Old 24th May 2010, 19:54   #8301  |  Link
JohnnyB.Good
I've been getting a lot of these lately, not just with this movie but it already happened with Couples Retreat, Red Cliff, etc. Seems to be the same error where if fails to re-encode extras, trailers or menu items. I've gotten passed this problem by replacing those files with clips from other movies so it's definitely an issue with certain files that BR doesn't like. Vid_141 happens to be the same clip that failed in Couples Retreat, its a black screen 5 second video that says "Universal Studios, all rights reserved" at the bottom. I wonder if just deleting those will cause a problem with "Full Back-up" Is there a way to blank it instead?
PS. When I right-click Vid_141 and select "Preview this Item" I get an error that says: "Resize: Source image too small for this resize method (Q:\MPC_View.AVS, Line 3)". I wonder if that has anything to do with the re-encoding problem, Vid_151 re-encoded fine and I was able to preview it... hmm.
[14:40:49] BD Rebuilder v0.33.09 (beta)
- Source: ING_BASTERDS
- Input BD size: 44.51 GB
- Approximate total content: [04:04:27.419]
- Target BD size: 23.78 GB
- Windows Version: 6.0 [6002]
[14:40:49] PHASE ONE, Encoding
- [14:40:49] Extracting A/V streams [VID_00151]
- [14:40:50] Reencoding: VID_00151 (1 of 18)
- [14:40:50] Collecting video information
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 151 frames
- [14:40:50] Reencoding: VID_00151, Pass 1 of 1
- [14:40:53] Video Encode complete
- [14:40:53] Reencoding audio tracks (if req'd)
- [14:40:54] Multiplexing M2TS
- [14:40:54] Extracting A/V streams [VID_00141]
- [14:40:55] Reencoding: VID_00141 (2 of 18)
- [14:40:55] Collecting video information
- Rate/Length: 23.976fps, 121 frames
- [14:40:55] Reencoding: VID_00141, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.33.09 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
[14:41:28] - Failed video encode, aborted
JohnnyB.Good is offline   Reply With Quote
Old 24th May 2010, 21:04   #8302  |  Link
Elvis Gratton
My Best Friend's Girl
Any1 have success with (My Best Friend's Girl) title02 101 min. version
UPC Code: 031398104216
No problem with Clown_BD(movie-only) note: produced french AC3 track size is (472 833 ko) (& by BD Rebuilder = 472 870 ko)
No problem with DVDFab(movie-only) but stay a multi-m2ts
Same problem with AVCHDCoder(movie-only) out of sync
Same problem with MakeMKV(movie-only) out of sync
prob. #1 less than 20GB & BD rebuilder re-encode anyway !!! "not keeping video"
prob. #2 audio on french track out of sync late in the movie !!!
(just for testing audio prob.)
When i try to demux this title with tsmuxer i get error's message style (AC3 stream (track 2): overlapped frame detected at position 00:00:22,047. Remove frame.) & many other place "if may help"
update: tested demux ac3 5.1 french with eac3to used by Clown_BD & overwrite ac3 file in working dir of BD Rebuilder before remux & all is ok (SYNC perfectly).
I joint txmuxer log & eac3to log
In tsmuxer log we can see (REMOVE FRAME) may be this is the answer ?
BTW BD Rebuilder finish process normally with v3304 v3305
v3309 & inspect is OK too
all my setup is OK after duplicate 73 BD,s with no prob.
any idea ?
THANKS jdobbs for your excellent pmg.
p.s. sorry for my very very very bad English
Elvis Gratton is offline   Reply With Quote
Old 25th May 2010, 00:03   #8303  |  Link
Audiophile1178
JohnnyB.Good, I've never had a problems with BDRebuilder yet except for out of sync audio on deleted scenes from the air I breathe. I did couples retreat full backup to BD25 without any problems and I always watch my backup (I have an oppo BDP-83) before I delete it off the computer to make sure that it's ok since this is beta software. I've done ~50 full backups and have yet to have a problem. The only time that I have a problem is from a bad rip. I just did Daybreakers and couldn't wait to watch it. Well 3 mins into the movie I get a lot of static and breakups in the audio and then the audio goes waaayyy out of sync. I played back my rip and it did the same thing. I had a bad rip and have to do the process all over again. I'm a little mad because it took 13 hours to encode plus I wasted a disc but it wasn't BDRebuilders fault.
