Old 7th October 2017, 17:00   #5621  |  Link
RieGo
hey there. are there any commands to improve multithreading on x265?
i'm running an i9 @ 12/24x3.5ghz i end up with 70-80% cpu usage at most, using presets medium slow slower slowest / main10
it's running at ~5/6fps on a slower 4k encode
or do you think something else is bottlenecking me?
RieGo is offline   Reply With Quote
Old 7th October 2017, 17:08   #5622  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
This has been discussed numerous times already. x265 doesn't scale past a certain number of cores. You either buy and use UHDKit or run several copies of x265 simultaneously.
Old 7th October 2017, 17:35   #5623  |  Link
RieGo
thanks for explaining.
i was thinking x265 team wrote it scales up to 20(??) threads or something, but i wasn't sure
i also tried to disable HT to run with (only) 12 threads, which doesn't sound like much to me, but same result.
i'll run 2 instances of x265 then. :
Old 8th October 2017, 12:56   #5624  |  Link
You won't notice huge fps boost because HT on intel cpus gives only extra ~15%
If you see cpu utilization at ~75% then this means that in practice you get ~93% of your CPU.
100-15/50*(100-75)=92.5
Old 8th October 2017, 18:16   #5625  |  Link
AMED
AMED's Avatar
Originally Posted by Barough View Post
x265 v2.5+25-4b95f82c9fb1 (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version 2.5+25-4b95f82c9fb1
x265 [info]: build info [Windows][GCC 7.2.0][32/64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
Barough's link doesn't seem to work for me, just goes to a page saying "Drop to share files".
A Man Eating Duck
AMED is offline   Reply With Quote
Old 9th October 2017, 11:13   #5626  |  Link
excellentswordfight
Lost my old account :(
I ran a few benchmarks on some machines a few weeks ago, I thought that x265 scaled quite nicely.
2x Intel Xeon E5-2690 v3 @ 2.9Ghz (24C48T): 3.36 fps
2x Intel Xeon E5-2643 v4 @ 3.6Ghz (12C24T): 2.37 fps
excellentswordfight is offline   Reply With Quote
Old 9th October 2017, 15:47   #5627  |  Link
Barough
Barough's Avatar
No issues with DL'ing the archive here.
Old 9th October 2017, 15:48   #5628  |  Link
Barough
Barough's Avatar
x265 v2.5+27-0e168bdeb48b (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version 2.5+27-0e168bdeb48b
Old 9th October 2017, 16:04   #5629  |  Link
d3rd3vil
If I have an m2ts file with 2 layers and HDR10 PLUS Dolby Vision but the TV only recognizes HDR10, is there a way to force Dolby Vision somehow?
d3rd3vil is offline   Reply With Quote
Old 9th October 2017, 17:22   #5630  |  Link
x265_Project
If there is metadata for multiple HDR standards, the TV decides which HDR format to use. If it has a choice between HDR10 (static HDR) and Dolby Vision (dynamic HDR), it will certainly choose Dolby Vision.
Old 9th October 2017, 17:45   #5631  |  Link
d3rd3vil
Yeah well but it doesnt. MKVToolNix shows 2 streams one with 4k and one with 1080p. Ofc thats not really accurate cause MKVToolNix doesnt support Dolby Vision but both standards are there. The TV doesnt play the m2ts.
So I have to convert the m2ts to mkv which THEN only seems to support HDR10.
As an example this one: http://4kmedia.org/lg-dolby-vision-uhd-4k-demo/
Once I've used MKVToolNix, the Dolby Vision is gone
Is there at least a way to see if I am using Dolby Vision or not? The TS and the MKV files look pretty much the same in MediaInfo for example. But one has DV the other doesnt....
Old 10th October 2017, 10:10   #5632  |  Link
Thunderbolt8
are you sure your TV supports Dolby Vision or 12-bit in general? From what Ive read most panels dont.
Old 10th October 2017, 10:24   #5633  |  Link
d3rd3vil
12 bit doesnt matter atm. No TV supports that, thats true.
I got an LG Oled B6. All these Oleds support Dolby Vision. So as I said the TS file has DV and it works fine! After using MKVToolNix, cause the program doesnt support DV, Dolby Vision is gone from the MKV.
But still some information wether the file has DV or not would be nice. But MediaInfo, nor MPC or VLC or any program show anything regarding Dolby Vision....its like it doesnt exist yet. Unfortunate
Old 10th October 2017, 11:05   #5634  |  Link
This entire discussion is rather off-topic for the x265 thread, since x265 cannot encode Dolby Vision, nor is it in any way related to handling your existing Dolby Vision files.
Old 11th October 2017, 07:59   #5635  |  Link
jlpsvk
Hi... how can I use extracted Dolby Vision Enhancement layer to encode it to HEVC stream directly with x265?
jlpsvk is offline   Reply With Quote
Old 11th October 2017, 14:17   #5636  |  Link
d3rd3vil
And how to even detect it properly with eac3to
Old 11th October 2017, 15:30   #5637  |  Link
Why do you add a question about eac3to to a thread specifically discussing the development of x265? Stay in each thread, separately, please.
Old 11th October 2017, 18:44   #5638  |  Link
jlpsvk
I asked about using the layer in x265!
Old 11th October 2017, 18:51   #5639  |  Link
@jlpsvk: I directed that to d3rd3vil. Being interested in enhancing x265 is a valid intention here. But using eac3to is best discussed in a thread about eac3to, instead. And there I already expressed my doubts that eac3to is the first choice software to treat video streams, because it was originally made to handle audio streams.
Old 11th October 2017, 19:56   #5640  |  Link
jlpsvk
@LigH
Yeah. Ok. But. Can I use the demuxed Dolby Vision stream and mux it to encoded video with x265? in MKV new eac3to (3.22) is recognizing Dolby Vision Enhancement Layer too.
