Old 26th February 2019, 20:23   #6761  |  Link
katzenjoghurt
Hi Ma,
I fear I can't be of help finding an answer to your question but thanks a lot for looking into it! *thumbsup*
Old 27th February 2019, 05:36   #6762  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by Wolfberry View Post
The only difference between Au+7 and Au+3 are SVT-HEVC (not enabled in the build you use) and the zone fix in linux (which probably breaks staxrip) (need to investigate further)
@FranceBB New test build Not Set SSE4.2
This one works, however I can't encode anything higher than 8bit (if I try to use Main10 it reverts back to the default bit-depth).
I remember that I had this kind of issue when I tried to compile x265 x86 with Visual Studio (I never managed to get 10bit and 12bit builds for x86 out of Visual Studio).
I tried now with a longer test, but encoding at 8bit this time, letting x265 calculate the average speed for me and feeding it with a 16bit uncompressed clip:
- GCC 8.2 SSE4.2
6.19fps
- Wolfberry not SSE4.2
6.14fps
- GCC 9 Preview SSE4.2
6.11fps
- LigH
6.22fps
However, encoding at 8bit and comparing different compilers shows different results, 'cause for 8bit x265 there are manually written intrinsics by x265 developers.
The interesting part is with 10bit for which there aren't manually written intrinsics, so it's up to the compiler to optimize the plain C++ code as much as possible, that's why I was testing them with Main10 in my previous test.
For the 8bit, apparently, GCC9 is still slower than GCC8, your build without targeting SSE4.2 is somewhere in-between and the one made by LigH is faster than mine for whatever reason.
But again, for 8bit there are manually written intrinsics, so I can't really test the effectiveness of compilers.
Old 28th February 2019, 10:23   #6763  |  Link
Ma
@katzenjoghurt
In new binaries from http://msystem.waw.pl/x265/ (ver. 3.0_Au+8) zones are working.
Now I must do some work for living but at the weekend I should look into this bug closer and prepare proper patch that works with SVT_HEVC too.
Old 28th February 2019, 17:11   #6764  |  Link
x265 3.0 Au+8-31ab7e09a3b5 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
New 64-bit GCC 8.3.0, and zone issues should be fixed
Old 28th February 2019, 19:58   #6765  |  Link
katzenjoghurt
Originally Posted by Ma View Post
@katzenjoghurt
Yes! Wonderful! ... works like a charm for me again.
Immediately tried it out this morning but had to get to work as well (really quick) and was running out of time to post about it.
Thank you, Ma.
Old 5th March 2019, 16:31   #6766  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+9-2abd2a1909a4 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
Old 5th March 2019, 17:02   #6767  |  Link
filler56789
SuperVirus
filler56789's Avatar
↑ @Barough: many for the new build
Old 10th March 2019, 16:59   #6768  |  Link
Barough
Barough's Avatar
x265 v3.0_Au+14-c7e5878bdd31 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (32bit-GCC v7.4.0 / 64bit-GCC v8.3.0)
Old 13th March 2019, 14:48   #6769  |  Link
x265 3.0 Au+14-c7e5878bdd31 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
3 flavours:
  • "Win32XP" (XP compatibility enabled, should disable NUMA support)
  • "Win32" (XP compatibility disabled, NUMA support should be enabled in Win7+)
  • "Win64"
AVX2 for normFactor and ssimDistortion
Old 30th March 2019, 05:50   #6770  |  Link
filler56789
SuperVirus
x265.exe 3.0_Au+16-0018ca1ca42f
(GCC 7.4.0, 64-bits, multilib)
http://www.mediafire.com/file/gtr4eh...018ca1ca42f.7z
Old 14th April 2019, 21:19   #6771  |  Link
Forteen88
Herr
@Wolfberry. You're not releasing a ICC19-compile of x265 anymore?
Forteen88 is offline   Reply With Quote
Old 21st April 2019, 09:13   #6772  |  Link
filler56789
SuperVirus
x265-3.0_Au+21-bac0e1acb874-win64-multilib
x265 [info]: build info [Windows][GCC 8.3.1][64 bit] 8bit+10bit+12bit
x265 [info]: (libavcodec  58.51.100)
x265 [info]: (libavformat 58.27.102)
x265 [info]: (libavutil   56.26.100)
x265 [info]: (lsmash       2.16.1)
Compiled with LAVF & LSMASH support, patches from msg7086.