Long story short, you have a bad rip!
What I don't get is that I've never had a bad rip from a DVD?!?!? Then again I use an old Plextor PX-716sa for my dvd rips and burns so that might have something to do with it.
Audiophile1178 is offline   Reply With Quote
Old 25th May 2010, 00:30   #8304  |  Link
Elvis Gratton
Sorry but
Ripped 4 time
2 w DVDFab & 2 w AnyDVD
& the result is the same.
note: The copy made with DVDFab & Clown_BD work very well.
Old 25th May 2010, 01:28   #8305  |  Link
Audiophile1178
Then the only thing that I can say is that may you have a bad disc. I recently had a very bad problem with Big Trouble In little China. It took me 3 discs before I got one that worked. All I'm saying is that I backed up couples retreats without any problem. That was a few BDRebuilder versions ago as well.
So far I've only had two problems with discs. Big Trouble In Little China and Daybreakers.
Old 25th May 2010, 01:53   #8306  |  Link
Audiophile1178
Jdobbs, I have an error detecting request.
I just fully backed up Daybreakers (took me 13 hours) without any problems but there was indeed a problem. Daybreakers didn't rip correctly onto my hard drive and has several problems. I'm messing around with clown_BD which found the problems right away during demuxing. Could you incorporate some sort of error detection that would prompt the user that it found an error and ask if you would like to continue? I think adding something like that in the setup to enable/disable it would be ideal for people that would like to use it for a reference. To me there's nothing worse than wasting all the encoding time and the blank discs to then sit down to watch the movie and find out that there's an error in the ripping and that you have to do it all over again. If we could find out that there's a problem from the start it would save us a lot of time and money.
Here's my clown_BD log as a reference.
Sorry I didn't know how to properly insert the log file like everyone else.
Old 25th May 2010, 02:02   #8307  |  Link
@Elvis Gratton,
If you want me to try and help you -- it would be more helpful if you didn't post logs that are unrelated to BD-RB, as they really don't give me the information I need. EAC3TO isn't even involved in a BD-RB encode. How about posting the BD-RB log and INF instead? It also doesn't help to say other programs work either (like Clown BD or MakeMKV)... they are completely unrelated and don't do anything even remotely similar to BD-RB.
The "source image too small" means that BD-RB is being fed garbage -- and that's why it is failing. My guess would be (without any info to help me) that you might have a "Codec Pack" or some other package that is attempting to decode instead of FFDSHOW -- and it isn't doing a very good job.
Old 25th May 2010, 09:01   #8308  |  Link
Reveal
Wrong size - BUDDENBROOKS
The iso is 14.2 GB instead of 7.72 GB. Region B
[16:48:58] BD Rebuilder v0.33.09 (beta)
- Source: BUDDENBROOKS
- Input BD size: 26,00 GB
- Approximate total content: [02:25:16.680]
- Target BD size: 7,72 GB
- Windows Version: 6.1 [7600]
- MOVIE-ONLY mode enabled
- RESIZE 1080p to 720p enabled
[16:49:03] PHASE ONE, Encoding
- [16:49:03] Extracting A/V streams [VID_00005]
- [17:00:15] Reencoding: VID_00005 (1 of 1)
- [17:00:15] Collecting video information
- Rate/Length: 25,000fps, 217*917 frames
- Convert: 1280x720, 50,000fps, 435*834 frames
- Bitrate: 6*308 Kbs
- [17:00:15] Reencoding: VID_00005, Pass 1 of 2
- [18:52:34] Reencoding: VID_00005, Pass 2 of 2
- [23:42:56] Video Encode complete
- [23:42:56] Reencoding audio tracks (if req'd)
- [23:47:43] Multiplexing M2TS
[23:54:41]PHASE ONE complete
[23:54:41]PHASE TWO - Rebuild Started
- [23:54:41] Rebuilding AVCHD file Structure
[00:04:01] - Encode and Rebuild complete
[00:04:02] Writing BD structure to ISO file
- ImgBurn completed successfully
[00:15:15]JOB: BUDDENBROOKS finished.
