7th January 2010, 03:17 | #6541 | Link | |
So I decided to upgrade to the newer version and reinstall all the needed software and when I try to preview the subs I get this new error. any ideas? Last edited by gr1mmj0w; 7th January 2010 at 03:28. |
7th January 2010, 06:13 | #6544 | Link |
I got the same error as MKVCrazy after installing v1.15.0. I have the video track of Collateral Damage in a .ts. I'm not familiar with any program that can cut a 50 MB sample from it. Does anyone happen to know of any programs or can I just send you the MediaInfo?
7th January 2010, 06:34 | #6545 | Link | |
Nope, it is still there. I verified the location. edit: UPDATE: seems if I do not use the bluray ripped subtitles, it works when trying to embed the subtitles. Last edited by gr1mmj0w; 7th January 2010 at 06:43. |
7th January 2010, 13:47 | #6546 | Link |
@wolfbane5
dgsplit and www.mediafire.com
7th January 2010, 19:08 | #6547 | Link | |
If yes, try to modifiy the propertries compatibility of avs2avi.exe to compatibility of 'Windows XP Service Pack 3'. Apply, and retry. HEre my post intial trouble research: http://forum.doom9.org/showthread.ph...ns#post1334203 Here my solution: http://forum.doom9.org/showpost.php?...postcount=6508 Try dat.. hope you resolve your trouble. Good luck, 8ternity
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
7th January 2010, 19:15 | #6548 | Link |
I have windows 7 x64 and I have never seen avs2avi crashing! Since I remember you've always had some weird problems
7th January 2010, 23:37 | #6549 | Link | |
Just an example of ffdshow rev3175 i'm having troubles and now with rev3176 everything is fine including DTS audio tracks but i need to convert it to AC3 640 because the audio is out off sync when a 25fps converted into 23.976 and COPY AUDIO is selected. It's why i use right Windows 7 x86 version with a fresh installation. i want to eliminate trouble. I have update everything (direct-X to the latest, graphic card driver, ffdshow version etc.).
7th January 2010, 23:51 | #6550 | Link | |
Edit: Nvm, I found DGSplit 1.1 and I had 1.0. Last edited by wolfbane5; 7th January 2010 at 23:56. |
7th January 2010, 23:55 | #6552 | Link |
You need to edit the .ini file.
Edit: Atak_Snajpera, here's the 50MB sample: http://www.mediafire.com/?miow11nndmk Last edited by wolfbane5; 8th January 2010 at 00:09. |
8th January 2010, 00:34 | #6553 | Link | |
8th January 2010, 01:07 | #6554 | Link |
@wolfbane5
it works on my pc without any problems! 1) if you have XP make sure you have Windows Media Player 11 installed! 2) Do not use latest haali media splitter because it does not see VC-1 streams inside .m2ts and .ts!!! Install previous version http://www.mediafire.com/file/nmlqv3...tter110109.exe
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th January 2010 at 01:13. |
8th January 2010, 05:28 | #6556 | Link | |
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th January 2010 at 05:31. |
8th January 2010, 06:26 | #6557 | Link | |
2) I bet that its Haali. If I'm not mistaken I have the latest version. I will revert back and hopefully that'll fix it. I guess it not recognizing VC-1 streams in .m2ts and .ts is a bug? |
8th January 2010, 10:35 | #6559 | Link | |
Silent Reader
Maybe it's only a nonexistent sanity-checking: Ripbot tries to load a not available profile and hangs till it gets that profile (never). I don't blame Atak for that. It was my fault to change ini and then delete profile. Atak can't imagine all the stupidity of users and try to prevent. |
8th January 2010, 11:04 | #6560 | Link |
Hi Atak, loving Ripbot, it does everything I ask of it but there's one small problem I hope you can help me with. I use an RDP connection from Windows XP Pro to my home PC which is Win 7 Pro to set off encodes while I am at work. The options I choose are crop (automatically), resize (SD-PAL), deinterlace using TFF -> 25fps, and denoise using the anime option (old Transformers DVDs). However when I click the ok button to finish a message pops up saying 'Unexpected error occurred' then in the box it says the following line by line:
File: Line: 216 Error Code: D3DERR_INVALIDCALL(0x8876086c) Calling: Creating Device Do you want to debug the application? I realise that this is not what most people do and the answer will probably be don't use RDP and only run RipBot locally but just wanted to let you know. Simon |