Your build doesn't work on 64-bit Windows 7, it simply crashes
Old 21st April 2019, 11:26   #6773  |  Link
lvqcl
I suspect that the problem is not an OS. Probably your CPU doesn't support AVX (or AVX2?), and this build requires it for some reason.
Old 21st April 2019, 15:40   #6774  |  Link
filler56789
SuperVirus
Yeah, that build requires AVX.
New build
x265 [info]: HEVC encoder version 3.0_Au+21-bac0e1acb874
x265 [info]: (libavcodec  58.52.100)
x265 [info]: (libavformat 58.27.103)
I'm using march=core2 for this build (I use --with-arch=core2 when configuring gcc), so it should work for most people, but no guarantee as I don't have a spare machine to test.
Thanks for the compatible build
It is somewhat bloated because of the additional stuff, but I compressed it with upx and now it has a healthy weight.
Old 25th April 2019, 18:52   #6775  |  Link
Boulder
Pig on the wing
Boulder's Avatar
How does one get rid of the "onion gradient" artifacts of x265? In the sample images, they are apparent in the character's forehead and also in the purplish stripe near his hair (zoom a bit to see both better). The bitrate of the encodes is ~6900 kbps.
x264
x265, aq-mode 1
x265, aq-mode 2
Some base settings of the x265 encode:
--deblock -2:-1 --no-strong-intra-smoothing --cbqpoffs -3 --crqpoffs -3 --subme 3 --merange 24 --no-sao --no-rect --qcomp 0.7 --rd 6 --rd-refine
--aq-mode 1/aq-mode 2 --aq-strength 0.9 --ctu 16 --max-tu-size 8 --qg-size 16 --tu-inter-depth 2 --tu-intra-depth 2 --limit-tu 1 --limit-refs 3
--max-merge 2 --ref 5 --bframes 10
The x264 settings are pretty much --preset veryslow --tune film --no-fast-pskip --no-dct-decimate --deblock -2:-1 --qcomp 0.7.
Old 26th April 2019, 10:02   #6776  |  Link
mini-moose
Maybe post a source cap too.
mini-moose is offline   Reply With Quote
Old 26th April 2019, 16:46   #6777  |  Link
benwaggoner
You are doing some weird settings in there which may have combinatorial effects. Can you try just --preset slower and see how that turns out?
A 8x8 max tu is pretty unusual, and those are also big chroma offsets which can suck bits away from luma. What are the goals of these settings, and how tdid you come to them?
Ben Waggoner
My Compression Book
Old 27th April 2019, 10:01   #6778  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I got you the original clip here. I basically did a very slight MDegrain and then downscaled to 1280x720 using a very sharp Bicubic and fed to the encoders.
https://drive.google.com/open?id=1Qm...9NZavzXFTSkGIr
My x265 settings are based on frame-by-frame comparisons that I made several times. A small CTU and TU size look better (least distortion compared to the original image) with 720p encodes. For 1080p, I would use one notch higher values (also based on my tests). The chroma offsets don't change the bitrate much in CRF mode so the difference in 2-pass shouldn't also be big. Besides, x264 already does a similar thing by default.
EDIT: does anyone else have problems with topic notifications? I don't get any emails at all from any thread I've subscribed to.
Old 27th April 2019, 10:54   #6779  |  Link
excellentswordfight
Lost my old account :(
Dont seem to be an "general" issue with x265. Did a re-encode of your sample and I didnt get an gradiant issue, and overall I think x265 did a better job. I think benwaggoner is right, its your settings thats causing it.
x264 2pass @ 5Mbps, veryslow tune film
x265 2pass @ 5Mbps, slow, --no-sao --no-strong-intra-smoothing --deblock -1:-1
excellentswordfight is offline   Reply With Quote
Old 27th April 2019, 18:59   #6780  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, that's exactly what I was looking for since I was experimenting a lot with aq-strength and the psy options to try to figure out what is wrong but was clearly looking in the wrong place.
I did some more testing now that I found those troublesome frames (it seems they evaded me when I pinpointed my go-to settings a long time ago), and using CTU 32 makes the onionize effect go away. I also left max-tu-size and qg-size at their defaults since things looked good.
