://avisynth.nl/index.php/Interna...PT_Enable_V210
OPT_Enable_V210
global OPT_Enable_V210 = true ## default false AVS+
For 10bit YUV422, Frameserve interleaved V210 instead of planar P210. (VfW)
§ VfW here means Video For Windows clients such as VirtualDub are affected, but not other clients such as ffmpeg.
Old 25th March 2020, 15:09   #979  |  Link
Stereodude
I used the v210 enable that StainlessS pointed out (after your post) prior to my post last night and it did not work. However, after updating to the lastest VD2 it works fine. I guess there was a bug that has since been fixed and I didn't realize how outdated my version of VD2 was.
Old 25th March 2020, 16:04   #980  |  Link
StainlessS
StainlessS's Avatar
Not sure, think not a bug, was just not supported back then, Shekh & Pinterf got together and arranged for joint support.