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.33.0.9, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[Options]
MODE=1
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=7910
AUTO_BURN=2
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=1
DEINTERLACE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
[Paths]
SOURCE_PATH=D:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxx\BUDDENBROOKS\
WORKING_PATH=C:\WINDOWS\TEMP\
Reveal is offline   Reply With Quote
Old 25th May 2010, 09:36   #8309  |  Link
Elvis Gratton
@Elvis Gratton,
- Windows Version: 5.1 [2600]
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
[21:27:40] BD Rebuilder v0.33.09 (beta)
  - Source:  MYBESTFRIENDSGIRL
  - Input BD size: 24,06 GB
  - Approximate total content: [01:40:52.254]
  - Target BD size: 22,66 GB
  - Auto Quality: Good (Very Fast), One Pass
[21:27:40] PHASE ONE, Encoding
 - [21:27:40] Extracting A/V streams [VID_00001]
 - [21:42:23] Reencoding: VID_00001 (1 of 25)
 - [21:42:23] Collecting video information
   - Rate/Length: 23,976fps, 528 frames
   - Bitrate: 26*714 Kbs
 - [21:42:23] Reencoding: VID_00001, Pass 1 of 1
 - [21:42:40] Video Encode complete
 - [21:42:40] Reencoding audio tracks (if req'd)
 - [21:42:40] Multiplexing M2TS
 - [21:42:41] Extracting A/V streams [VID_00026]
 - [21:43:13] Reencoding: VID_00026 (2 of 25)
 - [21:43:13] Collecting video information
   - Rate/Length: 23,976fps, 5*982 frames
   - Bitrate: 24*200 Kbs
 - [21:43:13] Reencoding: VID_00026, Pass 1 of 1
 - [21:46:13] Video Encode complete
 - [21:46:13] Multiplexing M2TS
 - [21:46:18] Extracting A/V streams [VID_00003]
 - [21:47:20] Reencoding: VID_00003 (3 of 25)
 - [21:47:20] Collecting video information
   - Rate/Length: 23,976fps, 9*295 frames
   - Bitrate: 30*000 Kbs
 - [21:47:20] Reencoding: VID_00003, Pass 1 of 1
 - [21:52:42] Video Encode complete
 - [21:52:43] Multiplexing M2TS
 - [21:52:59] Extracting A/V streams [VID_00027]
 - [21:53:08] Reencoding: VID_00027 (4 of 25)
 - [21:53:08] Collecting video information
   - Rate/Length: 23,976fps, 1*441 frames
   - Bitrate: 28*732 Kbs
 - [21:53:08] Reencoding: VID_00027, Pass 1 of 1
 - [21:53:57] Video Encode complete
 - [21:53:57] Multiplexing M2TS
 - [21:53:59] Extracting A/V streams [VID_00028]
 - [21:54:19] Reencoding: VID_00028 (5 of 25)
 - [21:54:19] Collecting video information
   - Rate/Length: 23,976fps, 2*407 frames
 - [21:54:19] Reencoding: VID_00028, Pass 1 of 1
 - [21:55:59] Video Encode complete
 - [21:55:59] Multiplexing M2TS
 - [21:56:02] Extracting A/V streams [VID_00006]
 - [21:56:23] Reencoding: VID_00006 (6 of 25)
 - [21:56:23] Collecting video information
   - Rate/Length: 23,976fps, 3*001 frames
 - [21:56:23] Reencoding: VID_00006, Pass 1 of 1
 - [21:58:11] Video Encode complete
 - [21:58:11] Multiplexing M2TS
 - [21:58:14] Extracting A/V streams [VID_00029]
 - [21:58:25] Reencoding: VID_00029 (7 of 25)
 - [21:58:25] Collecting video information
