Old 15th April 2015, 22:22   #21  |  Link
luquinhas0021
The image enthusyast
I guess Spline 100 (5 taps) is better than nnedi3_rpow2, because is more sharper and faster than nnedi3.
luquinhas0021 is offline   Reply With Quote
Old 15th April 2015, 22:32   #22  |  Link
Groucho2004
You can't have your cake and eat it too:
Sharper algorithms -> more artefacts
Ultimately it's your decision what you can live with.
Groucho's Avisynth Stuff
Old 15th April 2015, 22:44   #23  |  Link
luquinhas0021
It's not like this! Algorithms that use Edge detection doesn't have artifacts, sometimes, and are sharpers.
Old 16th April 2015, 02:57   #24  |  Link
colours
colours's Avatar
That's only true on the assumption that the edge detection is perfect.
Say no to AviSynth 2.5.8 and DirectShowSource!
colours is offline   Reply With Quote
Old 17th April 2015, 16:01   #25  |  Link
luquinhas0021
Explain
Colours, explain me what oy wannted say when you said perfect Edge Detection. Perfect in what sense: all edges detection or none artifact detection?
Old 18th April 2015, 05:04   #26  |  Link
colours
colours's Avatar
Perfect in the sense that it detects all the edges and only the edges.
This is obviously not a well-posed problem because (in the context of photography) the projection from three dimensions to two is lossy, not to mention that things sometimes don't even have hard, defined edges. Also, Moiré patterns tend to mess with edge detectors.
It's simply not possible for an upscaling algorithm to be free of artifacts in every case. (Unless the input is bandlimited and sampling theorem etc.)
Not that this is all too relevant to the thread; if I'm not mistaken (though I very well might be), using a neural network approach to upscaling is more like solving a maximum likelihood problem than doing explicitly edge-directed interpolation. It's probably not entirely accurate to call nnedi3 an "EDI" type of algorithm, for example. The edge-directedness is an emergent property, not something inherent to how it works.
neurondoubler, nnedi3, upscaling
