Old 11th May 2018, 12:39   #50781  |  Link
suanm
I wanna ask if madshi has a plan to add an option that converts format 4:2:0 to format 4:4:4 through gpu instead of cpu ?
suanm is offline   Reply With Quote
Old 11th May 2018, 15:46   #50782  |  Link
wushantao
Originally Posted by wushantao View Post
since KB4103721, fullscreen playback broken,it will be blackscreen
anyone have the same problem with me?
win10 x64 1803 17134.48
17134.1 is ok,17134.48(KB4103721) is broken
i think i know it。。。
check “enable automatic fullscreen exclusive mode” is bad
uncheck is okay
wushantao is offline   Reply With Quote
Old 11th May 2018, 15:47   #50783  |  Link
el Filou
el Filou's Avatar
@suanm: madVR already does chroma upscaling of 4:2:0 to 4:4:4 via the GPU, it's basic stuff.
What's your source format? Can you post a screenshot of the madVR OSD to see what format it's receiving from the video decoder?
Old 11th May 2018, 17:25   #50784  |  Link
Asmodian
That is what the "chroma upscaling" page is for.
madVR has an amazing number of options for upscaling the chroma from 4:2:0 to 4:4:4 and they all run on the GPU. NGU AA high is my favorite method for 4:2:0 to 4:4:4.
madVR options explained
Old 11th May 2018, 22:43   #50785  |  Link
Clown shoes
King of the Jungle
Clown shoes's Avatar
Soooooo has anyone had an issue with custom refresh rates causing their HDR image to be green??
No frame drops for over 24 hours, but green HDR! Doh!
Clown shoes is offline   Reply With Quote
Old 12th May 2018, 09:48   #50786  |  Link
mitchmalibu
Are you using a LG OLED ?
OS: Win10 1703
GPU: GTX 1070 (latest stable drivers)
Monitor: LG OLED55B6V TV / Yamaha RX-A860 AVR
Media setup: MPC-BE x64, madvr, lav filters (nightly)
mitchmalibu is offline   Reply With Quote
Old 12th May 2018, 09:59   #50787  |  Link
wushantao
uncheck is okay
amd gpu is ok—amd a10 7890k
intel gpu is not good—intel 4760hq
Old 12th May 2018, 15:27   #50788  |  Link
suanm
First of all:
A big thank to you for your reply.
I posted two screenshots on the post board.
Second:
I'm surprised there is no chroma appeared on madVR OSD.i don't know what's going on?Chroma is not displayed all the time when the playback of 4K UHD movies
Third:
Due to no chroma used, the conversion of 4:2:0 format to 4:4:4 format doesn't always work.This leads to worse video quality.I don't know how to solve the intractable problem.
Old 12th May 2018, 15:32   #50789  |  Link
cam you upload the inages somewhere else?
Old 12th May 2018, 15:37   #50790  |  Link
suanm
You're exactly correct.However, Chroma item doesn't appear all the time when the playback of 4K UHD movies.
Old 12th May 2018, 15:49   #50791  |  Link
imhh11
hey i just want to give props to madshi.
Madvr is so great at upscaling 1080p to 4k , it even looks better than some native 4k stuff
http://caps-a-holic.com/c.php?a=1&x=...1&l=0&i=6&go=1
Old 12th May 2018, 16:22   #50792  |  Link
sauma144
I think my next laptop will be fanless and probably use ARM.
Will madVR support ARM machines?
Is a new release planned this weekend?
sauma144 is offline   Reply With Quote
Old 12th May 2018, 17:02   #50793  |  Link
x7007
What's new with Latest version
0.71 / 0.71.0-35 Nightly (May 12, 2018) ?
there's nothing on the changelog about this specific version
x7007 is offline   Reply With Quote
Old 12th May 2018, 17:52   #50794  |  Link
Ver Greeneyes
This is the only recent commit, so 35 is probably functionally identical to 34. Might have been built with a slightly newer version of Visual Studio.
Old 12th May 2018, 20:10   #50795  |  Link
Asmodian
Are you watching 4K movies on a display with a resolution lower than 4K?
If yes, turn off the trade quality for performance option "scale chroma separately, if it saves performance". This option will let madVR avoid scaling chroma if it doesn't have to, instead scaling luma to reach the same resolution as the chroma. Effectively this is still converting to 4:4:4, but it is probably lower quality than scaling chroma to match the luma and then downscaling in RGB.
Old 12th May 2018, 23:23   #50796  |  Link
tingtong5
Madvr stops working on Win 10
Hi all,
I am using madvr 0.92.14 on win10 build 1703 and it stops working as soon as I want to change settings (see attachment). Any idea why this happens or how to troubleshoot it?
Ronald
tingtong5 is offline   Reply With Quote
Old 12th May 2018, 23:31   #50797  |  Link
can you upload the image somewhere else we have to wait for admin approval first.
Old 12th May 2018, 23:36   #50798  |  Link
tingtong5
http://www.ronaldverlaan.nl/download...512_235232.jpg
Old 13th May 2018, 04:00   #50799  |  Link
As long as it runs Windows non s you're fine. Don't expect much tho. Release this weekend? Doubt it.
Old 13th May 2018, 06:47   #50800  |  Link
oldpainlesskodi
First of all:
Second:
Third:
Have you activated supersampling? (doubling action - always supersample).
It takes a fair amount horsepower, so you might need to adjust your settings for 4k movies when it's activated.