   - Rate/Length: 23,976fps, 2*113 frames
   - Bitrate: 22*481 Kbs
 - [21:58:25] Reencoding: VID_00029, Pass 1 of 1
 - [21:59:27] Video Encode complete
 - [21:59:27] Multiplexing M2TS
 - [21:59:29] Extracting A/V streams [VID_00008]
 - [22:00:03] Reencoding: VID_00008 (8 of 25)
 - [22:00:03] Collecting video information
   - Rate/Length: 23,976fps, 4*762 frames
 - [22:00:03] Reencoding: VID_00008, Pass 1 of 1
 - [22:02:55] Video Encode complete
 - [22:02:55] Multiplexing M2TS
 - [22:03:00] Extracting A/V streams [VID_00030]
 - [22:03:02] Reencoding: VID_00030 (9 of 25)
 - [22:03:02] Collecting video information
   - Rate/Length: 23,976fps, 219 frames
 - [22:03:02] Reencoding: VID_00030, Pass 1 of 1
 - [22:03:11] Video Encode complete
 - [22:03:11] Multiplexing M2TS
 - [22:03:12] Extracting A/V streams [VID_00010]
 - [22:04:31] Reencoding: VID_00010 (10 of 25)
 - [22:04:31] Collecting video information
   - Rate/Length: 23,976fps, 11*070 frames
 - [22:04:31] Reencoding: VID_00010, Pass 1 of 1
 - [22:11:06] Video Encode complete
 - [22:11:06] Multiplexing M2TS
 - [22:11:26] Extracting A/V streams [VID_00031]
 - [22:11:35] Reencoding: VID_00031 (11 of 25)
 - [22:11:35] Collecting video information
   - Rate/Length: 23,976fps, 2*004 frames
   - Bitrate: 20*790 Kbs
 - [22:11:35] Reencoding: VID_00031, Pass 1 of 1
 - [22:12:32] Video Encode complete
 - [22:12:32] Multiplexing M2TS
 - [22:12:34] Extracting A/V streams [VID_00012]
 - [22:13:49] Reencoding: VID_00012 (12 of 25)
 - [22:13:49] Collecting video information
   - Rate/Length: 23,976fps, 10*897 frames
 - [22:13:49] Reencoding: VID_00012, Pass 1 of 1
 - [22:20:25] Video Encode complete
 - [22:20:25] Multiplexing M2TS
 - [22:21:14] Extracting A/V streams [VID_00032]
 - [22:21:18] Reencoding: VID_00032 (13 of 25)
 - [22:21:18] Collecting video information
   - Rate/Length: 23,976fps, 718 frames
   - Bitrate: 22*964 Kbs
 - [22:21:18] Reencoding: VID_00032, Pass 1 of 1
 - [22:21:41] Video Encode complete
 - [22:21:41] Multiplexing M2TS
 - [22:21:42] Extracting A/V streams [VID_00014]
 - [22:22:42] Reencoding: VID_00014 (14 of 25)
 - [22:22:42] Collecting video information
   - Rate/Length: 23,976fps, 8*909 frames
 - [22:22:42] Reencoding: VID_00014, Pass 1 of 1
 - [22:28:00] Video Encode complete
 - [22:28:00] Multiplexing M2TS
 - [22:28:14] Extracting A/V streams [VID_00033]
 - [22:28:33] Reencoding: VID_00033 (15 of 25)
 - [22:28:33] Collecting video information
   - Rate/Length: 23,976fps, 2*817 frames
 - [22:28:33] Reencoding: VID_00033, Pass 1 of 1
 - [22:30:13] Video Encode complete
 - [22:30:13] Multiplexing M2TS
 - [22:30:17] Extracting A/V streams [VID_00016]
 - [22:31:19] Reencoding: VID_00016 (16 of 25)
 - [22:31:19] Collecting video information
   - Rate/Length: 23,976fps, 9*359 frames
   - Bitrate: 29*993 Kbs
 - [22:31:19] Reencoding: VID_00016, Pass 1 of 1
 - [22:36:57] Video Encode complete
 - [22:36:57] Multiplexing M2TS
