Old 5th July 2007, 05:24   #21  |  Link
Jerry_Sm@rt
Would you please add faster first pass surport in custom profiles?
Jerry_Sm@rt is offline   Reply With Quote
Old 5th July 2007, 06:46   #22  |  Link
Yes I will add faster first pass as well
Old 5th July 2007, 18:34   #23  |  Link
asdfsauce
VEIG Master
Excellent program Atak.
Just a couple questions; Will the current mp4 muxer do ipod video? And also, is there any chance you are planning on adding some kind of batch encode option to the program in the near future?
asdfsauce is offline   Reply With Quote
Old 6th July 2007, 00:17   #24  |  Link
Hyper_Thread
Hyper_Thread's Avatar
iPod videos needs a different encoding profile, MP4 muxer is the same for all devices.
RipBot264 is based on batch encode, look at the main window.
@Atak_Snajpera
i found "MT.dll" accidentally copied to my avisynth' plugins folder, so sorry for my displaced question about "SetMTMode".
Hyper_Thread is offline   Reply With Quote
Old 6th July 2007, 01:44   #25  |  Link
asdfsauce
VEIG Master
I meant like, applying settings to a bunch of files at once instead of doing them one by one and then adding them to the queue. And IIRC from the megui wiki, you need a special mp4box build for ipod video. Not such a big deal anymore since I noticed theres a tools directory where you can replace mp4box with the build of your choosing.
Old 6th July 2007, 02:33   #26  |  Link
I think I will be able to implement your request after v1.1.0. At the moment I don't have time for that. Custom profiles are more important. Nevertheless your suggestion is very good because I do many encodes for PSP mainly TV-Shows like Conan o'Brein and I know how annoying it can be when you do the same steps maaaaany times.
Old 6th July 2007, 23:01   #27  |  Link
raven369
Will you be implementing/supporting the .pmp (avc) format for the PSP on Ripbot264?
raven369 is offline   Reply With Quote
Old 6th July 2007, 23:19   #28  |  Link
Exotic pmp format will never be supported. Since Sony unlocked full resoluton I see no reason to not use widely recognized mp4 format.
Old 10th July 2007, 01:36   #29  |  Link
Very important bug has been fixed in v1.1.1!!! Description as always in my first post.
Old 10th July 2007, 04:54   #30  |  Link
asdfsauce
VEIG Master
Keep up the good work Atak, these are some nice changes. Only version 1.1.1 and it's already my favorite video encoding GUI.
Only suggestion I would make with regard to the x264 profiles would be to add an option to view/edit the command line arguements.
Oh and, if it's not too much trouble, a way to add your own resolution presets in the AVS editor.
Old 12th July 2007, 13:01   #31  |  Link
Barough
Barough's Avatar
This looks like a nice and easy GUI. I'll have a look @ it. Thnx
Old 28th July 2007, 12:36   #32  |  Link
Lemonadez
How do we access "Codec Settings"
Can you also add a 32kbps sounds?
Lemonadez is offline   Reply With Quote
Old 28th July 2007, 21:44   #33  |  Link
No because 32kbps is not enough to provide good quality in stereo.
Old 29th July 2007, 04:53   #34  |  Link
B. W.
Any chance of adding the 5.5G iPod profile?
B. W. is offline   Reply With Quote
Old 30th July 2007, 00:17   #35  |  Link
"5.5G iPod profile" is more restricted than ordinary profile. In 5.5 you cannot use deblocking and also MacroBlocks cannot be analyzed. And what do you get instead? Resolution higher than iPod's display (640 on 320= senseless)
Old 30th July 2007, 00:30   #36  |  Link
B. W.
But the same file can play on the iPod, within QuickTime, and people who own Apple TVs. Not only that, but you can take advantage of the iPhone's higher resolution.
Old 30th July 2007, 12:52   #37  |  Link
But quality will be still terrible without deblocking (annoying blocks will kill your eyes. Even 1.5Mbps (limit for iPOD) is not enough to achieve reasonable quality at 640x480 without advanced settings like Deblocking,CABAC,Trellis,many r-frames,b-frames and so on. iPOD is not PSP where you can activate almost all settings and enjoy high quality movies on high resolution display at 512kbps.
...but you can take advantage of the iPhone's higher resolution.
Quality will be alot better if you use iPhone's native resolution with regular profile.
Old 30th July 2007, 21:12   #38  |  Link
weaver4
But it still will not be able to play on Apple TV or the iPod.
I agree the Apple TV profile is bad, but it will play on the Apple TV and no one if forcing them to use that profile.
weaver4 is offline   Reply With Quote
Old 31st July 2007, 00:56   #39  |  Link
Disable deblocking and remove P8x8 and B8x8 ,set AVC Level to 3.0. Probably you will need to download modified Nicmp4box.
Old 5th August 2007, 18:28   #40  |  Link
New version (1.2.0) is available for download