 - [22:37:14] Extracting A/V streams [VID_00034]
 - [22:37:49] Reencoding: VID_00034 (17 of 25)
 - [22:37:49] Collecting video information
   - Rate/Length: 23,976fps, 6*154 frames
   - Bitrate: 26*374 Kbs
 - [22:37:49] Reencoding: VID_00034, Pass 1 of 1
 - [22:41:05] Video Encode complete
 - [22:41:05] Multiplexing M2TS
 - [22:41:10] Extracting A/V streams [VID_00035]
 - [22:41:36] Reencoding: VID_00035 (18 of 25)
 - [22:41:36] Collecting video information
   - Rate/Length: 23,976fps, 3*418 frames
 - [22:41:36] Reencoding: VID_00035, Pass 1 of 1
 - [22:43:46] Video Encode complete
 - [22:43:46] Multiplexing M2TS
 - [22:43:50] Extracting A/V streams [VID_00019]
 - [22:45:13] Reencoding: VID_00019 (19 of 25)
 - [22:45:13] Collecting video information
   - Rate/Length: 23,976fps, 12*298 frames
 - [22:45:13] Reencoding: VID_00019, Pass 1 of 1
 - [22:52:15] Video Encode complete
 - [22:52:15] Multiplexing M2TS
 - [22:52:39] Extracting A/V streams [VID_00036]
 - [22:52:41] Reencoding: VID_00036 (20 of 25)
 - [22:52:41] Collecting video information
   - Bitrate: 25*086 Kbs
 - [22:52:41] Reencoding: VID_00036, Pass 1 of 1
 - [22:52:48] Video Encode complete
 - [22:52:48] Multiplexing M2TS
 - [22:52:49] Extracting A/V streams [VID_00037]
 - [22:53:04] Reencoding: VID_00037 (21 of 25)
 - [22:53:04] Collecting video information
   - Rate/Length: 23,976fps, 2*130 frames
 - [22:53:04] Reencoding: VID_00037, Pass 1 of 1
 - [22:54:22] Video Encode complete
 - [22:54:22] Multiplexing M2TS
 - [22:54:25] Extracting A/V streams [VID_00022]
 - [22:55:10] Reencoding: VID_00022 (22 of 25)
 - [22:55:10] Collecting video information
   - Rate/Length: 23,976fps, 7*795 frames
   - Bitrate: 26*465 Kbs
 - [22:55:10] Reencoding: VID_00022, Pass 1 of 1
 - [22:59:21] Video Encode complete
 - [22:59:21] Multiplexing M2TS
 - [22:59:29] Extracting A/V streams [VID_00038]
 - [23:00:28] Reencoding: VID_00038 (23 of 25)
 - [23:00:28] Collecting video information
   - Rate/Length: 23,976fps, 8*748 frames
 - [23:00:28] Reencoding: VID_00038, Pass 1 of 1
 - [23:05:39] Video Encode complete
 - [23:05:39] Multiplexing M2TS
 - [23:05:52] Extracting A/V streams [VID_00039]
 - [23:06:13] Reencoding: VID_00039 (24 of 25)
 - [23:06:13] Collecting video information
   - Rate/Length: 23,976fps, 2*910 frames
 - [23:06:13] Reencoding: VID_00039, Pass 1 of 1
 - [23:08:01] Video Encode complete
 - [23:08:01] Multiplexing M2TS
 - [23:08:05] Extracting A/V streams [VID_00025]
 - [23:10:27] Reencoding: VID_00025 (25 of 25)
 - [23:10:27] Collecting video information
   - Rate/Length: 23,976fps, 25*915 frames
   - Bitrate: 25*055 Kbs
 - [23:10:27] Reencoding: VID_00025, Pass 1 of 1
 - [23:22:50] Video Encode complete
 - [23:22:50] Multiplexing M2TS
[23:23:43]PHASE ONE complete
[23:23:43]PHASE TWO - Rebuild Started
 - [23:23:43] Rebuilding BD file Structure
[23:30:51] - Encode and Rebuild complete
[23:30:51]JOB: MYBESTFRIENDSGIRL finished.
[Status]
LABEL=MYBESTFRIENDSGIRL
VERSION=v0.33.09 (beta)
SOURCE_SIZE=25830082560
SOURCE_VIDEO_SIZE=25830082560
TARGET_SIZE=24326963200
REDUCTION=.941807411706546
RESIZE_1080=0
AUDIO_TO_KEEP=eng;fra;fre;
SUBS_TO_KEEP=eng;fra;fre;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=25
REBUILD_COMPLETE=1
[00001]
AUDIO=1111
PGS=110
M2TS_TARGET=81236178
RATE=26714
NSIZE=73052160
FLINK=-1
MLINK=0
[00026]
M2TS_TARGET=833731199
RATE=24200
AUDIO=1111
NSIZE=798793728
FLINK=-1
MLINK=0
[00003]
M2TS_TARGET=1626476868
RATE=30000
AUDIO=1111
NSIZE=1522937856
FLINK=-1
MLINK=0
[00027]
M2TS_TARGET=238448639
RATE=28732
AUDIO=1111
NSIZE=227401728
FLINK=-1
MLINK=0
[00028]
M2TS_TARGET=527424688
RATE=30000
AUDIO=1111
NSIZE=397295616
FLINK=-1
MLINK=0
[00006]
M2TS_TARGET=523154277
RATE=30000
AUDIO=1111
NSIZE=491649024
FLINK=-1
MLINK=0
[00029]
M2TS_TARGET=273584053
RATE=22481
AUDIO=1111
NSIZE=258490368
FLINK=-1
MLINK=0
[00008]
M2TS_TARGET=877123898
RATE=30000
AUDIO=1111
NSIZE=779298816
FLINK=-1
MLINK=0
[00030]
M2TS_TARGET=39110715
RATE=30000
AUDIO=1111
NSIZE=37570560
FLINK=-1
MLINK=0
[00010]
M2TS_TARGET=2078665941
RATE=30000
AUDIO=1111
NSIZE=1813364736
FLINK=-1
MLINK=0
[00031]
M2TS_TARGET=239947333
RATE=20790
AUDIO=1111
NSIZE=227026944
FLINK=-1
MLINK=0
[00012]
M2TS_TARGET=1962010812
RATE=30000
AUDIO=1111
NSIZE=1785090048
FLINK=-1
MLINK=0
[00032]
M2TS_TARGET=94961673
RATE=22964
AUDIO=1111
NSIZE=88080384
FLINK=-1
MLINK=0
[00014]
M2TS_TARGET=1572413928
RATE=30000
AUDIO=1111
NSIZE=1459617792
FLINK=-1
MLINK=0
[00033]
M2TS_TARGET=496496034
RATE=30000
AUDIO=1111
NSIZE=460474368
FLINK=-1
MLINK=0
[00016]
M2TS_TARGET=1616686169
RATE=29993
AUDIO=1111
NSIZE=1531398144
FLINK=-1
MLINK=0
[00034]
M2TS_TARGET=934757087
RATE=26374
AUDIO=1111
NSIZE=887697408
FLINK=-1
MLINK=0
[00035]
M2TS_TARGET=673087365
RATE=30000
AUDIO=1111
NSIZE=559288320
FLINK=-1
MLINK=0
[00019]
M2TS_TARGET=2187237379
RATE=30000
AUDIO=1111
NSIZE=2013419520
FLINK=-1
MLINK=0
[00036]
M2TS_TARGET=31640389
RATE=25086
AUDIO=1111
NSIZE=30111744
FLINK=-1
MLINK=0
[00037]
M2TS_TARGET=382444814
RATE=30000
AUDIO=1111
NSIZE=350767104
FLINK=-1
MLINK=0
[00022]
M2TS_TARGET=1188134805
RATE=26465
AUDIO=1111
NSIZE=1124278272
FLINK=-1
MLINK=0
[00038]
M2TS_TARGET=1551952988
RATE=30000
AUDIO=1111
NSIZE=1432915968
FLINK=-1
MLINK=0
[00039]
M2TS_TARGET=556738918
RATE=30000
AUDIO=1111
NSIZE=476448768
FLINK=-1
MLINK=0
[00025]
M2TS_TARGET=3739497050
RATE=25055
AUDIO=0100
NSIZE=3485239296
FLINK=0
MLINK=0
[Options]
MODE=1
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
QUICK_EXTRAS=0
TARGET_SIZE=23200
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
[Paths]
WORKING_PATH=D:\WORKING\
SOURCE_PATH=J:\
No other "Codec Pack" or package installed
Tanks
DVD Rebuilder user
Old 25th May 2010, 13:45   #8310  |  Link
drackula
why i can't encode File VC-1
D Rebuilder v0.33.07 (beta)
- Source: THE_ISLAND_2005_1080P_BLU-RAY_CEE_VC-1_DD_5.1_-_EIMI
- Input BD size: 23.84 GB
- Approximate total content: [02:37:39.074]
- Target BD size: 2.34 GB
- Auto Quality: High Quality (Default), Two Pass
- Audio Settings: AC3=1 DTS=0 HD=1 Kbs=448
[19:41:20] PHASE ONE, Encoding
- [19:41:20] Extracting A/V streams [VID_00003]
- [19:41:22] Reencoding: VID_00003 (1 of 5)
- [19:41:22] Collecting video information
- Rate/Length: 23.976fps, 286 frames
- [19:41:22] Reencoding: VID_00003, Pass 1 of 1
- BD-Rebuilder v0.33.07 (beta)
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3326, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[19:41:24] - Failed video encode, aborted
How i can fix this thank you
drackula is offline   Reply With Quote
Old 25th May 2010, 13:49   #8311  |  Link
PeteWalker74
This says it all, brother.
PeteWalker74 is offline   Reply With Quote
Old 25th May 2010, 14:43   #8312  |  Link
To me there's nothing worse than wasting all the encoding time and the blank discs to then sit down to watch the movie and find out that there's an error in the ripping and that you have to do it all over again. If we could find out that there's a problem from the start it would save us a lot of time and money..
YOU are using the program at your own discretion. YOU have chosen to be a beta tester. YOU read the first post of this thread -- including this:
IF BD-RB DOESN'T WORK FOR YOU. JUST REPORT IT AS A BUG. Please leave out the "I wasted 16 hours of my time" commentary. If you don't know the risk of testing a beta you shouldn't be downloading this software.
Please refrain from these kinds of comments.
Old 25th May 2010, 14:53   #8313  |  Link
@Elvis Gratton
That one is a multi-part encode. Since the sections are extracted one-at-a-time there is lots of chance for missing the chance to "extract" rather than encode. Also, they would have to all be small enough to fit (you can't just encode one section, or the quality would not be consistent).
I'll look at it and see if I can come up with a better way to project size on muli-part sources.
As for the sync problem -- I think that was probably fixed with v0.33.09. It turns out that using the internal FFMS in X264 for frame-serving on multi-part sources wasn't as great an idea as I originally thought -- but encoding from the demuxed source rather than the original M2TS seems to have fixed it.
Old 25th May 2010, 17:47   #8314  |  Link
lastangel
My tsmux freeze when i convert audio dts on ac3
the file m2ts not mux and the bdrebuilder go to 100% of process and not respond.
why?
i try many BD
in some m2ts tsmux on mux time freeze.
lastangel is offline   Reply With Quote
Old 25th May 2010, 18:06   #8315  |  Link
colinhunt
Did an alternate output run last night with 03307, not knowing there was a new version out. Source was a playlist of a 90-minute documentary, encoded with MPEG-2 and it has a resolution of 720x480@29.97fps. Inspect reports OK for everything. I had ticked "Resize 1080p to 720p enabled", but "Convert SD to HD (720p)" was not enabled.
Two things went wrong:
1) 720x480 got upconverted to 1280x720, even though "Convert SD to HD (720p)" was disabled.
2) The resulting .mkv looks... odd. Here's a screencap from MPC-HC: http://yfrog.com/1gsnap194640j
As you can see, there's a wide green bar at the top of the image and colour (look at the faces and hands) is misplaced.
update: Image looks fine in VLC, but not in Windows Media Player. I suspect this has something to do with FFDShow.
update: It was caused by DXVA. Once I disabled DXVA support in FFDShow, the image cleared right up. D'oh.
Odd how an episode of a TV show I viewed earlier today on MPC-HC looked fine with DXVA enabled. Hmmh.
Old 25th May 2010, 19:28   #8316  |  Link
colinhunt
I've done hundreds and hundreds of encodes of 720x480 sources and never, never, not even once did it accidentally convert to 720p. In fact -- I can't even imagine how it could be possible. I gotta' believe you had it checked, but didn't know you did at the time you encoded. But I'll take a look. Maybe the 1080p->720p confused it somehow.
After posting the message, I've done several conversions from the same disc (Saving Private Ryan disc 2) with v0.33.09, and they've all come out as 720p even though the source is 720x480. I'm sure I don't have the "Convert SD to HD" option enabled, but I do have the "1080p to 720p" ticked.
Now that I think of it, uou mentioned "the MKV" -- are you doing an "ALTERNATE Output" movie conversion? If so, it would have been helpful to mention it -- and the checkboxes would have no impact at all, your output will be the size you selected in the ALTERATE output list.
I did mention it, right in the first sentence, "Did an alternate output run last night with 03307".
Yeah, I did notice that there were only two MKV output options, 1080p and 720p, but I sorta kinda thought it would use original resolution if that was lower than 720p and the "Convert SD to HD" was not enabled. Felt logical, you know?
Old 25th May 2010, 19:35   #8317  |  Link
Originally Posted by colinhunt View Post
Yes, I am. In fact, after posting the message, I've done several conversions from the same disc (Saving Private Ryan disc 2) with v0.33.09, and they've all come out as 720p even though the source is 720x480. I'm sure I don't have the "Convert SD to HD" option enabled, but I do have the "1080p to 720p" ticked.
Nope. It resizes to the size you select. So it's doing what it is supposed to do.
The flags in the SETUP dialog would contradict the purpose of the ALTERNATE output... for example, if I paid attention to the resizing instructions I could end up eith iPod output that wouldn't play on an iPod.
Old 25th May 2010, 19:42   #8318  |  Link
colinhunt
Okay-dokey! It's back to MeGUI and RipBot for 480p extras... unfortunately. Would've been so much easier with BD-RB
Old 25th May 2010, 20:08   #8319  |  Link
santito
Ps3
i dunno if this is answered before....
but i realize that with the newer versions of bd-rebuilder...
i get "invalid disc" in the ps3
is this happening only to me? or is ps3 no longer supported in bd-rebuilder?
santito is offline   Reply With Quote
Old 25th May 2010, 20:45   #8320  |  Link
Elvis Gratton
update: MYBESTFRIENDSGIRL
@Elvis Gratton
FYI: v0.33.09 not resolve out of sync prob. in this particular case.
After doing some other test ie: edit MUX_MOVIEONLY.meta file
to replace tsmuxer_track.ac3 with eac3to_track.ac3 & set the custom size to 40GB to eliminate reencode & speedup, + remux (audio sync was perfect).
Can you tel me, in this expression: AC3 stream (track 1): overlapped frame detected at position 00:00:22,047. Remove frame. what wants to say: (Remove frame) it is an information or an action ?
maybe these cause of my troubles if audio frame are missing !
i'm not an expert of tsmuxer ...
Again, sorry for my bad English.
thank you for answering
DVD Rebuilder user
